@hsu-ret Thanks for you comment.
I implemented the command to enter offboard mode and arming.
Also, I verified it armed and entered offboard mode.
What is POSCTL mode?
I used the same code for offboard code in the tutorial -> https://dev.px4.io/v1.9.0/en/ros/mavros_offboard.html
I attached my log as following for reference.
SUMMARY
CLEAR PARAMETERS
PARAMETERS
/hector_mapping/advertise_map_service: True
/hector_mapping/base_frame: base_link
/hector_mapping/laser_z_max_value: 1.0
/hector_mapping/laser_z_min_value: -1.0
/hector_mapping/map_frame: map
/hector_mapping/map_multi_res_levels: 2
/hector_mapping/map_resolution: 0.1
/hector_mapping/map_size: 2048
/hector_mapping/map_start_x: 0.5
/hector_mapping/map_start_y: 0.5
/hector_mapping/map_update_angle_thresh: 0.06
/hector_mapping/map_update_distance_thresh: 0.4
/hector_mapping/odom_frame: base_link
/hector_mapping/pub_map_odom_transform: True
/hector_mapping/scan_subscriber_queue_size: 5
/hector_mapping/scan_topic: scan
/hector_mapping/tf_map_scanmatch_transform_frame_name: scanmatcher_frame
/hector_mapping/update_factor_free: 0.4
/hector_mapping/update_factor_occupied: 0.9
/hector_mapping/use_tf_pose_start_estimate: False
/hector_mapping/use_tf_scan_transformation: True
/imu_attitude_to_tf_node/base_frame: base_footprint
/imu_attitude_to_tf_node/base_stabilized_frame: base_stabilized
/mavros/cmd/use_comp_id_system_control: False
/mavros/conn/heartbeat_rate: 1.0
/mavros/conn/system_time_rate: 1.0
/mavros/conn/timeout: 10.0
/mavros/conn/timesync_rate: 10.0
/mavros/distance_sensor/hrlv_ez4_pub/field_of_view: 0.0
/mavros/distance_sensor/hrlv_ez4_pub/frame_id: hrlv_ez4_sonar
/mavros/distance_sensor/hrlv_ez4_pub/id: 0
/mavros/distance_sensor/hrlv_ez4_pub/orientation: PITCH_270
/mavros/distance_sensor/hrlv_ez4_pub/send_tf: True
/mavros/distance_sensor/hrlv_ez4_pub/sensor_position/x: 0.0
/mavros/distance_sensor/hrlv_ez4_pub/sensor_position/y: 0.0
/mavros/distance_sensor/hrlv_ez4_pub/sensor_position/z: -0.1
/mavros/distance_sensor/laser_1_sub/id: 3
/mavros/distance_sensor/laser_1_sub/orientation: PITCH_270
/mavros/distance_sensor/laser_1_sub/subscriber: True
/mavros/distance_sensor/lidarlite_pub/field_of_view: 0.0
/mavros/distance_sensor/lidarlite_pub/frame_id: lidarlite_laser
/mavros/distance_sensor/lidarlite_pub/id: 1
/mavros/distance_sensor/lidarlite_pub/orientation: PITCH_270
/mavros/distance_sensor/lidarlite_pub/send_tf: True
/mavros/distance_sensor/lidarlite_pub/sensor_position/x: 0.0
/mavros/distance_sensor/lidarlite_pub/sensor_position/y: 0.0
/mavros/distance_sensor/lidarlite_pub/sensor_position/z: -0.1
/mavros/distance_sensor/sonar_1_sub/id: 2
/mavros/distance_sensor/sonar_1_sub/orientation: PITCH_270
/mavros/distance_sensor/sonar_1_sub/subscriber: True
/mavros/fake_gps/eph: 2.0
/mavros/fake_gps/epv: 2.0
/mavros/fake_gps/fix_type: 3
/mavros/fake_gps/geo_origin/alt: 408.0
/mavros/fake_gps/geo_origin/lat: 47.3667
/mavros/fake_gps/geo_origin/lon: 8.55
/mavros/fake_gps/gps_rate: 5.0
/mavros/fake_gps/mocap_transform: True
/mavros/fake_gps/satellites_visible: 5
/mavros/fake_gps/tf/child_frame_id: fix
/mavros/fake_gps/tf/frame_id: map
/mavros/fake_gps/tf/listen: False
/mavros/fake_gps/tf/rate_limit: 10.0
/mavros/fake_gps/tf/send: False
/mavros/fake_gps/use_mocap: True
/mavros/fake_gps/use_vision: False
/mavros/fcu_protocol: v2.0
/mavros/fcu_url: /dev/ttyUSB2:57600
/mavros/gcs_url:
/mavros/global_position/child_frame_id: base_link
/mavros/global_position/frame_id: map
/mavros/global_position/gps_uere: 1.0
/mavros/global_position/rot_covariance: 99999.0
/mavros/global_position/tf/child_frame_id: base_link
/mavros/global_position/tf/frame_id: map
/mavros/global_position/tf/global_frame_id: earth
/mavros/global_position/tf/send: False
/mavros/global_position/use_relative_alt: True
/mavros/image/frame_id: px4flow
/mavros/imu/angular_velocity_stdev: 0.000349065850399
/mavros/imu/frame_id: base_link
/mavros/imu/linear_acceleration_stdev: 0.0003
/mavros/imu/magnetic_stdev: 0.0
/mavros/imu/orientation_stdev: 1.0
/mavros/local_position/frame_id: map
/mavros/local_position/tf/child_frame_id: base_link
/mavros/local_position/tf/frame_id: map
/mavros/local_position/tf/send: False
/mavros/local_position/tf/send_fcu: False
/mavros/mission/pull_after_gcs: True
/mavros/mocap/use_pose: True
/mavros/mocap/use_tf: False
/mavros/odometry/in/child_frame_id: base_link
/mavros/odometry/in/frame_id: odom
/mavros/odometry/in/frame_tf/body_frame_orientation: flu
/mavros/odometry/in/frame_tf/local_frame: local_origin_ned
/mavros/odometry/out/frame_tf/body_frame_orientation: frd
/mavros/odometry/out/frame_tf/local_frame: vision_ned
/mavros/plugin_blacklist: [‘safety_area’, '…
/mavros/plugin_whitelist: []
/mavros/px4flow/frame_id: px4flow
/mavros/px4flow/ranger_fov: 0.118682389136
/mavros/px4flow/ranger_max_range: 5.0
/mavros/px4flow/ranger_min_range: 0.3
/mavros/safety_area/p1/x: 1.0
/mavros/safety_area/p1/y: 1.0
/mavros/safety_area/p1/z: 1.0
/mavros/safety_area/p2/x: -1.0
/mavros/safety_area/p2/y: -1.0
/mavros/safety_area/p2/z: -1.0
/mavros/setpoint_accel/send_force: False
/mavros/setpoint_attitude/reverse_thrust: False
/mavros/setpoint_attitude/tf/child_frame_id: target_attitude
/mavros/setpoint_attitude/tf/frame_id: map
/mavros/setpoint_attitude/tf/listen: False
/mavros/setpoint_attitude/tf/rate_limit: 50.0
/mavros/setpoint_attitude/use_quaternion: False
/mavros/setpoint_position/mav_frame: LOCAL_NED
/mavros/setpoint_position/tf/child_frame_id: target_position
/mavros/setpoint_position/tf/frame_id: map
/mavros/setpoint_position/tf/listen: False
/mavros/setpoint_position/tf/rate_limit: 50.0
/mavros/setpoint_raw/thrust_scaling: 1.0
/mavros/setpoint_velocity/mav_frame: LOCAL_NED
/mavros/startup_px4_usb_quirk: True
/mavros/sys/disable_diag: False
/mavros/sys/min_voltage: 10.0
/mavros/target_component_id: 1
/mavros/target_system_id: 1
/mavros/tdr_radio/low_rssi: 40
/mavros/time/time_ref_source: fcu
/mavros/time/timesync_avg_alpha: 0.6
/mavros/time/timesync_mode: MAVLINK
/mavros/vibration/frame_id: base_link
/mavros/vision_pose/tf/child_frame_id: vision_estimate
/mavros/vision_pose/tf/frame_id: map
/mavros/vision_pose/tf/listen: False
/mavros/vision_pose/tf/rate_limit: 10.0
/mavros/vision_speed/listen_twist: True
/mavros/vision_speed/twist_cov: True
/mavros/wheel_odometry/child_frame_id: base_link
/mavros/wheel_odometry/count: 2
/mavros/wheel_odometry/frame_id: map
/mavros/wheel_odometry/send_raw: True
/mavros/wheel_odometry/send_twist: False
/mavros/wheel_odometry/tf/child_frame_id: base_link
/mavros/wheel_odometry/tf/frame_id: map
/mavros/wheel_odometry/tf/send: True
/mavros/wheel_odometry/use_rpm: False
/mavros/wheel_odometry/vel_error: 0.1
/mavros/wheel_odometry/wheel0/radius: 0.05
/mavros/wheel_odometry/wheel0/x: 0.0
/mavros/wheel_odometry/wheel0/y: -0.15
/mavros/wheel_odometry/wheel1/radius: 0.05
/mavros/wheel_odometry/wheel1/x: 0.0
/mavros/wheel_odometry/wheel1/y: 0.15
/rosdistro: kinetic
/rosversion: 1.12.14
/rplidarNode/angle_compensate: True
/rplidarNode/frame_id: laser
/rplidarNode/inverted: False
/rplidarNode/scan_mode: Sensitivity
/rplidarNode/scan_name: /scan
/rplidarNode/serial_baudrate: 256000
/rplidarNode/serial_port: /dev/ttyUSB0
/rplidarNode_v/angle_compensate: True
/rplidarNode_v/frame_id: laser_v
/rplidarNode_v/inverted: False
/rplidarNode_v/scan_mode: Sensitivity
/rplidarNode_v/scan_name: /scan_v
/rplidarNode_v/serial_baudrate: 256000
/rplidarNode_v/serial_port: /dev/ttyUSB1
NODES
base_to_laser_broadcaster (tf/static_transform_publisher)
generate_topics (rplidar_ros/generate_topics.py)
hector_mapping (hector_mapping/hector_mapping)
imu_attitude_to_tf_node (hector_imu_attitude_to_tf/imu_attitude_to_tf_node)
laser_broadcaster1 (tf/static_transform_publisher)
laser_broadcaster2 (tf/static_transform_publisher)
laser_broadcaster3 (tf/static_transform_publisher)
mavros (mavros/mavros_node)
rplidarNode (rplidar_ros/rplidarNode)
rplidarNode_v (rplidar_ros/rplidarNode)
auto-starting new master
process[master]: started with pid [1971]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to 176f6190-b564-11e9-8580-b827eb162589
process[rosout-1]: started with pid [1984]
process[rplidarNode-2]: started with pid [2002]
process[rplidarNode_v-3]: started with pid [2003]
process[hector_mapping-4]: started with pid [2015]
process[base_to_laser_broadcaster-5]: started with pid [2032]
process[mavros-6]: started with pid [2042]
[ INFO] [1564777716.331294931]: RPLIDAR running on ROS package rplidar_ros. SDK Version:1.10.0
process[generate_topics-7]: started with pid [2053]
process[laser_broadcaster1-8]: started with pid [2068]
[ INFO] [1564777716.451790689]: RPLIDAR running on ROS package rplidar_ros. SDK Version:1.10.0
process[laser_broadcaster2-9]: started with pid [2087]
process[laser_broadcaster3-10]: started with pid [2094]
process[imu_attitude_to_tf_node-11]: started with pid [2109]
RPLIDAR S/N: F98D9AF2C1EA9FC0BEEB9CF3765E3200
[ INFO] [1564777716.854759330]: Firmware Ver: 1.25
[ INFO] [1564777716.854902250]: Hardware Rev: 6
[ INFO] [1564777716.857746649]: RPLidar health status : 0
RPLIDAR S/N: 92889AF0C5E29DD2B6E39DF5115B3116
[ INFO] [1564777716.973520876]: Firmware Ver: 1.27
[ INFO] [1564777716.973674734]: Hardware Rev: 6
[ INFO] [1564777716.976645959]: RPLidar health status : 0
HectorSM map lvl 0: cellLength: 0.1 res x:2048 res y: 2048
HectorSM map lvl 1: cellLength: 0.2 res x:1024 res y: 1024
[ INFO] [1564777717.454586623]: HectorSM p_base_frame_: base_link
[ INFO] [1564777717.455374559]: HectorSM p_map_frame_: map
[ INFO] [1564777717.455520969]: HectorSM p_odom_frame_: base_link
[ INFO] [1564777717.455601075]: HectorSM p_scan_topic_: scan
[ INFO] [1564777717.455817383]: HectorSM p_use_tf_scan_transformation_: true
[ INFO] [1564777717.455902697]: HectorSM p_pub_map_odom_transform_: true
[ INFO] [1564777717.455978428]: HectorSM p_scan_subscriber_queue_size_: 5
[ INFO] [1564777717.456065930]: HectorSM p_map_pub_period_: 2.000000
[ INFO] [1564777717.456138693]: HectorSM p_update_factor_free_: 0.400000
[ INFO] [1564777717.456218122]: HectorSM p_update_factor_occupied_: 0.900000
[ INFO] [1564777717.456310207]: HectorSM p_map_update_distance_threshold_: 0.400000
[ INFO] [1564777717.456391459]: HectorSM p_map_update_angle_threshold_: 0.060000
[ INFO] [1564777717.456460784]: HectorSM p_laser_z_min_value_: -1.000000
[ INFO] [1564777717.456527609]: HectorSM p_laser_z_max_value_: 1.000000
[ INFO] [1564777717.581874642]: current scan mode: Sensitivity, max_distance: 25.0 m, Point number: 15.9K , angle_compensate: 2
[ INFO] [1564777717.696761363]: current scan mode: Sensitivity, max_distance: 25.0 m, Point number: 15.9K , angle_compensate: 2
[ INFO] [1564777718.063548227]: FCU URL: /dev/ttyUSB2:57600
[ INFO] [1564777718.084321837]: serial0: device: /dev/ttyUSB2 @ 57600 bps
[ INFO] [1564777718.089434509]: GCS bridge disabled
[ INFO] [1564777718.312595041]: Plugin 3dr_radio loaded
[ INFO] [1564777718.326447969]: Plugin 3dr_radio initialized
[ INFO] [1564777718.327004336]: Plugin actuator_control loaded
[ INFO] [1564777718.369016621]: Plugin actuator_control initialized
[ INFO] [1564777718.449981432]: Plugin adsb loaded
[ INFO] [1564777718.493387864]: Plugin adsb initialized
[ INFO] [1564777718.494143246]: Plugin altitude loaded
[ INFO] [1564777718.502350157]: Plugin altitude initialized
[ INFO] [1564777718.503397212]: Plugin cam_imu_sync loaded
[ INFO] [1564777718.510859366]: Plugin cam_imu_sync initialized
[ INFO] [1564777718.511683135]: Plugin command loaded
[ INFO] [1564777718.582857977]: Plugin command initialized
[ INFO] [1564777718.585145166]: Plugin companion_process_status loaded
[ INFO] [1564777718.616295634]: Plugin companion_process_status initialized
[ INFO] [1564777718.617271386]: Plugin debug_value loaded
[ INFO] [1564777718.678060568]: Plugin debug_value initialized
[ INFO] [1564777718.678908401]: Plugin distance_sensor blacklisted
[ INFO] [1564777718.679926185]: Plugin fake_gps loaded
[ INFO] [1564777718.850327671]: Plugin fake_gps initialized
[ INFO] [1564777718.852614026]: Plugin ftp loaded
[ INFO] [1564777718.934649122]: Plugin ftp initialized
[ INFO] [1564777718.935725814]: Plugin global_position loaded
[ INFO] [1564777719.109563676]: Plugin global_position initialized
[ INFO] [1564777719.110373225]: Plugin gps_rtk loaded
[ INFO] [1564777719.136194104]: Plugin gps_rtk initialized
[ INFO] [1564777719.137760857]: Plugin hil loaded
[ INFO] [1564777719.302694162]: Plugin hil initialized
[ INFO] [1564777719.304475294]: Plugin home_position loaded
[ INFO] [1564777719.354373055]: Plugin home_position initialized
[ INFO] [1564777719.355765794]: Plugin imu loaded
[ INFO] [1564777719.454997814]: Plugin imu initialized
[ INFO] [1564777719.455970752]: Plugin local_position loaded
[ INFO] [1564777719.532553629]: Plugin local_position initialized
[ INFO] [1564777719.533376668]: Plugin log_transfer loaded
[ INFO] [1564777719.579582785]: Plugin log_transfer initialized
[ INFO] [1564777719.580640413]: Plugin manual_control loaded
[ INFO] [1564777719.642596355]: Plugin manual_control initialized
[ INFO] [1564777719.643338402]: Plugin mocap_pose_estimate loaded
[ INFO] [1564777719.709174533]: Plugin mocap_pose_estimate initialized
[ INFO] [1564777719.709785640]: Plugin obstacle_distance loaded
[ INFO] [1564777719.741933950]: Plugin obstacle_distance initialized
[ INFO] [1564777719.743230020]: Plugin odom loaded
[ INFO] [1564777719.839791512]: Plugin odom initialized
[ INFO] [1564777719.840578404]: Plugin param loaded
[ INFO] [1564777719.890238868]: Plugin param initialized
[ INFO] [1564777719.891066699]: Plugin px4flow loaded
[ INFO] [1564777719.992525903]: Plugin px4flow initialized
[ INFO] [1564777719.992890286]: Plugin rangefinder blacklisted
[ INFO] [1564777719.995770870]: Plugin rc_io loaded
[ INFO] [1564777720.045710284]: Plugin rc_io initialized
[ INFO] [1564777720.045947736]: Plugin safety_area blacklisted
[ INFO] [1564777720.046728690]: Plugin setpoint_accel loaded
[ INFO] [1564777720.092944848]: Plugin setpoint_accel initialized
[ INFO] [1564777720.093976068]: Plugin setpoint_attitude loaded
[ INFO] [1564777720.227219692]: Plugin setpoint_attitude initialized
[ INFO] [1564777720.229520312]: Plugin setpoint_position loaded
[ INFO] [1564777720.424783701]: Plugin setpoint_position initialized
[ INFO] [1564777720.426114875]: Plugin setpoint_raw loaded
[ INFO] [1564777720.562319550]: Plugin setpoint_raw initialized
[ INFO] [1564777720.564479490]: Plugin setpoint_velocity loaded
[ INFO] [1564777720.646402111]: Plugin setpoint_velocity initialized
[ INFO] [1564777720.647419528]: Plugin sys_status loaded
[ INFO] [1564777720.764236825]: Plugin sys_status initialized
[ INFO] [1564777720.765705710]: Plugin sys_time loaded
[ INFO] [1564777720.847508381]: TM: Timesync mode: MAVLINK
[ INFO] [1564777720.876621219]: Plugin sys_time initialized
[ INFO] [1564777720.878774128]: Plugin trajectory loaded
[ INFO] [1564777720.988444091]: Plugin trajectory initialized
[ INFO] [1564777720.989691044]: Plugin vfr_hud loaded
[ INFO] [1564777720.999390201]: Plugin vfr_hud initialized
[ INFO] [1564777720.999591299]: Plugin vibration blacklisted
[ INFO] [1564777721.000640383]: Plugin vision_pose_estimate loaded
[ INFO] [1564777721.152630702]: Plugin vision_pose_estimate initialized
[ INFO] [1564777721.154552561]: Plugin vision_speed_estimate loaded
[ INFO] [1564777721.227410789]: Plugin vision_speed_estimate initialized
[ INFO] [1564777721.228701282]: Plugin waypoint loaded
[ INFO] [1564777721.305171714]: Plugin waypoint initialized
[ INFO] [1564777721.305574326]: Plugin wheel_odometry blacklisted
[ INFO] [1564777721.307387278]: Plugin wind_estimation loaded
[ INFO] [1564777721.312024450]: Plugin wind_estimation initialized
[ INFO] [1564777721.312452792]: Autostarting mavlink via USB on PX4
[ INFO] [1564777721.312875665]: Built-in SIMD instructions: None
[ INFO] [1564777721.313282079]: Built-in MAVLink package version: 2019.3.3
[ INFO] [1564777721.313584585]: Known MAVLink dialects: common ardupilotmega ASLUAV autoquad icarous matrixpilot paparazzi slugs standard uAvionix ualberta
[ INFO] [1564777721.313841673]: MAVROS started. MY ID 1.240, TARGET ID 1.1
[ INFO] [1564777721.436847898]: IMU: Attitude quaternion IMU detected!
[ INFO] [1564777721.457883043]: IMU: High resolution IMU detected!
[ INFO] [1564777721.476037872]: RC_CHANNELS message detected!
[ERROR] [1564777721.710320199]: FCU: Onboard controller lost
[ WARN] [1564777721.732713079]: TM : RTT too high for timesync: 16.41 ms.
[ INFO] [1564777722.139020787]: CON: Got HEARTBEAT, connected. FCU: PX4 Autopilot
[ INFO] [1564777722.213430985]: FCU: Onboard controller regained
[ INFO] [1564777722.221339409]: IMU: Attitude quaternion IMU detected!
[ INFO] [1564777722.234291675]: IMU: High resolution IMU detected!
[ WARN] [1564777722.327128508]: TM : RTT too high for timesync: 11.04 ms.
[ INFO] [1564777722.443569571]: RC_CHANNELS message detected!
[ WARN] [1564777722.933251543]: TM : RTT too high for timesync: 17.00 ms.
[ INFO] [1564777723.200125309]: VER: 1.1: Capabilities 0x000000000000e4ef
[ INFO] [1564777723.200563181]: VER: 1.1: Flight software: 010902ff (106905871d000000)
[ INFO] [1564777723.200824436]: VER: 1.1: Middleware software: 010902ff (106905871d000000)
[ INFO] [1564777723.201011835]: VER: 1.1: OS software: 071c00ff (423371c7d4012e72)
[ INFO] [1564777723.201193608]: VER: 1.1: Board hardware: 00000011
[ INFO] [1564777723.201361528]: VER: 1.1: VID/PID: 26ac:0011
[ INFO] [1564777723.201527416]: VER: 1.1: UID: 3335510638343732
[ WARN] [1564777723.204398559]: CMD: Unexpected command 520, result 0
[ WARN] [1564777723.527365019]: TM : RTT too high for timesync: 11.17 ms.
[ WARN] [1564777724.149974523]: TM : RTT too high for timesync: 34.19 ms.
[ WARN] [1564777724.738090529]: TM : RTT too high for timesync: 22.04 ms.
[ WARN] [1564777725.379486330]: TM : RTT too high for timesync: 63.87 ms.
[ WARN] [1564777725.928656016]: TM : RTT too high for timesync: 12.08 ms.
[ WARN] [1564777726.528229138]: TM : RTT too high for timesync: 12.01 ms.
[ WARN] [1564777727.156721526]: TM : RTT too high for timesync: 40.19 ms.
[ WARN] [1564777727.738050643]: TM : RTT too high for timesync: 22.27 ms.
[ WARN] [1564777728.332099863]: TM : RTT too high for timesync: 15.87 ms.
[ WARN] [1564777728.933144007]: TM : RTT too high for timesync: 16.89 ms.
[ WARN] [1564777729.530796138]: TM : RTT too high for timesync: 15.25 ms.
[ WARN] [1564777730.154745805]: TM : RTT too high for timesync: 38.63 ms.
[ WARN] [1564777730.733345897]: TM : RTT too high for timesync: 17.19 ms.
[ WARN] [1564777731.330074658]: TM : RTT too high for timesync: 14.52 ms.
[ WARN] [1564777731.966062648]: TM : RTT too high for timesync: 49.84 ms.
[ INFO] [1564777732.139770927]: HP: requesting home position
[ WARN] [1564777733.026929053]: TM : RTT too high for timesync: 111.00 ms.
[ WARN] [1564777734.021552461]: TM : RTT too high for timesync: 105.67 ms.
[ WARN] [1564777735.031873464]: TM : RTT too high for timesync: 114.68 ms.
[ INFO] [1564777737.249826672]: WP: mission received
[ WARN] [1564777737.522706357]: TM : RTT too high for timesync: 106.21 ms.
[ WARN] [1564777738.145270151]: TM : RTT too high for timesync: 28.77 ms.
[ WARN] [1564777738.731590850]: TM : RTT too high for timesync: 15.96 ms.
[ WARN] [1564777739.042888617]: PR: request param #13 timeout, retries left 2, and 177 params still missing
[ WARN] [1564777739.330204517]: TM : RTT too high for timesync: 14.15 ms.
[ WARN] [1564777739.946897559]: TM : RTT too high for timesync: 31.09 ms.
[ WARN] [1564777740.536754090]: TM : RTT too high for timesync: 20.52 ms.
[ WARN] [1564777741.154421381]: TM : RTT too high for timesync: 38.48 ms.
[ WARN] [1564777741.727545304]: TM : RTT too high for timesync: 11.37 ms.
[ INFO] [1564777742.140364424]: HP: requesting home position
[ WARN] [1564777742.347694568]: TM : RTT too high for timesync: 32.05 ms.
[ WARN] [1564777742.934898580]: TM : RTT too high for timesync: 18.67 ms.
[ WARN] [1564777743.571477814]: TM : RTT too high for timesync: 55.63 ms.
[ WARN] [1564777744.147792904]: TM : RTT too high for timesync: 32.28 ms.
[ WARN] [1564777744.728674973]: TM : RTT too high for timesync: 12.50 ms.
[ WARN] [1564777745.327254738]: TM : RTT too high for timesync: 11.14 ms.
[ WARN] [1564777745.934633996]: TM : RTT too high for timesync: 18.28 ms.
[ WARN] [1564777746.541795979]: TM : RTT too high for timesync: 25.27 ms.
[ WARN] [1564777747.146358785]: TM : RTT too high for timesync: 30.10 ms.
[ WARN] [1564777747.726981656]: TM : RTT too high for timesync: 10.82 ms.
[ WARN] [1564777748.332054905]: TM : RTT too high for timesync: 15.06 ms.
[ WARN] [1564777748.935562149]: TM : RTT too high for timesync: 19.49 ms.
[ WARN] [1564777749.531848215]: TM : RTT too high for timesync: 15.40 ms.
[ WARN] [1564777750.181364973]: TM : RTT too high for timesync: 65.36 ms.
[ WARN] [1564777750.727390238]: TM : RTT too high for timesync: 10.99 ms.
[ WARN] [1564777751.095472874]: CMD: Unexpected command 176, result 0
[ WARN] [1564777751.328212739]: TM : RTT too high for timesync: 11.88 ms.
[ WARN] [1564777751.927529040]: TM : RTT too high for timesync: 11.30 ms.
[ INFO] [1564777752.139976950]: HP: requesting home position
[ WARN] [1564777752.532233389]: TM : RTT too high for timesync: 16.36 ms.
[ WARN] [1564777753.155866029]: TM : RTT too high for timesync: 39.79 ms.
[ WARN] [1564777753.734142181]: TM : RTT too high for timesync: 17.75 ms.
[ WARN] [1564777754.332607341]: TM : RTT too high for timesync: 16.62 ms.
[ WARN] [1564777754.927848392]: TM : RTT too high for timesync: 11.95 ms.
[ WARN] [1564777755.531788293]: TM : RTT too high for timesync: 15.51 ms.
[ WARN] [1564777756.146914958]: TM : RTT too high for timesync: 30.55 ms.
[ INFO] [1564777756.173599699]: FCU: ARMED by Arm/Disarm component command
[ INFO] [1564777756.637693602]: FCU: [logger] file: /fs/microsd/log/2019-08-02/20_06_2
[ WARN] [1564777756.778048364]: TM : RTT too high for timesync: 61.71 ms.
[ WARN] [1564777757.334000274]: TM : RTT too high for timesync: 16.45 ms.
[ WARN] [1564777757.928861761]: TM : RTT too high for timesync: 12.77 ms.
[ WARN] [1564777758.528735748]: TM : RTT too high for timesync: 12.30 ms.
[ WARN] [1564777759.154511837]: TM : RTT too high for timesync: 38.25 ms.
[ WARN] [1564777759.745152765]: TM : RTT too high for timesync: 28.81 ms.
[ WARN] [1564777760.331361619]: TM : RTT too high for timesync: 12.37 ms.
[ WARN] [1564777760.938155896]: TM : RTT too high for timesync: 22.30 ms.
[ WARN] [1564777761.221918763]: CMD: Unexpected command 176, result 0
[ WARN] [1564777761.532104007]: TM : RTT too high for timesync: 15.59 ms.
[ INFO] [1564777762.139514454]: HP: requesting home position
[ WARN] [1564777762.152448926]: TM : RTT too high for timesync: 36.21 ms.
[ WARN] [1564777762.737239105]: TM : RTT too high for timesync: 21.00 ms.
[ WARN] [1564777763.360307428]: TM : RTT too high for timesync: 42.71 ms.
[ WARN] [1564777763.973852601]: TM : RTT too high for timesync: 57.47 ms.
[ WARN] [1564777764.530050982]: TM : RTT too high for timesync: 14.20 ms.
[ WARN] [1564777765.145395639]: TM : RTT too high for timesync: 29.09 ms.
[ WARN] [1564777765.728605983]: TM : RTT too high for timesync: 12.59 ms.
[ WARN] [1564777766.335902680]: TM : RTT too high for timesync: 19.87 ms.
[ WARN] [1564777766.928646255]: TM : RTT too high for timesync: 12.81 ms.
[ WARN] [1564777767.528712243]: TM : RTT too high for timesync: 12.58 ms.
[ WARN] [1564777768.145697547]: TM : RTT too high for timesync: 29.59 ms.
[ WARN] [1564777768.738904571]: TM : RTT too high for timesync: 15.52 ms.
[ WARN] [1564777769.350098265]: TM : RTT too high for timesync: 32.85 ms.
[ WARN] [1564777769.955618332]: TM : RTT too high for timesync: 39.56 ms.
[ WARN] [1564777770.567320807]: TM : RTT too high for timesync: 50.91 ms.
[ WARN] [1564777771.145633059]: TM : RTT too high for timesync: 29.71 ms.
[ WARN] [1564777771.321845291]: CMD: Unexpected command 176, result 0
[ WARN] [1564777771.727419658]: TM : RTT too high for timesync: 11.87 ms.
[ INFO] [1564777772.141098803]: HP: requesting home position
[ WARN] [1564777772.329776893]: TM : RTT too high for timesync: 10.94 ms.
[ WARN] [1564777772.931911664]: TM : RTT too high for timesync: 15.46 ms.
[ WARN] [1564777773.534309102]: TM : RTT too high for timesync: 18.79 ms.
^C[imu_attitude_to_tf_node-11] killing on exit
[laser_broadcaster3-10] killing on exit
[mavros-6] killing on exit
[laser_broadcaster1-8] killing on exit
[laser_broadcaster2-9] killing on exit
[base_to_laser_broadcaster-5] killing on exit
[hector_mapping-4] killing on exit
[rplidarNode_v-3] killing on exit
[generate_topics-7] killing on exit
[rplidarNode-2] killing on exit
Debug: mavconn: serial0: recv: v2.0 OK Message-Id: 30 [28 bytes] IDs: 1.1 Seq: 219
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor…
… shutting down processing monitor complete
done
