I tried to make the laptop communicate with px4 via usb cable. I have installed the noetic version of ros and the corresponding mavros. i have completely updated all packages to the latest. But for some reason I can’t communicate properly using the default px4.launch. It always worked previously. I’ve forgotten when it started not communicating properly. Here is the log output from the terminal. what does this usually mean? It seems that it just can’t communicate with my laptop, but it can communicate with an arm board with the same settings.
SUMMARY
CLEAR PARAMETERS
 * /mavros/
PARAMETERS
 * /mavros/camera/frame_id: base_link
 * /mavros/cmd/use_comp_id_system_control: False
 * /mavros/conn/heartbeat_rate: 1.0
 * /mavros/conn/system_time_rate: 1.0
 * /mavros/conn/timeout: 10.0
 * /mavros/conn/timesync_rate: 10.0
 * /mavros/distance_sensor/hrlv_ez4_pub/field_of_view: 0.0
 * /mavros/distance_sensor/hrlv_ez4_pub/frame_id: hrlv_ez4_sonar
 * /mavros/distance_sensor/hrlv_ez4_pub/id: 0
 * /mavros/distance_sensor/hrlv_ez4_pub/orientation: PITCH_270
 * /mavros/distance_sensor/hrlv_ez4_pub/send_tf: True
 * /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/x: 0.0
 * /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/y: 0.0
 * /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/z: -0.1
 * /mavros/distance_sensor/laser_1_sub/id: 3
 * /mavros/distance_sensor/laser_1_sub/orientation: PITCH_270
 * /mavros/distance_sensor/laser_1_sub/subscriber: True
 * /mavros/distance_sensor/lidarlite_pub/field_of_view: 0.0
 * /mavros/distance_sensor/lidarlite_pub/frame_id: lidarlite_laser
 * /mavros/distance_sensor/lidarlite_pub/id: 1
 * /mavros/distance_sensor/lidarlite_pub/orientation: PITCH_270
 * /mavros/distance_sensor/lidarlite_pub/send_tf: True
 * /mavros/distance_sensor/lidarlite_pub/sensor_position/x: 0.0
 * /mavros/distance_sensor/lidarlite_pub/sensor_position/y: 0.0
 * /mavros/distance_sensor/lidarlite_pub/sensor_position/z: -0.1
 * /mavros/distance_sensor/sonar_1_sub/horizontal_fov_ratio: 1.0
 * /mavros/distance_sensor/sonar_1_sub/id: 2
 * /mavros/distance_sensor/sonar_1_sub/orientation: PITCH_270
 * /mavros/distance_sensor/sonar_1_sub/subscriber: True
 * /mavros/distance_sensor/sonar_1_sub/vertical_fov_ratio: 1.0
 * /mavros/fake_gps/eph: 2.0
 * /mavros/fake_gps/epv: 2.0
 * /mavros/fake_gps/fix_type: 3
 * /mavros/fake_gps/geo_origin/alt: 408.0
 * /mavros/fake_gps/geo_origin/lat: 47.3667
 * /mavros/fake_gps/geo_origin/lon: 8.55
 * /mavros/fake_gps/gps_rate: 5.0
 * /mavros/fake_gps/mocap_transform: True
 * /mavros/fake_gps/satellites_visible: 5
 * /mavros/fake_gps/tf/child_frame_id: fix
 * /mavros/fake_gps/tf/frame_id: map
 * /mavros/fake_gps/tf/listen: False
 * /mavros/fake_gps/tf/rate_limit: 10.0
 * /mavros/fake_gps/tf/send: False
 * /mavros/fake_gps/use_mocap: True
 * /mavros/fake_gps/use_vision: False
 * /mavros/fcu_protocol: v2.0
 * /mavros/fcu_url: /dev/ttyACM0:57600
 * /mavros/gcs_url:
 * /mavros/global_position/child_frame_id: base_link
 * /mavros/global_position/frame_id: map
 * /mavros/global_position/gps_uere: 1.0
 * /mavros/global_position/rot_covariance: 99999.0
 * /mavros/global_position/tf/child_frame_id: base_link
 * /mavros/global_position/tf/frame_id: map
 * /mavros/global_position/tf/global_frame_id: earth
 * /mavros/global_position/tf/send: False
 * /mavros/global_position/use_relative_alt: True
 * /mavros/image/frame_id: px4flow
 * /mavros/imu/angular_velocity_stdev: 0.0003490659 // 0...
 * /mavros/imu/frame_id: base_link
 * /mavros/imu/linear_acceleration_stdev: 0.0003
 * /mavros/imu/magnetic_stdev: 0.0
 * /mavros/imu/orientation_stdev: 1.0
 * /mavros/landing_target/camera/fov_x: 2.0071286398
 * /mavros/landing_target/camera/fov_y: 2.0071286398
 * /mavros/landing_target/image/height: 480
 * /mavros/landing_target/image/width: 640
 * /mavros/landing_target/land_target_type: VISION_FIDUCIAL
 * /mavros/landing_target/listen_lt: False
 * /mavros/landing_target/mav_frame: LOCAL_NED
 * /mavros/landing_target/target_size/x: 0.3
 * /mavros/landing_target/target_size/y: 0.3
 * /mavros/landing_target/tf/child_frame_id: camera_center
 * /mavros/landing_target/tf/frame_id: landing_target
 * /mavros/landing_target/tf/listen: False
 * /mavros/landing_target/tf/rate_limit: 10.0
 * /mavros/landing_target/tf/send: True
 * /mavros/local_position/frame_id: map
 * /mavros/local_position/tf/child_frame_id: base_link
 * /mavros/local_position/tf/frame_id: map
 * /mavros/local_position/tf/send: False
 * /mavros/local_position/tf/send_fcu: False
 * /mavros/mission/pull_after_gcs: True
 * /mavros/mission/use_mission_item_int: True
 * /mavros/mocap/use_pose: True
 * /mavros/mocap/use_tf: False
 * /mavros/odometry/fcu/odom_child_id_des: base_link
 * /mavros/odometry/fcu/odom_parent_id_des: map
 * /mavros/plugin_blacklist: ['safety_area', '...
 * /mavros/plugin_whitelist: []
 * /mavros/px4flow/frame_id: px4flow
 * /mavros/px4flow/ranger_fov: 0.118682
 * /mavros/px4flow/ranger_max_range: 5.0
 * /mavros/px4flow/ranger_min_range: 0.3
 * /mavros/safety_area/p1/x: 1.0
 * /mavros/safety_area/p1/y: 1.0
 * /mavros/safety_area/p1/z: 1.0
 * /mavros/safety_area/p2/x: -1.0
 * /mavros/safety_area/p2/y: -1.0
 * /mavros/safety_area/p2/z: -1.0
 * /mavros/setpoint_accel/send_force: False
 * /mavros/setpoint_attitude/reverse_thrust: False
 * /mavros/setpoint_attitude/tf/child_frame_id: target_attitude
 * /mavros/setpoint_attitude/tf/frame_id: map
 * /mavros/setpoint_attitude/tf/listen: False
 * /mavros/setpoint_attitude/tf/rate_limit: 50.0
 * /mavros/setpoint_attitude/use_quaternion: False
 * /mavros/setpoint_position/mav_frame: LOCAL_NED
 * /mavros/setpoint_position/tf/child_frame_id: target_position
 * /mavros/setpoint_position/tf/frame_id: map
 * /mavros/setpoint_position/tf/listen: False
 * /mavros/setpoint_position/tf/rate_limit: 50.0
 * /mavros/setpoint_raw/thrust_scaling: 1.0
 * /mavros/setpoint_velocity/mav_frame: LOCAL_NED
 * /mavros/startup_px4_usb_quirk: True
 * /mavros/sys/disable_diag: False
 * /mavros/sys/min_voltage: 10.0
 * /mavros/target_component_id: 1
 * /mavros/target_system_id: 1
 * /mavros/tdr_radio/low_rssi: 40
 * /mavros/time/time_ref_source: fcu
 * /mavros/time/timesync_avg_alpha: 0.6
 * /mavros/time/timesync_mode: MAVLINK
 * /mavros/vibration/frame_id: base_link
 * /mavros/vision_pose/tf/child_frame_id: vision_estimate
 * /mavros/vision_pose/tf/frame_id: odom
 * /mavros/vision_pose/tf/listen: False
 * /mavros/vision_pose/tf/rate_limit: 10.0
 * /mavros/vision_speed/listen_twist: True
 * /mavros/vision_speed/twist_cov: True
 * /mavros/wheel_odometry/child_frame_id: base_link
 * /mavros/wheel_odometry/count: 2
 * /mavros/wheel_odometry/frame_id: odom
 * /mavros/wheel_odometry/send_raw: True
 * /mavros/wheel_odometry/send_twist: False
 * /mavros/wheel_odometry/tf/child_frame_id: base_link
 * /mavros/wheel_odometry/tf/frame_id: odom
 * /mavros/wheel_odometry/tf/send: False
 * /mavros/wheel_odometry/use_rpm: False
 * /mavros/wheel_odometry/vel_error: 0.1
 * /mavros/wheel_odometry/wheel0/radius: 0.05
 * /mavros/wheel_odometry/wheel0/x: 0.0
 * /mavros/wheel_odometry/wheel0/y: -0.15
 * /mavros/wheel_odometry/wheel1/radius: 0.05
 * /mavros/wheel_odometry/wheel1/x: 0.0
 * /mavros/wheel_odometry/wheel1/y: 0.15
 * /rosdistro: noetic
 * /rosversion: 1.15.14
NODES
    mavros (mavros/mavros_node)
auto-starting new master
process[master]: started with pid [62261]
ROS_MASTER_URI=http://127.0.0.1:11311
setting /run_id to b7c287e4-e2a7-11ec-bb3d-09c176124d84
process[rosout-1]: started with pid [62286]
process[mavros-2]: started with pid [62294]
[ INFO] [1654197052.041470541]: FCU URL: /dev/ttyACM0:57600
[ INFO] [1654197052.044364974]: serial0: device: /dev/ttyACM0 @ 57600 bps
[ INFO] [1654197052.048685704]: GCS bridge disabled
[ INFO] [1654197052.059937623]: Plugin 3dr_radio loaded
[ INFO] [1654197052.063070493]: Plugin 3dr_radio initialized
[ INFO] [1654197052.063244957]: Plugin actuator_control loaded
[ INFO] [1654197052.071299123]: Plugin actuator_control initialized
[ INFO] [1654197052.076068374]: Plugin adsb loaded
[ INFO] [1654197052.083251061]: Plugin adsb initialized
[ INFO] [1654197052.083452902]: Plugin altitude loaded
[ INFO] [1654197052.085962090]: Plugin altitude initialized
[ INFO] [1654197052.086153595]: Plugin cam_imu_sync loaded
[ INFO] [1654197052.087586808]: Plugin cam_imu_sync initialized
[ INFO] [1654197052.087928262]: Plugin camera loaded
[ INFO] [1654197052.090023221]: Plugin camera initialized
[ INFO] [1654197052.090353500]: Plugin command loaded
[ INFO] [1654197052.105616543]: Plugin command initialized
[ INFO] [1654197052.105810492]: Plugin companion_process_status loaded
[ INFO] [1654197052.111192741]: Plugin companion_process_status initialized
[ INFO] [1654197052.111397306]: Plugin debug_value loaded
[ INFO] [1654197052.123093066]: Plugin debug_value initialized
[ INFO] [1654197052.123174711]: Plugin distance_sensor blacklisted
[ INFO] [1654197052.123349244]: Plugin esc_status loaded
[ INFO] [1654197052.125637454]: Plugin esc_status initialized
[ INFO] [1654197052.125816666]: Plugin esc_telemetry loaded
[ INFO] [1654197052.127007740]: Plugin esc_telemetry initialized
[ INFO] [1654197052.127238006]: Plugin fake_gps loaded
[ INFO] [1654197052.162457985]: Plugin fake_gps initialized
[ INFO] [1654197052.162687065]: Plugin ftp loaded
[ INFO] [1654197052.176517873]: Plugin ftp initialized
[ INFO] [1654197052.176713219]: Plugin geofence loaded
[ INFO] [1654197052.184406655]: Plugin geofence initialized
[ INFO] [1654197052.184621347]: Plugin global_position loaded
[ INFO] [1654197052.216332570]: Plugin global_position initialized
[ INFO] [1654197052.216672837]: Plugin gps_input loaded
[ INFO] [1654197052.224029009]: Plugin gps_input initialized
[ INFO] [1654197052.224235320]: Plugin gps_rtk loaded
[ INFO] [1654197052.229807956]: Plugin gps_rtk initialized
[ INFO] [1654197052.229956019]: Plugin gps_status loaded
[ INFO] [1654197052.233836610]: Plugin gps_status initialized
[ INFO] [1654197052.234038172]: Plugin hil loaded
[ INFO] [1654197052.263667357]: Plugin hil initialized
[ INFO] [1654197052.263901325]: Plugin home_position loaded
[ INFO] [1654197052.273269555]: Plugin home_position initialized
[ INFO] [1654197052.273550596]: Plugin imu loaded
[ INFO] [1654197052.289950935]: Plugin imu initialized
[ INFO] [1654197052.290206135]: Plugin landing_target loaded
[ INFO] [1654197052.321616133]: Plugin landing_target initialized
[ INFO] [1654197052.321845980]: Plugin local_position loaded
[ INFO] [1654197052.339042719]: Plugin local_position initialized
[ INFO] [1654197052.339296243]: Plugin log_transfer loaded
[ INFO] [1654197052.344903031]: Plugin log_transfer initialized
[ INFO] [1654197052.345118142]: Plugin mag_calibration_status loaded
[ INFO] [1654197052.347419761]: Plugin mag_calibration_status initialized
[ INFO] [1654197052.347663368]: Plugin manual_control loaded
[ INFO] [1654197052.354492587]: Plugin manual_control initialized
[ INFO] [1654197052.354706441]: Plugin mocap_pose_estimate loaded
[ INFO] [1654197052.362771503]: Plugin mocap_pose_estimate initialized
[ INFO] [1654197052.363005750]: Plugin mount_control loaded
[ INFO] [1654197052.373890025]: Plugin mount_control initialized
[ INFO] [1654197052.374109117]: Plugin nav_controller_output loaded
[ INFO] [1654197052.375518444]: Plugin nav_controller_output initialized
[ INFO] [1654197052.375719308]: Plugin obstacle_distance loaded
[ INFO] [1654197052.382228445]: Plugin obstacle_distance initialized
[ INFO] [1654197052.382483016]: Plugin odom loaded
[ INFO] [1654197052.392010484]: Plugin odom initialized
[ INFO] [1654197052.392212465]: Plugin onboard_computer_status loaded
[ INFO] [1654197052.398959622]: Plugin onboard_computer_status initialized
[ INFO] [1654197052.399209653]: Plugin param loaded
[ INFO] [1654197052.403719654]: Plugin param initialized
[ INFO] [1654197052.403918841]: Plugin play_tune loaded
[ INFO] [1654197052.409145553]: Plugin play_tune initialized
[ INFO] [1654197052.409336779]: Plugin px4flow loaded
[ INFO] [1654197052.422666126]: Plugin px4flow initialized
[ INFO] [1654197052.422906241]: Plugin rallypoint loaded
[ INFO] [1654197052.431334337]: Plugin rallypoint initialized
[ INFO] [1654197052.431449156]: Plugin rangefinder blacklisted
[ INFO] [1654197052.431588280]: Plugin rc_io loaded
[ INFO] [1654197052.438642179]: Plugin rc_io initialized
[ INFO] [1654197052.438814268]: Plugin safety_area blacklisted
[ INFO] [1654197052.439048516]: Plugin setpoint_accel loaded
[ INFO] [1654197052.445571551]: Plugin setpoint_accel initialized
[ INFO] [1654197052.445909234]: Plugin setpoint_attitude loaded
[ INFO] [1654197052.466252392]: Plugin setpoint_attitude initialized
[ INFO] [1654197052.466533433]: Plugin setpoint_position loaded
[ INFO] [1654197052.501632378]: Plugin setpoint_position initialized
[ INFO] [1654197052.501916841]: Plugin setpoint_raw loaded
[ INFO] [1654197052.521821536]: Plugin setpoint_raw initialized
[ INFO] [1654197052.522141688]: Plugin setpoint_trajectory loaded
[ INFO] [1654197052.534409379]: Plugin setpoint_trajectory initialized
[ INFO] [1654197052.534722617]: Plugin setpoint_velocity loaded
[ INFO] [1654197052.546738529]: Plugin setpoint_velocity initialized
[ INFO] [1654197052.547104987]: Plugin sys_status loaded
[ INFO] [1654197052.573723663]: Plugin sys_status initialized
[ INFO] [1654197052.574063022]: Plugin sys_time loaded
[ INFO] [1654197052.586605677]: TM: Timesync mode: MAVLINK
[ INFO] [1654197052.587671595]: TM: Not publishing sim time
[ INFO] [1654197052.590483335]: Plugin sys_time initialized
[ INFO] [1654197052.590766471]: Plugin terrain loaded
[ INFO] [1654197052.592087659]: Plugin terrain initialized
[ INFO] [1654197052.592381761]: Plugin trajectory loaded
[ INFO] [1654197052.604041203]: Plugin trajectory initialized
[ INFO] [1654197052.604343826]: Plugin tunnel loaded
[ INFO] [1654197052.611672411]: Plugin tunnel initialized
[ INFO] [1654197052.611967071]: Plugin vfr_hud loaded
[ INFO] [1654197052.613830785]: Plugin vfr_hud initialized
[ INFO] [1654197052.614172030]: Plugin vibration blacklisted
[ INFO] [1654197052.614454887]: Plugin vision_pose_estimate loaded
[ INFO] [1654197052.632665931]: Plugin vision_pose_estimate initialized
[ INFO] [1654197052.632898153]: Plugin vision_speed_estimate loaded
[ INFO] [1654197052.642073341]: Plugin vision_speed_estimate initialized
[ INFO] [1654197052.642360808]: Plugin waypoint loaded
[ INFO] [1654197052.654269026]: Plugin waypoint initialized
[ INFO] [1654197052.654367362]: Plugin wheel_odometry blacklisted
[ INFO] [1654197052.654618651]: Plugin wind_estimation loaded
[ INFO] [1654197052.656031121]: Plugin wind_estimation initialized
[ INFO] [1654197052.656391083]: Autostarting mavlink via USB on PX4
[ INFO] [1654197052.656591458]: Built-in SIMD instructions: SSE, SSE2
[ INFO] [1654197052.656740848]: Built-in MAVLink package version: 2022.3.3
[ INFO] [1654197052.656862442]: Known MAVLink dialects: common ardupilotmega ASLUAV AVSSUAS all development icarous matrixpilot paparazzi standard storm32 uAvionix ualberta
[ INFO] [1654197052.657015813]: MAVROS started. MY ID 1.240, TARGET ID 1.1
[ERROR] [1654197137.191113433]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197137.290967465]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197137.390812208]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197137.491030043]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197137.554533435]: 0: DROPPED Message HEARTBEAT: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197137.590934849]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197137.591280005]: 0: DROPPED Message SYSTEM_TIME: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197137.690773725]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197137.790762690]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197137.890736081]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197137.990621890]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197138.090794119]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197138.190663236]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197138.290745928]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197138.390944417]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197138.490759757]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197138.554622063]: 0: DROPPED Message HEARTBEAT: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197138.590743414]: 0: DROPPED Message SYSTEM_TIME: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197138.591071598]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197138.690799497]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197138.790984646]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197138.891357598]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197138.990769814]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197139.090969141]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197139.190988766]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197139.290980944]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197139.391085706]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197139.490805223]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197139.554563816]: 0: DROPPED Message HEARTBEAT: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197139.590753331]: 0: DROPPED Message SYSTEM_TIME: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197139.591123630]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197139.690752563]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197139.790746347]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197139.890768836]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197139.990774423]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197140.090756195]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197140.190958246]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
[ERROR] [1654197140.290753052]: 0: DROPPED Message TIMESYNC: MAVConnSerial::send_message: TX queue overflow
^C[mavros-2] killing on exit
