PX4 Dev Call: September 28, 2022
September 28, 2022
Join us
Agenda
  • Community Announcement
  • Community Q&A
  • Project Updates
  • General Discussions
  • Weekly Overview
  • High priority queue
  • Release
:loudspeaker: Community Announcement
Discord migration effort
Try out the server here:
Progress tracked here:
  • Lots of cool bots
  • Matrix could be an option as well
  • But Discord is very nice (e.g. Ardupilot uses it)
  • Linux foundation could be helpful for Matrix version bumping up as well - Mark
  • Try out matrix if you are interested: https://element.io/
Matrix migration effort
Check out how the Matrix works as well! It’s not as bad as you think :wink:
:people_holding_hands: Community Q&A (No deep technical discussions)
:exclamation: Guideline for asking a Question
  1. Specify what you are trying to achieve
  2. Specify what environment / platform you are using
  3. Prepare a Link or Document to help understand if possible
  4. First, ask the question on the Slack or create a Github Issue!
  5. If you take over 5 minutes for the question, please continue in Slack or a Github Issue.
Q.1 : Pixhawk 6C compass calibration not working
  • Have to calibrate everytime it boots up
  • Check for mag_worker_data, after having the logging set to ā€˜debug’
  • Also affects v1.13
  • If SYS_AUTOCONFIG is being force-set, it will force re-setting the Compass calibration data
Q.2 : Doing Mission ā€˜push’ via ROS2
  • Mission waypoint push was possible via MAVROS, how do we do that via ROS2?
  • For example, pushing JSON file getting pushed via MAVROS to PX4
  • TODO: @farhang will create PX4 Github issue to track which MAVROS features would be needed for ROS2 DDS bridge features.
Q.3:
:construction_worker_woman: Project Updates
P.1 : CM4 Integration in progress
  • CM4 <> FMU v6x serial connection works
  • Ethernet also works for both Companion & FMU
P.2 : Fixed-wing focus call from yesterday
P.3: Gazebo improvements - Ben
https://github.com/PX4/PX4-Autopilot/pull/20319
  • Now we can drag & drop models through Gazebo
  • Beforehand, the SITL Gazebo was outdated
  • Gazebo Ignition is now called ā€œGZā€ (OSRF’s decision)
  • Using this, you don’t need to use SITL Gazebo at all. Uses native Gazebo’s simulation feature
  • This allows you to ā€˜pause’ the Simulation properly without memory leaks / very fast to launch
  • Now we don’t have to keep track of DAE / STL, with this feature.
  • Currently, Quadcopter Plugin was adapted with the PR above.
  • Fixed-wing Plugin exists, would appreciate any tests!
  • Help on adding more vehicle types would be much appreciated :+1:
:thinking: General Discussions
D.1 : FMU v6x Bootloader UART port PR
https://github.com/PX4/PX4-Autopilot/pull/20292
  • Should we switch to TELEM2? (Holybro CM4 case)
  • Or, how do we support both TELEM1 and TELEM2?
  • TODO: Scan through UART ports & automatically detecting baud rates
  • We need to have a robust auto-baud-detect mechanism - Chris
  • Bootloader’s documentation (baud-rate and ports) is not good yet
  • TODO: Add TELEM2 921600,
:calendar: Weekly Overview
:mouse2: Github
Recently updated Issues / PRs in PX4-Autopilot Link
Pull Requests
Issues
:computer: Slack
:phone: Last Dev-Call
PX4 Dev Call: April 27, 2022
:exclamation: High priority queue
Discussion based on: https://github.com/orgs/PX4/projects/24
:ear_of_rice: Release
If we can discuss these in case unsolved:
This is my concern as well:
Relevant maybe:
Added the issue:
