I’m trying to run avoidance local_planner simulation.
Not able to arm because “Avoidance system timed out” errors appeared.
Also a lot of other errors printed.
I’m using ubuntu 16.4 , PX4 - version 1.9.2 , avoidance - latest master.
Here is terminal output:
evgeny@quad:~/catkin_ws$ roslaunch local_planner local_planner_stereo.launch
… logging to /home/evgeny/.ros/log/ca0bb740-d157-11e9-a458-5cea1dc619f5/roslaunch-quad-17561.log
Checking log directory for disk usage. This may take awhile.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://quad:34395/
SUMMARY
CLEAR PARAMETERS
- /mavros/
PARAMETERS
- /local_planner_node/goal_x_param: 15
- /local_planner_node/goal_y_param: 15
- /local_planner_node/goal_z_param: 4
- /local_planner_node/pointcloud_topics: [‘/stereo/points2’]
- /local_planner_node/world_name: /home/evgeny/catk…
- /mavros/cmd/use_comp_id_system_control: False
- /mavros/conn/heartbeat_rate: 1.0
- /mavros/conn/system_time_rate: 1.0
- /mavros/conn/timeout: 10.0
- /mavros/conn/timesync_rate: 10.0
- /mavros/distance_sensor/hrlv_ez4_pub/field_of_view: 0.0
- /mavros/distance_sensor/hrlv_ez4_pub/frame_id: hrlv_ez4_sonar
- /mavros/distance_sensor/hrlv_ez4_pub/id: 0
- /mavros/distance_sensor/hrlv_ez4_pub/orientation: ROLL_180
- /mavros/distance_sensor/hrlv_ez4_pub/send_tf: True
- /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/x: 0.0
- /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/y: 0.0
- /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/z: -0.1
- /mavros/distance_sensor/laser_1_sub/id: 3
- /mavros/distance_sensor/laser_1_sub/orientation: ROLL_180
- /mavros/distance_sensor/laser_1_sub/subscriber: True
- /mavros/distance_sensor/lidarlite_pub/field_of_view: 0.0
- /mavros/distance_sensor/lidarlite_pub/frame_id: lidarlite_laser
- /mavros/distance_sensor/lidarlite_pub/id: 1
- /mavros/distance_sensor/lidarlite_pub/orientation: ROLL_180
- /mavros/distance_sensor/lidarlite_pub/send_tf: True
- /mavros/distance_sensor/lidarlite_pub/sensor_position/x: 0.0
- /mavros/distance_sensor/lidarlite_pub/sensor_position/y: 0.0
- /mavros/distance_sensor/lidarlite_pub/sensor_position/z: -0.1
- /mavros/distance_sensor/sonar_1_sub/id: 2
- /mavros/distance_sensor/sonar_1_sub/orientation: ROLL_180
- /mavros/distance_sensor/sonar_1_sub/subscriber: True
- /mavros/fcu_protocol: v2.0
- /mavros/fcu_url: udp://:14540@loca…
- /mavros/gcs_url:
- /mavros/global_position/frame_id: fcu
- /mavros/global_position/rot_covariance: 99999.0
- /mavros/global_position/tf/child_frame_id: fcu_utm
- /mavros/global_position/tf/frame_id: local_origin
- /mavros/global_position/tf/send: False
- /mavros/image/frame_id: px4flow
- /mavros/imu/angular_velocity_stdev: 0.000349065850399
- /mavros/imu/frame_id: fcu
- /mavros/imu/linear_acceleration_stdev: 0.0003
- /mavros/imu/magnetic_stdev: 0.0
- /mavros/imu/orientation_stdev: 1.0
- /mavros/local_position/frame_id: local_origin
- /mavros/local_position/tf/child_frame_id: fcu
- /mavros/local_position/tf/frame_id: local_origin
- /mavros/local_position/tf/send: True
- /mavros/local_position/tf/send_fcu: False
- /mavros/mission/pull_after_gcs: True
- /mavros/mocap/use_pose: False
- /mavros/mocap/use_tf: True
- /mavros/plugin_blacklist: [‘safety_area’, '…
- /mavros/plugin_whitelist:
- /mavros/px4flow/frame_id: px4flow
- /mavros/px4flow/ranger_fov: 0.0
- /mavros/px4flow/ranger_max_range: 5.0
- /mavros/px4flow/ranger_min_range: 0.3
- /mavros/safety_area/p1/x: 1.0
- /mavros/safety_area/p1/y: 1.0
- /mavros/safety_area/p1/z: 1.0
- /mavros/safety_area/p2/x: -1.0
- /mavros/safety_area/p2/y: -1.0
- /mavros/safety_area/p2/z: -1.0
- /mavros/setpoint_accel/send_force: False
- /mavros/setpoint_attitude/reverse_throttle: False
- /mavros/setpoint_attitude/tf/child_frame_id: attitude
- /mavros/setpoint_attitude/tf/frame_id: local_origin
- /mavros/setpoint_attitude/tf/listen: False
- /mavros/setpoint_attitude/tf/rate_limit: 10.0
- /mavros/setpoint_position/tf/child_frame_id: setpoint
- /mavros/setpoint_position/tf/frame_id: local_origin
- /mavros/setpoint_position/tf/listen: False
- /mavros/setpoint_position/tf/rate_limit: 50.0
- /mavros/startup_px4_usb_quirk: True
- /mavros/sys/disable_diag: False
- /mavros/sys/min_voltage: 10.0
- /mavros/target_component_id: 1
- /mavros/target_system_id: 1
- /mavros/tdr_radio/low_rssi: 40
- /mavros/time/time_ref_source: fcu
- /mavros/time/timesync_avg_alpha: 0.6
- /mavros/vibration/frame_id: vibration
- /mavros/vision_pose/tf/child_frame_id: vision
- /mavros/vision_pose/tf/frame_id: local_origin
- /mavros/vision_pose/tf/listen: False
- /mavros/vision_pose/tf/rate_limit: 10.0
- /mavros/vision_speed/listen_twist: False
- /rosdistro: kinetic
- /rosversion: 1.12.14
- /stereo/stereo_image_proc/correlation_window_size: 19.0
- /stereo/stereo_image_proc/disparity_range: 32.0
- /stereo/stereo_image_proc/speckle_range: 2.0
- /stereo/stereo_image_proc/speckle_size: 1000.0
- /stereo/stereo_image_proc/stereo_algorithm: 1.0
- /stereo/stereo_image_proc/uniqueness_ratio: 40.0
- /use_sim_time: True
NODES
/stereo/
stereo_image_proc (stereo_image_proc/stereo_image_proc)
gazebo (gazebo_ros/gzserver)
local_planner_node (local_planner/local_planner_node)
mavros (mavros/mavros_node)
rqt_reconfigure (rqt_reconfigure/rqt_reconfigure)
rviz (rviz/rviz)
sitl_0 (px4/px4)
spawn_model (gazebo_ros/spawn_model)
tf_depth_camera (tf/static_transform_publisher)
auto-starting new master
process[master]: started with pid [17572]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to ca0bb740-d157-11e9-a458-5cea1dc619f5
process[rosout-1]: started with pid [17586]
process[tf_depth_camera-2]: started with pid [17590]
process[rqt_reconfigure-3]: started with pid [17591]
process[sitl_0-4]: started with pid [17644]
INFO [px4] Creating symlink /home/evgeny/Firmware/ROMFS/px4fmu_common → /home/evgeny/.ros/etc
0 WARNING: setRealtimeSched failed (not run as root?)
| ___ \ \ \ / / / |
| |/ / \ V / / /| |
| __/ / \ / /| |
| | / /^\ \ ___ |
_| / / |_/
px4 starting.
process[mavros-5]: started with pid [17660]
process[gazebo-6]: started with pid [17665]
process[spawn_model-7]: started with pid [17680]
process[stereo/stereo_image_proc-8]: started with pid [17696]
process[local_planner_node-9]: started with pid [17700]
INFO [dataman] Unknown restart, data manager file ‘./dataman’ size is 11798680 bytes
INFO [simulator] Waiting for simulator to connect on TCP port 4560
process[rviz-10]: started with pid [17735]
[ INFO] [1567851064.352348257]: FCU URL: udp://:14540@localhost:14557
[ INFO] [1567851064.364184203]: udp0: Bind address: 0.0.0.0:14540
[ INFO] [1567851064.364458154]: udp0: Remote address: 127.0.0.1:14557
[ INFO] [1567851064.364924211]: GCS bridge disabled
[ INFO] [1567851064.592313675]: rviz version 1.12.17
[ INFO] [1567851064.592386912]: compiled against Qt version 5.5.1
[ INFO] [1567851064.592412004]: compiled against OGRE version 1.9.0 (Ghadamon)
[ INFO] [1567851064.657310648]: Plugin 3dr_radio loaded
[ INFO] [1567851064.663939878]: Plugin 3dr_radio initialized
[ INFO] [1567851064.664268594]: Plugin actuator_control loaded
[ INFO] [1567851064.683718755]: Plugin actuator_control initialized
[ INFO] [1567851064.872879658]: Plugin adsb loaded
[ INFO] [1567851064.920871154]: Plugin adsb initialized
[ INFO] [1567851064.921463435]: Plugin altitude loaded
[ INFO] [1567851064.928452020]: Plugin altitude initialized
[ INFO] [1567851064.928967837]: Plugin cam_imu_sync loaded
[ INFO] [1567851064.933446880]: Plugin cam_imu_sync initialized
[ INFO] [1567851064.934096295]: Plugin command loaded
[ INFO] [1567851064.975862998]: Plugin command initialized
[ INFO] [1567851064.976384140]: Plugin companion_process_status loaded
[ INFO] [1567851065.004107375]: Plugin companion_process_status initialized
[ INFO] [1567851065.004574670]: Plugin debug_value loaded
[ INFO] [1567851065.038759809]: Plugin debug_value initialized
[ INFO] [1567851065.039059559]: Plugin distance_sensor blacklisted
[ INFO] [1567851065.039938663]: Plugin fake_gps loaded
[ INFO] [1567851065.131431862]: Plugin fake_gps initialized
[ INFO] [1567851065.131809266]: Plugin ftp loaded
[ INFO] [1567851065.198028053]: Plugin ftp initialized
[ INFO] [1567851065.198398521]: Plugin global_position loaded
[ INFO] [1567851065.231246968]: Plugin global_position initialized
[ INFO] [1567851065.231500377]: Plugin gps_rtk loaded
[ INFO] [1567851065.235793744]: Plugin gps_rtk initialized
[ INFO] [1567851065.236073438]: Plugin hil loaded
[ INFO] [1567851065.264960313]: Plugin hil initialized
[ INFO] [1567851065.265404169]: Plugin home_position loaded
[ INFO] [1567851065.276805920]: Plugin home_position initialized
[ INFO] [1567851065.277341535]: Plugin imu loaded
[ INFO] [1567851065.296800054]: Plugin imu initialized
[ INFO] [1567851065.297077853]: Plugin landing_target loaded
[ INFO] [1567851065.315137171]: Plugin landing_target initialized
[ INFO] [1567851065.315550641]: Plugin local_position loaded
[ INFO] [1567851065.331678940]: Plugin local_position initialized
[ INFO] [1567851065.331940807]: Plugin log_transfer loaded
[ INFO] [1567851065.339321419]: Plugin log_transfer initialized
[ INFO] [1567851065.339605476]: Plugin manual_control loaded
[ INFO] [1567851065.347589407]: Plugin manual_control initialized
[ INFO] [1567851065.347873668]: Plugin mocap_pose_estimate loaded
[ INFO] [1567851065.357613948]: Plugin mocap_pose_estimate initialized
[ INFO] [1567851065.358211595]: Plugin mount_control loaded
[ INFO] [1567851065.362718314]: Plugin mount_control initialized
[ INFO] [1567851065.362972499]: Plugin obstacle_distance loaded
[ INFO] [1567851065.373361991]: Plugin obstacle_distance initialized
[ INFO] [1567851065.373724403]: Plugin odom loaded
[ INFO] [1567851065.401146751]: Plugin odom initialized
[ INFO] [1567851065.401722514]: Plugin param loaded
[ INFO] [1567851065.415691711]: Plugin param initialized
[ INFO] [1567851065.415995561]: Plugin px4flow loaded
[ INFO] [1567851065.442691155]: Plugin px4flow initialized
[ INFO] [1567851065.442760923]: Plugin rangefinder blacklisted
[ INFO] [1567851065.443144755]: Plugin rc_io loaded
[ INFO] [1567851065.461718912]: Plugin rc_io initialized
[ INFO] [1567851065.461907712]: Plugin safety_area blacklisted
[ INFO] [1567851065.462235625]: Plugin setpoint_accel loaded
[ INFO] [1567851065.477559401]: Plugin setpoint_accel initialized
[ INFO] [1567851065.477983177]: Plugin setpoint_attitude loaded
[ INFO] [1567851065.547549231]: Plugin setpoint_attitude initialized
[ INFO] [1567851065.547899805]: Plugin setpoint_position loaded
[ INFO] [1567851065.572105217]: Plugin setpoint_position initialized
[ INFO] [1567851065.572404243]: Plugin setpoint_raw loaded
[ INFO] [1567851065.588684637]: Plugin setpoint_raw initialized
[ INFO] [1567851065.588988463]: Plugin setpoint_velocity loaded
[ INFO] [1567851065.608348566]: Plugin setpoint_velocity initialized
[ INFO] [1567851065.609009623]: Plugin sys_status loaded
[ INFO] [1567851065.634622287]: Plugin sys_status initialized
[ INFO] [1567851065.635147758]: Plugin sys_time loaded
[ INFO] [1567851065.652359951]: TM: Timesync mode: MAVLINK
[ INFO] [1567851065.655065444]: Plugin sys_time initialized
[ INFO] [1567851065.655433536]: Plugin trajectory loaded
libGL error: failed to create drawable
[ INFO] [1567851065.679846868]: Plugin trajectory initialized
[ INFO] [1567851065.680248519]: Plugin vfr_hud loaded
[ INFO] [1567851065.682703354]: Plugin vfr_hud initialized
[ INFO] [1567851065.682776043]: Plugin vibration blacklisted
[ INFO] [1567851065.683067844]: Plugin vision_pose_estimate loaded
[ INFO] [1567851065.699389999]: Plugin vision_pose_estimate initialized
[ INFO] [1567851065.699731696]: Plugin vision_speed_estimate loaded
[ INFO] [1567851065.710028549]: Plugin vision_speed_estimate initialized
[ INFO] [1567851065.710340427]: Plugin waypoint loaded
[ INFO] [1567851065.735082952]: Plugin waypoint initialized
[ INFO] [1567851065.735155094]: Plugin wheel_odometry blacklisted
[ INFO] [1567851065.735508170]: Plugin wind_estimation loaded
[ INFO] [1567851065.737573351]: Plugin wind_estimation initialized
[ INFO] [1567851065.737682489]: Autostarting mavlink via USB on PX4
[ INFO] [1567851065.737888289]: Built-in SIMD instructions: SSE, SSE2
[ INFO] [1567851065.737920505]: Built-in MAVLink package version: 2019.8.8
[ INFO] [1567851065.737948218]: Known MAVLink dialects: common ardupilotmega ASLUAV autoquad icarous matrixpilot paparazzi slugs standard uAvionix ualberta
[ INFO] [1567851065.737976487]: MAVROS started. MY ID 1.240, TARGET ID 1.1
[ INFO] [1567851065.748716115]: Stereo is NOT SUPPORTED
[ INFO] [1567851065.748844298]: OpenGl version: 3 (GLSL 1.3).
SpawnModel script started
[ INFO] [1567851066.220412195]: Finished loading Gazebo ROS API Plugin.
[INFO] [1567851066.221445, 0.000000]: Loading model XML from Gazebo Model Database
[INFO] [1567851066.221999, 0.000000]: Waiting for service /gazebo/spawn_sdf_model
[ INFO] [1567851066.224235414]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting…
[INFO] [1567851067.747262, 0.000000]: Calling service /gazebo/spawn_sdf_model
[INFO] [1567851068.043401, 0.004000]: Spawn status: SpawnModel: Successfully spawned entity
[spawn_model-7] process has finished cleanly
log file: /home/evgeny/.ros/log/ca0bb740-d157-11e9-a458-5cea1dc619f5/spawn_model-7*.log
[ INFO] [1567851068.385068283, 0.004000000]: Camera Plugin: The ‘robotNamespace’ param did not exit
[ INFO] [1567851068.385328071, 0.004000000]: Camera Plugin: The ‘robotNamespace’ param did not exit
[ INFO] [1567851068.392105858, 0.004000000]: Camera Plugin (ns = ) <tf_prefix_>, set to “”
[ INFO] [1567851068.392888125, 0.004000000]: Camera Plugin (ns = ) <tf_prefix_>, set to “”
[ERROR] [1567851068.461611466]: PR: Unknown parameter to get: MPC_XY_CRUISE
[ERROR] [1567851068.464255790]: PR: Unknown parameter to get: MPC_COL_PREV_D
[ERROR] [1567851068.466742349]: PR: Unknown parameter to get: MPC_LAND_SPEED
[ERROR] [1567851068.469113857]: PR: Unknown parameter to get: NAV_ACC_RAD
INFO [simulator] Simulator connected on TCP port 4560.
[ INFO] [1567851069.228697312, 0.024000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1567851069.298450517, 0.092000000]: Physics dynamic reconfigure ready.
INFO [init] Mixer: etc/mixers/quad_w.main.mix on /dev/pwm_output0
INFO [mavlink] mode: Normal, data rate: 4000000 B/s on udp port 14570 remote port 14550
INFO [mavlink] mode: Onboard, data rate: 4000000 B/s on udp port 14558 remote port 14541
INFO [logger] Opened full log file: ./log/2019-09-07/10_11_10.ulg
INFO [mavlink] MAVLink only on localhost (set param MAV_BROADCAST = 1 to enable network)
[ INFO] [1567851070.511507511, 1.268000000]: udp0: Remote address: 127.0.0.1:14580
[ INFO] [1567851070.517216200, 1.272000000]: IMU: High resolution IMU detected!
INFO [mavlink] partner IP: 127.0.0.1
[ INFO] [1567851070.761920479, 1.512000000]: FCU: [logger] file: ./log/2019-09-07/10_11_10.ulg
[ INFO] [1567851070.813644077, 1.564000000]: FCU: Avoidance system starting
INFO [ecl/EKF] EKF aligned, (pressure height, IMU buf: 22, OBS buf: 14)
[ INFO] [1567851071.350490883, 2.000000000]: Successfully loaded rviz world
[ INFO] [1567851071.469387346, 2.120000000]: IMU: Attitude quaternion IMU detected!
[ INFO] [1567851071.562545680, 2.212000000]: CON: Got HEARTBEAT, connected. FCU: PX4 Autopilot
[ INFO] [1567851071.569920510, 2.220000000]: FCU: Avoidance system connected
[ INFO] [1567851071.571477070, 2.224000000]: IMU: Attitude quaternion IMU detected!
[ INFO] [1567851071.580547746, 2.232000000]: IMU: High resolution IMU detected!
[ WARN] [1567851072.370427908, 3.004000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.374939514, 3.008000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.378288400, 3.012000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.382945189, 3.016000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.390799619, 3.020000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.394162083, 3.024000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.398739274, 3.028000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.403747864, 3.032000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.406901215, 3.036000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.411286666, 3.040000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.415714006, 3.044000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.420128946, 3.048000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.423743742, 3.052000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.428292407, 3.056000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.431630809, 3.060000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.435868085, 3.064000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.440321589, 3.068000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.444707027, 3.072000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.447997724, 3.076000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.451494179, 3.080000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.455884714, 3.084000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.460275788, 3.088000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.463607443, 3.092000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.467966169, 3.096000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.475252416, 3.100000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.479045509, 3.104000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.483350879, 3.108000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.487126076, 3.112000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.491870471, 3.116000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.495344837, 3.120000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.499685023, 3.124000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.503070593, 3.128000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.507464289, 3.132000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.511930421, 3.136000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.517189431, 3.140000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.521694967, 3.144000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.525068874, 3.148000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.529483160, 3.152000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.533884993, 3.156000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.537322626, 3.160000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.544329024, 3.164000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.547201400, 3.168000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.554164934, 3.172000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.556501134, 3.176000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.559794391, 3.180000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.564590191, 3.184000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.569334439, 3.188000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.572879894, 3.192000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.576474335, 3.196000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.581356555, 3.200000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.584004720, 3.204000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.588365589, 3.208000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.592965213, 3.212000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.596788592, 3.216000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ INFO] [1567851072.600750577, 3.216000000]: VER: 1.1: Capabilities 0x000000000000e4ef
[ INFO] [1567851072.600929446, 3.216000000]: VER: 1.1: Flight software: 010902ff (106905871d000000)
[ INFO] [1567851072.600994285, 3.216000000]: VER: 1.1: Middleware software: 010902ff (106905871d000000)
[ INFO] [1567851072.601047602, 3.216000000]: VER: 1.1: OS software: 040f00ff (423371c7d4012e72)
[ INFO] [1567851072.601194610, 3.216000000]: VER: 1.1: Board hardware: 00000001
[ INFO] [1567851072.601278630, 3.216000000]: VER: 1.1: VID/PID: 0000:0000
[ INFO] [1567851072.601347697, 3.216000000]: VER: 1.1: UID: 4954414c44494e4f
[ WARN] [1567851072.604568829, 3.220000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.606960092, 3.224000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.611514792, 3.228000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.616524699, 3.232000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.618975570, 3.236000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.628395323, 3.240000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.631910574, 3.244000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.637550393, 3.248000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.641306154, 3.252000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.648403956, 3.256000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.651744431, 3.260000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.655110214, 3.264000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.659504822, 3.268000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.663097699, 3.272000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.667716133, 3.276000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.671455651, 3.280000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.675778249, 3.284000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.684580829, 3.288000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.685879040, 3.292000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.689284655, 3.296000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.691694310, 3.300000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.696122918, 3.304000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.702243186, 3.308000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.705688344, 3.312000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.712191410, 3.316000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.714439546, 3.320000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.718785959, 3.324000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.722263024, 3.328000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.726990119, 3.332000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ WARN] [1567851072.732080419, 3.336000000]: TF Buffer: could not retrieve requested transform from buffer, tf has already been dropped from buffer
[ERROR] [1567851073.471948840, 3.892000000]: PR: Unknown parameter to get: MPC_XY_CRUISE
[ERROR] [1567851073.474928768, 3.896000000]: PR: Unknown parameter to get: MPC_COL_PREV_D
[ERROR] [1567851073.478361695, 3.896000000]: PR: Unknown parameter to get: MPC_LAND_SPEED
[ERROR] [1567851073.481177397, 3.900000000]: PR: Unknown parameter to get: NAV_ACC_RAD
[ INFO] [1567851075.578200044, 5.612000000]: FCU: Avoidance system timed out
[ INFO] [1567851077.438436083, 6.804000000]: FCU: Avoidance system connected
[ERROR] [1567851078.484804827, 7.392000000]: PR: Unknown parameter to get: MPC_XY_CRUISE
[ERROR] [1567851078.491302828, 7.400000000]: PR: Unknown parameter to get: MPC_COL_PREV_D
[ERROR] [1567851078.508250879, 7.408000000]: PR: Unknown parameter to get: MPC_LAND_SPEED
[ INFO] [1567851078.519628810, 7.416000000]: FCU: Avoidance system timed out
[ERROR] [1567851078.519718597, 7.416000000]: PR: Unknown parameter to get: NAV_ACC_RAD
[ INFO] [1567851080.109830974, 8.208000000]: FCU: Avoidance system connected
[ INFO] [1567851080.801876353, 8.600000000]: FCU: Avoidance system timed out
[ INFO] [1567851082.688711846, 9.808000000]: FCU: Avoidance system connected
[ INFO] [1567851083.276907074, 10.216000000]: FCU: Avoidance system timed out
[ERROR] [1567851083.543886663, 10.400000000]: PR: Unknown parameter to get: MPC_XY_CRUISE
[ERROR] [1567851083.546944887, 10.400000000]: PR: Unknown parameter to get: MPC_COL_PREV_D
[ERROR] [1567851083.555888323, 10.404000000]: PR: Unknown parameter to get: MPC_LAND_SPEED
[ERROR] [1567851083.558924893, 10.404000000]: PR: Unknown parameter to get: NAV_ACC_RAD
INFO [ecl/EKF] EKF GPS checks passed (WGS-84 origin set)
INFO [ecl/EKF] EKF commencing GPS fusion
[ INFO] [1567851085.071548768, 11.408000000]: FCU: Avoidance system connected
[ INFO] [1567851085.658873480, 11.808000000]: FCU: Avoidance system timed out
[ INFO] [1567851087.402777592, 12.804000000]: FCU: Avoidance system connected
[ INFO] [1567851088.406991927, 13.408000000]: FCU: Avoidance system timed out
[ INFO] [1567851089.997085232, 14.412000000]: FCU: Avoidance system connected
[ INFO] [1567851090.594814377, 14.808000000]: FCU: Avoidance system timed out
[ INFO] [1567851092.159430136, 15.808000000]: FCU: Avoidance system connected
[ INFO] [1567851093.094922164, 16.404000000]: FCU: Avoidance system timed out
