External Position Estimation from Lidar
I am using pixhawk 4 with px4 verison 1.15.2 , onboard computer jetson nano and Livox mid 360 Lidar trying to use different slam algorithm such as google-cartographer , LTAOM , FAST-LIVO2 etc. But I dont know how to fuse external position from Livox mid 360 to Pixhawark. I read following discussion on external position with PX4 they say change the parameter EKF2_AID_MASK from 0 to 24 for external postion fuse to EKF2 but I dont’ find EKF2_AID_MASK in my parameter list I share my parameter list below
# Onboard parameters for Vehicle 1
# Stack: PX4 Pro
# Vehicle: Unknown
# Version: 1.15.2
# Git Revision: 4817c0618a000000
# Vehicle-Id Component-Id Name Value Type
ASPD_SCALE_1	1.000000000000000000	9
ATT_EN	0	6
BAT1_A_PER_V	36.367515563964843750	9
BAT1_CAPACITY	-1.000000000000000000	9
BAT1_I_CHANNEL	-1	6
BAT1_N_CELLS	0	6
BAT1_R_INTERNAL	0.004999999888241291	9
BAT1_SOURCE	0	6
BAT1_V_CHANNEL	-1	6
BAT1_V_CHARGED	4.050000190734863281	9
BAT1_V_DIV	18.100000381469726563	9
BAT1_V_EMPTY	3.599999904632568359	9
BAT1_V_LOAD_DROP	0.100000001490116119	9
BAT2_A_PER_V	36.367515563964843750	9
BAT2_CAPACITY	-1.000000000000000000	9
BAT2_I_CHANNEL	-1	6
BAT2_N_CELLS	0	6
BAT2_R_INTERNAL	0.004999999888241291	9
BAT2_SOURCE	-1	6
BAT2_V_CHANNEL	-1	6
BAT2_V_CHARGED	4.050000190734863281	9
BAT2_V_DIV	18.100000381469726563	9
BAT2_V_EMPTY	3.599999904632568359	9
BAT2_V_LOAD_DROP	0.100000001490116119	9
BATMON_DRIVER_EN	0	6
BAT_AVRG_CURRENT	15.000000000000000000	9
BAT_CRIT_THR	0.070000000298023224	9
BAT_EMERGEN_THR	0.050000000745058060	9
BAT_LOW_THR	0.150000005960464478	9
BAT_N_CELLS	3	6
BAT_V_CHARGED	4.050000190734863281	9
BAT_V_EMPTY	3.599999904632568359	9
BAT_V_LOAD_DROP	0.300000011920928955	9
BAT_V_OFFS_CURR	0.000000000000000000	9
CAL_ACC0_ID	3670026	6
CAL_ACC0_PRIO	50	6
CAL_ACC0_ROT	-1	6
CAL_ACC0_XOFF	0.135726585984230042	9
CAL_ACC0_XSCALE	1.000000000000000000	9
CAL_ACC0_YOFF	0.084648445248603821	9
CAL_ACC0_YSCALE	1.000000000000000000	9
CAL_ACC0_ZOFF	-0.074879199266433716	9
CAL_ACC0_ZSCALE	1.000000000000000000	9
CAL_ACC1_ID	3932170	6
CAL_ACC1_PRIO	50	6
CAL_ACC1_ROT	-1	6
CAL_ACC1_XOFF	0.137242138385772705	9
CAL_ACC1_XSCALE	1.000000000000000000	9
CAL_ACC1_YOFF	0.057041298598051071	9
CAL_ACC1_YSCALE	1.000000000000000000	9
CAL_ACC1_ZOFF	-0.305777311325073242	9
CAL_ACC1_ZSCALE	1.000000000000000000	9
CAL_ACC2_ID	0	6
CAL_ACC3_ID	0	6
CAL_AIR_CMODEL	0	6
CAL_AIR_TUBED_MM	1.500000000000000000	9
CAL_AIR_TUBELEN	0.200000002980232239	9
CAL_BARO0_ID	0	6
CAL_BARO1_ID	0	6
CAL_BARO2_ID	0	6
CAL_BARO3_ID	0	6
CAL_GYRO0_ID	3670026	6
CAL_GYRO0_PRIO	50	6
CAL_GYRO0_ROT	-1	6
CAL_GYRO0_XOFF	-0.009095278568565845	9
CAL_GYRO0_YOFF	0.011445863172411919	9
CAL_GYRO0_ZOFF	-0.001311208936385810	9
CAL_GYRO1_ID	3932170	6
CAL_GYRO1_PRIO	50	6
CAL_GYRO1_ROT	-1	6
CAL_GYRO1_XOFF	0.045027516782283783	9
CAL_GYRO1_YOFF	0.006419423501938581	9
CAL_GYRO1_ZOFF	0.009728308767080307	9
CAL_GYRO2_ID	0	6
CAL_GYRO3_ID	0	6
CAL_MAG0_ID	396825	6
CAL_MAG0_PITCH	0.000000000000000000	9
CAL_MAG0_PRIO	50	6
CAL_MAG0_ROLL	0.000000000000000000	9
CAL_MAG0_ROT	-1	6
CAL_MAG0_XCOMP	0.000000000000000000	9
CAL_MAG0_XODIAG	0.000000000000000000	9
CAL_MAG0_XOFF	0.038125377148389816	9
CAL_MAG0_XSCALE	1.000000000000000000	9
CAL_MAG0_YAW	0.000000000000000000	9
CAL_MAG0_YCOMP	0.000000000000000000	9
CAL_MAG0_YODIAG	0.000000000000000000	9
CAL_MAG0_YOFF	-0.148706734180450439	9
CAL_MAG0_YSCALE	1.000000000000000000	9
CAL_MAG0_ZCOMP	0.000000000000000000	9
CAL_MAG0_ZODIAG	0.000000000000000000	9
CAL_MAG0_ZOFF	-0.001039503957144916	9
CAL_MAG0_ZSCALE	1.000000000000000000	9
CAL_MAG1_ID	0	6
CAL_MAG1_ROT	-1	6
CAL_MAG2_ID	0	6
CAL_MAG2_ROT	-1	6
CAL_MAG3_ID	0	6
CAL_MAG3_ROT	-1	6
CAL_MAG_COMP_TYP	0	6
CAL_MAG_SIDES	63	6
CAM_CAP_FBACK	0	6
CBRK_BUZZER	0	6
CBRK_FLIGHTTERM	121212	6
CBRK_IO_SAFETY	22027	6
CBRK_SUPPLY_CHK	0	6
CBRK_USB_CHK	197848	6
CBRK_VTOLARMING	0	6
COM_ACT_FAIL_ACT	0	6
COM_ARMABLE	1	6
COM_ARM_AUTH_ID	10	6
COM_ARM_AUTH_MET	0	6
COM_ARM_AUTH_REQ	0	6
COM_ARM_AUTH_TO	1.000000000000000000	9
COM_ARM_BAT_MIN	0.000000000000000000	9
COM_ARM_CHK_ESCS	0	6
COM_ARM_EKF_HGT	1.000000000000000000	9
COM_ARM_EKF_POS	0.500000000000000000	9
COM_ARM_EKF_VEL	0.500000000000000000	9
COM_ARM_EKF_YAW	0.500000000000000000	9
COM_ARM_HFLT_CHK	1	6
COM_ARM_IMU_ACC	0.699999988079071045	9
COM_ARM_IMU_GYR	0.250000000000000000	9
COM_ARM_MAG_ANG	60	6
COM_ARM_MAG_STR	2	6
COM_ARM_MIS_REQ	0	6
COM_ARM_ODID	0	6
COM_ARM_SDCARD	1	6
COM_ARM_SWISBTN	0	6
COM_ARM_WO_GPS	1	6
COM_CPU_MAX	95.000000000000000000	9
COM_DISARM_LAND	2.000000000000000000	9
COM_DISARM_MAN	1	6
COM_DISARM_PRFLT	10.000000000000000000	9
COM_DL_LOSS_T	10	6
COM_FAIL_ACT_T	5.000000000000000000	9
COM_FLIGHT_UUID	207	6
COM_FLTMODE1	-1	6
COM_FLTMODE2	-1	6
COM_FLTMODE3	-1	6
COM_FLTMODE4	-1	6
COM_FLTMODE5	-1	6
COM_FLTMODE6	-1	6
COM_FLTT_LOW_ACT	3	6
COM_FLT_PROFILE	0	6
COM_FLT_TIME_MAX	-1	6
COM_FORCE_SAFETY	0	6
COM_HLDL_LOSS_T	120	6
COM_HLDL_REG_T	0	6
COM_HOME_EN	1	6
COM_HOME_IN_AIR	0	6
COM_IMB_PROP_ACT	0	6
COM_KILL_DISARM	5.000000000000000000	9
COM_LKDOWN_TKO	3.000000000000000000	9
COM_LOW_BAT_ACT	0	6
COM_MOT_TEST_EN	1	6
COM_OBC_LOSS_T	5.000000000000000000	9
COM_OBL_RC_ACT	0	6
COM_OBS_AVOID	0	6
COM_OF_LOSS_T	1.000000000000000000	9
COM_PARACHUTE	0	6
COM_POSCTL_NAVL	0	6
COM_POS_FS_DELAY	1	6
COM_POS_FS_EPH	5.000000000000000000	9
COM_POS_LOW_EPH	-1.000000000000000000	9
COM_POWER_COUNT	1	6
COM_PREARM_MODE	0	6
COM_QC_ACT	0	6
COM_RCL_EXCEPT	0	6
COM_RC_ARM_HYST	1000	6
COM_RC_IN_MODE	3	6
COM_RC_LOSS_T	0.500000000000000000	9
COM_RC_OVERRIDE	1	6
COM_RC_STICK_OV	30.000000000000000000	9
COM_SPOOLUP_TIME	1.000000000000000000	9
COM_TAKEOFF_ACT	0	6
COM_THROW_EN	0	6
COM_THROW_SPEED	5.000000000000000000	9
COM_VEL_FS_EVH	1.000000000000000000	9
COM_WIND_MAX	-1.000000000000000000	9
COM_WIND_MAX_ACT	0	6
COM_WIND_WARN	-1.000000000000000000	9
DSHOT_3D_DEAD_H	1000	6
DSHOT_3D_DEAD_L	1000	6
DSHOT_3D_ENABLE	0	6
DSHOT_MIN	0.054999999701976776	9
DSHOT_TEL_CFG	0	6
EKF2_ABIAS_INIT	0.200000002980232239	9
EKF2_ABL_ACCLIM	25.000000000000000000	9
EKF2_ABL_GYRLIM	3.000000000000000000	9
EKF2_ABL_LIM	0.400000005960464478	9
EKF2_ABL_TAU	0.500000000000000000	9
EKF2_ACC_B_NOISE	0.003000000026077032	9
EKF2_ACC_NOISE	0.349999994039535522	9
EKF2_ANGERR_INIT	0.100000001490116119	9
EKF2_ARSP_THR	0.000000000000000000	9
EKF2_ASPD_MAX	20.000000000000000000	9
EKF2_ASP_DELAY	100.000000000000000000	9
EKF2_AVEL_DELAY	5.000000000000000000	9
EKF2_BARO_CTRL	1	6
EKF2_BARO_DELAY	0.000000000000000000	9
EKF2_BARO_GATE	5.000000000000000000	9
EKF2_BARO_NOISE	3.500000000000000000	9
EKF2_BCOEF_X	100.000000000000000000	9
EKF2_BCOEF_Y	100.000000000000000000	9
EKF2_BETA_GATE	5.000000000000000000	9
EKF2_BETA_NOISE	0.300000011920928955	9
EKF2_DECL_TYPE	3	6
EKF2_DELAY_MAX	200.000000000000000000	9
EKF2_DRAG_CTRL	0	6
EKF2_DRAG_NOISE	2.500000000000000000	9
EKF2_EAS_NOISE	1.399999976158142090	9
EKF2_EN	1	6
EKF2_EVA_NOISE	0.100000001490116119	9
EKF2_EVP_GATE	5.000000000000000000	9
EKF2_EVP_NOISE	0.100000001490116119	9
EKF2_EVV_GATE	3.000000000000000000	9
EKF2_EVV_NOISE	0.100000001490116119	9
EKF2_EV_CTRL	15	6
EKF2_EV_DELAY	0.000000000000000000	9
EKF2_EV_NOISE_MD	0	6
EKF2_EV_POS_X	0.000000000000000000	9
EKF2_EV_POS_Y	0.000000000000000000	9
EKF2_EV_POS_Z	0.000000000000000000	9
EKF2_EV_QMIN	0	6
EKF2_FUSE_BETA	0	6
EKF2_GBIAS_INIT	0.100000001490116119	9
EKF2_GND_EFF_DZ	4.000000000000000000	9
EKF2_GND_MAX_HGT	0.500000000000000000	9
EKF2_GPS_CHECK	245	6
EKF2_GPS_CTRL	7	6
EKF2_GPS_DELAY	110.000000000000000000	9
EKF2_GPS_POS_X	0.000000000000000000	9
EKF2_GPS_POS_Y	0.000000000000000000	9
EKF2_GPS_POS_Z	0.000000000000000000	9
EKF2_GPS_P_GATE	5.000000000000000000	9
EKF2_GPS_P_NOISE	0.500000000000000000	9
EKF2_GPS_V_GATE	5.000000000000000000	9
EKF2_GPS_V_NOISE	0.300000011920928955	9
EKF2_GRAV_NOISE	1.000000000000000000	9
EKF2_GSF_TAS	15.000000000000000000	9
EKF2_GYR_B_LIM	0.150000005960464478	9
EKF2_GYR_B_NOISE	0.001000000047497451	9
EKF2_GYR_NOISE	0.014999999664723873	9
EKF2_HDG_GATE	2.599999904632568359	9
EKF2_HEAD_NOISE	0.300000011920928955	9
EKF2_HGT_REF	1	6
EKF2_IMU_CTRL	7	6
EKF2_IMU_POS_X	0.000000000000000000	9
EKF2_IMU_POS_Y	0.000000000000000000	9
EKF2_IMU_POS_Z	0.000000000000000000	9
EKF2_MAG_ACCLIM	0.500000000000000000	9
EKF2_MAG_B_NOISE	0.000099999997473788	9
EKF2_MAG_CHECK	1	6
EKF2_MAG_CHK_INC	20.000000000000000000	9
EKF2_MAG_CHK_STR	0.200000002980232239	9
EKF2_MAG_DECL	0.000000000000000000	9
EKF2_MAG_DELAY	0.000000000000000000	9
EKF2_MAG_E_NOISE	0.001000000047497451	9
EKF2_MAG_GATE	3.000000000000000000	9
EKF2_MAG_NOISE	0.050000000745058060	9
EKF2_MAG_TYPE	0	6
EKF2_MCOEF	0.150000005960464478	9
EKF2_MIN_RNG	0.100000001490116119	9
EKF2_MULTI_IMU	2	6
EKF2_NOAID_NOISE	10.000000000000000000	9
EKF2_NOAID_TOUT	5000000	6
EKF2_OF_CTRL	0	6
EKF2_OF_DELAY	20.000000000000000000	9
EKF2_OF_GATE	3.000000000000000000	9
EKF2_OF_N_MAX	0.500000000000000000	9
EKF2_OF_N_MIN	0.150000005960464478	9
EKF2_OF_POS_X	0.000000000000000000	9
EKF2_OF_POS_Y	0.000000000000000000	9
EKF2_OF_POS_Z	0.000000000000000000	9
EKF2_OF_QMIN	1	6
EKF2_OF_QMIN_GND	0	6
EKF2_PCOEF_XN	0.000000000000000000	9
EKF2_PCOEF_XP	0.000000000000000000	9
EKF2_PCOEF_YN	0.000000000000000000	9
EKF2_PCOEF_YP	0.000000000000000000	9
EKF2_PCOEF_Z	0.000000000000000000	9
EKF2_PREDICT_US	10000	6
EKF2_REQ_EPH	3.000000000000000000	9
EKF2_REQ_EPV	5.000000000000000000	9
EKF2_REQ_GPS_H	10.000000000000000000	9
EKF2_REQ_HDRIFT	0.100000001490116119	9
EKF2_REQ_NSATS	6	6
EKF2_REQ_PDOP	2.500000000000000000	9
EKF2_REQ_SACC	0.500000000000000000	9
EKF2_REQ_VDRIFT	0.200000002980232239	9
EKF2_RNG_A_HMAX	5.000000000000000000	9
EKF2_RNG_A_IGATE	1.000000000000000000	9
EKF2_RNG_A_VMAX	1.000000000000000000	9
EKF2_RNG_CTRL	1	6
EKF2_RNG_DELAY	5.000000000000000000	9
EKF2_RNG_GATE	5.000000000000000000	9
EKF2_RNG_K_GATE	1.000000000000000000	9
EKF2_RNG_NOISE	0.100000001490116119	9
EKF2_RNG_PITCH	0.000000000000000000	9
EKF2_RNG_POS_X	0.000000000000000000	9
EKF2_RNG_POS_Y	0.000000000000000000	9
EKF2_RNG_POS_Z	0.000000000000000000	9
EKF2_RNG_QLTY_T	1.000000000000000000	9
EKF2_RNG_SFE	0.050000000745058060	9
EKF2_SEL_ERR_RED	0.200000002980232239	9
EKF2_SEL_IMU_ACC	1.000000000000000000	9
EKF2_SEL_IMU_ANG	15.000000000000000000	9
EKF2_SEL_IMU_RAT	7.000000000000000000	9
EKF2_SEL_IMU_VEL	2.000000000000000000	9
EKF2_SYNT_MAG_Z	0	6
EKF2_TAS_GATE	5.000000000000000000	9
EKF2_TAU_POS	0.250000000000000000	9
EKF2_TAU_VEL	0.250000000000000000	9
EKF2_TERR_GRAD	0.500000000000000000	9
EKF2_TERR_MASK	3	6
EKF2_TERR_NOISE	5.000000000000000000	9
EKF2_WIND_NSD	0.050000000745058060	9
EV_TSK_RC_LOSS	0	6
EV_TSK_STAT_DIS	0	6
FD_ACT_EN	1	6
FD_ACT_MOT_C2T	2.000000000000000000	9
FD_ACT_MOT_THR	0.200000002980232239	9
FD_ACT_MOT_TOUT	100	6
FD_ESCS_EN	1	6
FD_EXT_ATS_EN	0	6
FD_EXT_ATS_TRIG	1900	6
FD_FAIL_P	60	6
FD_FAIL_P_TTRI	0.300000011920928955	9
FD_FAIL_R	60	6
FD_FAIL_R_TTRI	0.300000011920928955	9
FD_IMB_PROP_THR	30	6
FW_AIRSPD_MAX	20.000000000000000000	9
FW_AIRSPD_TRIM	15.000000000000000000	9
FW_T_CLMB_R_SP	3.000000000000000000	9
FW_T_SINK_R_SP	2.000000000000000000	9
GF_ACTION	2	6
GF_MAX_HOR_DIST	0.000000000000000000	9
GF_MAX_VER_DIST	0.000000000000000000	9
GF_PREDICT	0	6
GF_SOURCE	0	6
GND_SPEED_THR_SC	1.000000000000000000	9
GPS_1_CONFIG	201	6
GPS_1_GNSS	0	6
GPS_1_PROTOCOL	1	6
GPS_2_CONFIG	0	6
GPS_DUMP_COMM	0	6
GPS_SAT_INFO	0	6
GPS_UBX_BAUD2	230400	6
GPS_UBX_CFG_INTF	0	6
GPS_UBX_DYNMODEL	7	6
GPS_UBX_MODE	0	6
GPS_YAW_OFFSET	0.000000000000000000	9
IMU_ACCEL_CUTOFF	30.000000000000000000	9
IMU_DGYRO_CUTOFF	30.000000000000000000	9
IMU_GYRO_CAL_EN	1	6
IMU_GYRO_CUTOFF	40.000000000000000000	9
IMU_GYRO_DNF_BW	15.000000000000000000	9
IMU_GYRO_DNF_EN	0	6
IMU_GYRO_DNF_HMC	3	6
IMU_GYRO_DNF_MIN	25.000000000000000000	9
IMU_GYRO_NF0_BW	20.000000000000000000	9
IMU_GYRO_NF0_FRQ	0.000000000000000000	9
IMU_GYRO_NF1_BW	20.000000000000000000	9
IMU_GYRO_NF1_FRQ	0.000000000000000000	9
IMU_GYRO_RATEMAX	400	6
IMU_INTEG_RATE	200	6
LPE_EN	0	6
MAN_ARM_GESTURE	1	6
MAN_KILL_GEST_T	-1.000000000000000000	9
MAV_0_CONFIG	101	6
MAV_0_FLOW_CTRL	2	6
MAV_0_FORWARD	1	6
MAV_0_MODE	0	6
MAV_0_RADIO_CTL	1	6
MAV_0_RATE	1200	6
MAV_1_CONFIG	0	6
MAV_2_CONFIG	0	6
MAV_COMP_ID	1	6
MAV_FWDEXTSP	1	6
MAV_HASH_CHK_EN	1	6
MAV_HB_FORW_EN	1	6
MAV_PROTO_VER	0	6
MAV_RADIO_TOUT	5	6
MAV_SIK_RADIO_ID	0	6
MAV_SYS_ID	1	6
MAV_TYPE	0	6
MAV_USEHILGPS	0	6
MBE_ENABLE	1	6
MBE_LEARN_GAIN	18.000000000000000000	9
MC_AIRMODE	0	6
MC_AT_EN	1	6
MIS_DIST_1WP	900.000000000000000000	9
MIS_LND_ABRT_ALT	30	6
MIS_MNT_YAW_CTL	0	6
MIS_PD_TO	5.000000000000000000	9
MIS_TAKEOFF_ALT	2.500000000000000000	9
MIS_YAW_ERR	12.000000000000000000	9
MIS_YAW_TMT	-1.000000000000000000	9
MNT_MODE_IN	-1	6
MOT_POLE_COUNT	14	6
MOT_SLEW_MAX	0.000000000000000000	9
MPC_ACC_DOWN_MAX	3.000000000000000000	9
MPC_ACC_HOR	3.000000000000000000	9
MPC_ACC_HOR_MAX	5.000000000000000000	9
MPC_ACC_UP_MAX	4.000000000000000000	9
MPC_JERK_AUTO	4.000000000000000000	9
MPC_JERK_MAX	8.000000000000000000	9
MPC_LAND_SPEED	0.699999988079071045	9
MPC_XY_CRUISE	5.000000000000000000	9
MPC_Z_V_AUTO_DN	1.500000000000000000	9
MPC_Z_V_AUTO_UP	3.000000000000000000	9
MSP_OSD_CONFIG	0	6
NAV_ACC_RAD	10.000000000000000000	9
NAV_DLL_ACT	0	6
NAV_FORCE_VT	1	6
NAV_FW_ALTL_RAD	5.000000000000000000	9
NAV_FW_ALT_RAD	10.000000000000000000	9
NAV_LOITER_RAD	80.000000000000000000	9
NAV_MC_ALT_RAD	0.800000011920928955	9
NAV_MIN_LTR_ALT	-1.000000000000000000	9
NAV_RCL_ACT	2	6
NAV_TRAFF_AVOID	1	6
NAV_TRAFF_A_HOR	500.000000000000000000	9
NAV_TRAFF_A_VER	500.000000000000000000	9
NAV_TRAFF_COLL_T	60	6
PLD_BTOUT	5.000000000000000000	9
PLD_FAPPR_ALT	0.100000001490116119	9
PLD_HACC_RAD	0.200000002980232239	9
PLD_MAX_SRCH	3	6
PLD_SRCH_ALT	10.000000000000000000	9
PLD_SRCH_TOUT	10.000000000000000000	9
PWM_AUX_DIS1	1000	6
PWM_AUX_DIS10	1000	6
PWM_AUX_DIS11	1000	6
PWM_AUX_DIS2	1000	6
PWM_AUX_DIS3	1000	6
PWM_AUX_DIS4	1000	6
PWM_AUX_DIS5	1000	6
PWM_AUX_DIS6	1000	6
PWM_AUX_DIS7	1000	6
PWM_AUX_DIS8	1000	6
PWM_AUX_DIS9	1000	6
PWM_AUX_FAIL1	-1	6
PWM_AUX_FAIL10	-1	6
PWM_AUX_FAIL11	-1	6
PWM_AUX_FAIL2	-1	6
PWM_AUX_FAIL3	-1	6
PWM_AUX_FAIL4	-1	6
PWM_AUX_FAIL5	-1	6
PWM_AUX_FAIL6	-1	6
PWM_AUX_FAIL7	-1	6
PWM_AUX_FAIL8	-1	6
PWM_AUX_FAIL9	-1	6
PWM_AUX_FUNC1	0	6
PWM_AUX_FUNC10	0	6
PWM_AUX_FUNC11	0	6
PWM_AUX_FUNC2	0	6
PWM_AUX_FUNC3	0	6
PWM_AUX_FUNC4	0	6
PWM_AUX_FUNC5	0	6
PWM_AUX_FUNC6	0	6
PWM_AUX_FUNC7	0	6
PWM_AUX_FUNC8	0	6
PWM_AUX_FUNC9	0	6
PWM_AUX_MAX1	2000	6
PWM_AUX_MAX10	2000	6
PWM_AUX_MAX11	2000	6
PWM_AUX_MAX2	2000	6
PWM_AUX_MAX3	2000	6
PWM_AUX_MAX4	2000	6
PWM_AUX_MAX5	2000	6
PWM_AUX_MAX6	2000	6
PWM_AUX_MAX7	2000	6
PWM_AUX_MAX8	2000	6
PWM_AUX_MAX9	2000	6
PWM_AUX_MIN1	1000	6
PWM_AUX_MIN10	1000	6
PWM_AUX_MIN11	1000	6
PWM_AUX_MIN2	1000	6
PWM_AUX_MIN3	1000	6
PWM_AUX_MIN4	1000	6
PWM_AUX_MIN5	1000	6
PWM_AUX_MIN6	1000	6
PWM_AUX_MIN7	1000	6
PWM_AUX_MIN8	1000	6
PWM_AUX_MIN9	1000	6
PWM_AUX_REV	0	6
PWM_AUX_TIM0	400	6
PWM_AUX_TIM1	400	6
PWM_AUX_TIM2	400	6
PWM_AUX_TIM3	400	6
PWM_MAIN_DIS1	1000	6
PWM_MAIN_DIS2	1000	6
PWM_MAIN_DIS3	1000	6
PWM_MAIN_DIS4	1000	6
PWM_MAIN_DIS5	1000	6
PWM_MAIN_DIS6	1000	6
PWM_MAIN_DIS7	1000	6
PWM_MAIN_DIS8	1000	6
PWM_MAIN_FAIL1	-1	6
PWM_MAIN_FAIL2	-1	6
PWM_MAIN_FAIL3	-1	6
PWM_MAIN_FAIL4	-1	6
PWM_MAIN_FAIL5	-1	6
PWM_MAIN_FAIL6	-1	6
PWM_MAIN_FAIL7	-1	6
PWM_MAIN_FAIL8	-1	6
PWM_MAIN_FUNC1	0	6
PWM_MAIN_FUNC2	0	6
PWM_MAIN_FUNC3	0	6
PWM_MAIN_FUNC4	0	6
PWM_MAIN_FUNC5	0	6
PWM_MAIN_FUNC6	0	6
PWM_MAIN_FUNC7	0	6
PWM_MAIN_FUNC8	0	6
PWM_MAIN_MAX1	2000	6
PWM_MAIN_MAX2	2000	6
PWM_MAIN_MAX3	2000	6
PWM_MAIN_MAX4	2000	6
PWM_MAIN_MAX5	2000	6
PWM_MAIN_MAX6	2000	6
PWM_MAIN_MAX7	2000	6
PWM_MAIN_MAX8	2000	6
PWM_MAIN_MIN1	1000	6
PWM_MAIN_MIN2	1000	6
PWM_MAIN_MIN3	1000	6
PWM_MAIN_MIN4	1000	6
PWM_MAIN_MIN5	1000	6
PWM_MAIN_MIN6	1000	6
PWM_MAIN_MIN7	1000	6
PWM_MAIN_MIN8	1000	6
PWM_MAIN_REV	0	6
PWM_MAIN_TIM0	400	6
PWM_MAIN_TIM1	400	6
PWM_MAIN_TIM2	400	6
PWM_SBUS_MODE	0	6
RC10_DZ	0.000000000000000000	9
RC10_MAX	2000.000000000000000000	9
RC10_MIN	1000.000000000000000000	9
RC10_REV	1.000000000000000000	9
RC10_TRIM	1500.000000000000000000	9
RC11_DZ	0.000000000000000000	9
RC11_MAX	2000.000000000000000000	9
RC11_MIN	1000.000000000000000000	9
RC11_REV	1.000000000000000000	9
RC11_TRIM	1500.000000000000000000	9
RC12_DZ	0.000000000000000000	9
RC12_MAX	2000.000000000000000000	9
RC12_MIN	1000.000000000000000000	9
RC12_REV	1.000000000000000000	9
RC12_TRIM	1500.000000000000000000	9
RC13_DZ	0.000000000000000000	9
RC13_MAX	2000.000000000000000000	9
RC13_MIN	1000.000000000000000000	9
RC13_REV	1.000000000000000000	9
RC13_TRIM	1500.000000000000000000	9
RC14_DZ	0.000000000000000000	9
RC14_MAX	2000.000000000000000000	9
RC14_MIN	1000.000000000000000000	9
RC14_REV	1.000000000000000000	9
RC14_TRIM	1500.000000000000000000	9
RC15_DZ	0.000000000000000000	9
RC15_MAX	2000.000000000000000000	9
RC15_MIN	1000.000000000000000000	9
RC15_REV	1.000000000000000000	9
RC15_TRIM	1500.000000000000000000	9
RC16_DZ	0.000000000000000000	9
RC16_MAX	2000.000000000000000000	9
RC16_MIN	1000.000000000000000000	9
RC16_REV	1.000000000000000000	9
RC16_TRIM	1500.000000000000000000	9
RC17_DZ	0.000000000000000000	9
RC17_MAX	2000.000000000000000000	9
RC17_MIN	1000.000000000000000000	9
RC17_REV	1.000000000000000000	9
RC17_TRIM	1500.000000000000000000	9
RC18_DZ	0.000000000000000000	9
RC18_MAX	2000.000000000000000000	9
RC18_MIN	1000.000000000000000000	9
RC18_REV	1.000000000000000000	9
RC18_TRIM	1500.000000000000000000	9
RC1_DZ	10.000000000000000000	9
RC1_MAX	2000.000000000000000000	9
RC1_MIN	1000.000000000000000000	9
RC1_REV	1.000000000000000000	9
RC1_TRIM	1500.000000000000000000	9
RC2_DZ	10.000000000000000000	9
RC2_MAX	2000.000000000000000000	9
RC2_MIN	1000.000000000000000000	9
RC2_REV	1.000000000000000000	9
RC2_TRIM	1500.000000000000000000	9
RC3_DZ	10.000000000000000000	9
RC3_MAX	2000.000000000000000000	9
RC3_MIN	1000.000000000000000000	9
RC3_REV	1.000000000000000000	9
RC3_TRIM	1500.000000000000000000	9
RC4_DZ	10.000000000000000000	9
RC4_MAX	2000.000000000000000000	9
RC4_MIN	1000.000000000000000000	9
RC4_REV	1.000000000000000000	9
RC4_TRIM	1500.000000000000000000	9
RC5_DZ	10.000000000000000000	9
RC5_MAX	2000.000000000000000000	9
RC5_MIN	1000.000000000000000000	9
RC5_REV	1.000000000000000000	9
RC5_TRIM	1500.000000000000000000	9
RC6_DZ	10.000000000000000000	9
RC6_MAX	2000.000000000000000000	9
RC6_MIN	1000.000000000000000000	9
RC6_REV	1.000000000000000000	9
RC6_TRIM	1500.000000000000000000	9
RC7_DZ	10.000000000000000000	9
RC7_MAX	2000.000000000000000000	9
RC7_MIN	1000.000000000000000000	9
RC7_REV	1.000000000000000000	9
RC7_TRIM	1500.000000000000000000	9
RC8_DZ	10.000000000000000000	9
RC8_MAX	2000.000000000000000000	9
RC8_MIN	1000.000000000000000000	9
RC8_REV	1.000000000000000000	9
RC8_TRIM	1500.000000000000000000	9
RC9_DZ	0.000000000000000000	9
RC9_MAX	2000.000000000000000000	9
RC9_MIN	1000.000000000000000000	9
RC9_REV	1.000000000000000000	9
RC9_TRIM	1500.000000000000000000	9
RC_ARMSWITCH_TH	0.750000000000000000	9
RC_CHAN_CNT	0	6
RC_CRSF_PRT_CFG	0	6
RC_ENG_MOT_TH	0.750000000000000000	9
RC_FAILS_THR	0	6
RC_GEAR_TH	0.750000000000000000	9
RC_INPUT_PROTO	-1	6
RC_KILLSWITCH_TH	0.750000000000000000	9
RC_LOITER_TH	0.750000000000000000	9
RC_MAP_ACRO_SW	0	6
RC_MAP_ARM_SW	0	6
RC_MAP_AUX1	0	6
RC_MAP_AUX2	0	6
RC_MAP_AUX3	0	6
RC_MAP_AUX4	0	6
RC_MAP_AUX5	0	6
RC_MAP_AUX6	0	6
RC_MAP_ENG_MOT	0	6
RC_MAP_FAILSAFE	0	6
RC_MAP_FLAPS	0	6
RC_MAP_FLTMODE	0	6
RC_MAP_FLTM_BTN	0	6
RC_MAP_GEAR_SW	0	6
RC_MAP_KILL_SW	0	6
RC_MAP_LOITER_SW	0	6
RC_MAP_MAN_SW	0	6
RC_MAP_MODE_SW	0	6
RC_MAP_OFFB_SW	0	6
RC_MAP_PARAM1	0	6
RC_MAP_PARAM2	0	6
RC_MAP_PARAM3	0	6
RC_MAP_PITCH	0	6
RC_MAP_POSCTL_SW	0	6
RC_MAP_RATT_SW	0	6
RC_MAP_RETURN_SW	0	6
RC_MAP_ROLL	0	6
RC_MAP_STAB_SW	0	6
RC_MAP_THROTTLE	0	6
RC_MAP_TRANS_SW	0	6
RC_MAP_YAW	0	6
RC_OFFB_TH	0.750000000000000000	9
RC_PORT_CONFIG	0	6
RC_RETURN_TH	0.750000000000000000	9
RC_RSSI_PWM_CHAN	0	6
RC_RSSI_PWM_MAX	2000	6
RC_RSSI_PWM_MIN	1000	6
RC_TRANS_TH	0.750000000000000000	9
RTL_APPR_FORCE	0	6
RTL_CONE_ANG	45	6
RTL_DESCEND_ALT	30.000000000000000000	9
RTL_LAND_DELAY	0.000000000000000000	9
RTL_LOITER_RAD	80.000000000000000000	9
RTL_MIN_DIST	10.000000000000000000	9
RTL_PLD_MD	0	6
RTL_RETURN_ALT	60.000000000000000000	9
RTL_TIME_FACTOR	1.100000023841857910	9
RTL_TIME_MARGIN	100	6
RTL_TYPE	0	6
SDLOG_BOOT_BAT	0	6
SDLOG_DIRS_MAX	0	6
SDLOG_MISSION	0	6
SDLOG_MODE	0	6
SDLOG_PROFILE	1	6
SDLOG_UTC_OFFSET	0	6
SDLOG_UUID	1	6
SENS_BARO_QNH	1013.250000000000000000	9
SENS_BARO_RATE	20.000000000000000000	9
SENS_BOARD_ROT	0	6
SENS_BOARD_X_OFF	0.000000000000000000	9
SENS_BOARD_Y_OFF	0.000000000000000000	9
SENS_BOARD_Z_OFF	0.000000000000000000	9
SENS_CM8JL65_CFG	0	6
SENS_DPRES_OFF	0.000000000000000000	9
SENS_EN_ADIS164X	0	6
SENS_EN_BATT	0	6
SENS_EN_IRLOCK	0	6
SENS_EN_LL40LS	0	6
SENS_EN_MB12XX	0	6
SENS_EN_MS4525DO	0	6
SENS_EN_MS5525DS	0	6
SENS_EN_PAA3905	0	6
SENS_EN_PAW3902	0	6
SENS_EN_PMW3901	0	6
SENS_EN_PX4FLOW	0	6
SENS_EN_SDP3X	0	6
SENS_EN_SF1XX	0	6
SENS_EN_SHT3X	0	6
SENS_EN_SPL06	0	6
SENS_EN_TF02PRO	0	6
SENS_EN_THERMAL	-1	6
SENS_EN_TRANGER	0	6
SENS_EN_VL53L0X	0	6
SENS_EN_VL53L1X	0	6
SENS_EXT_I2C_PRB	1	6
SENS_GPS_MASK	7	6
SENS_GPS_PRIME	0	6
SENS_GPS_TAU	10.000000000000000000	9
SENS_IMU_AUTOCAL	1	6
SENS_IMU_CLPNOTI	1	6
SENS_IMU_MODE	0	6
SENS_LEDDAR1_CFG	0	6
SENS_MAG_AUTOCAL	1	6
SENS_MAG_AUTOROT	1	6
SENS_MAG_MODE	1	6
SENS_MAG_RATE	15.000000000000000000	9
SENS_MAG_SIDES	63	6
SENS_SF0X_CFG	0	6
SENS_TFLOW_CFG	0	6
SENS_TFMINI_CFG	0	6
SENS_ULAND_CFG	0	6
SER_GPS1_BAUD	0	6
SER_TEL1_BAUD	57600	6
SYS_AUTOCONFIG	0	6
SYS_AUTOSTART	0	6
SYS_CAL_ACCEL	0	6
SYS_CAL_BARO	0	6
SYS_CAL_GYRO	0	6
SYS_CAL_TDEL	24	6
SYS_CAL_TMAX	10	6
SYS_CAL_TMIN	5	6
SYS_DM_BACKEND	0	6
SYS_FAC_CAL_MODE	0	6
SYS_FAILURE_EN	0	6
SYS_HAS_BARO	1	6
SYS_HAS_GPS	1	6
SYS_HAS_MAG	1	6
SYS_HAS_NUM_ASPD	0	6
SYS_HAS_NUM_DIST	0	6
SYS_HITL	0	6
SYS_RGB_MAXBRT	1.000000000000000000	9
SYS_STCK_EN	1	6
SYS_USB_AUTO	2	6
TC_A_ENABLE	0	6
TC_B_ENABLE	0	6
TC_G_ENABLE	0	6
TC_M_ENABLE	0	6
TEL_BST_EN	0	6
TEL_FRSKY_CONFIG	0	6
TEL_HOTT_CONFIG	0	6
THR_MDL_FAC	0.000000000000000000	9
TRIG_MODE	0	6
UAVCAN_BITRATE	1000000	6
UAVCAN_EC_FAIL1	-1	6
UAVCAN_EC_FAIL2	-1	6
UAVCAN_EC_FAIL3	-1	6
UAVCAN_EC_FAIL4	-1	6
UAVCAN_EC_FAIL5	-1	6
UAVCAN_EC_FAIL6	-1	6
UAVCAN_EC_FAIL7	-1	6
UAVCAN_EC_FAIL8	-1	6
UAVCAN_EC_FUNC1	0	6
UAVCAN_EC_FUNC2	0	6
UAVCAN_EC_FUNC3	0	6
UAVCAN_EC_FUNC4	0	6
UAVCAN_EC_FUNC5	0	6
UAVCAN_EC_FUNC6	0	6
UAVCAN_EC_FUNC7	0	6
UAVCAN_EC_FUNC8	0	6
UAVCAN_EC_MAX1	8191	6
UAVCAN_EC_MAX2	8191	6
UAVCAN_EC_MAX3	8191	6
UAVCAN_EC_MAX4	8191	6
UAVCAN_EC_MAX5	8191	6
UAVCAN_EC_MAX6	8191	6
UAVCAN_EC_MAX7	8191	6
UAVCAN_EC_MAX8	8191	6
UAVCAN_EC_MIN1	1	6
UAVCAN_EC_MIN2	1	6
UAVCAN_EC_MIN3	1	6
UAVCAN_EC_MIN4	1	6
UAVCAN_EC_MIN5	1	6
UAVCAN_EC_MIN6	1	6
UAVCAN_EC_MIN7	1	6
UAVCAN_EC_MIN8	1	6
UAVCAN_EC_REV	0	6
UAVCAN_ENABLE	2	6
UAVCAN_LGT_ANTCL	2	6
UAVCAN_LGT_LAND	0	6
UAVCAN_LGT_NAV	3	6
UAVCAN_LGT_STROB	1	6
UAVCAN_NODE_ID	1	6
UAVCAN_PUB_ARM	0	6
UAVCAN_PUB_MBD	0	6
UAVCAN_PUB_RTCM	0	6
UAVCAN_SUB_ASPD	0	6
UAVCAN_SUB_BARO	0	6
UAVCAN_SUB_BAT	0	6
UAVCAN_SUB_BTN	0	6
UAVCAN_SUB_DPRES	0	6
UAVCAN_SUB_FLOW	0	6
UAVCAN_SUB_GPS	1	6
UAVCAN_SUB_GPS_R	1	6
UAVCAN_SUB_HYGRO	0	6
UAVCAN_SUB_ICE	0	6
UAVCAN_SUB_IMU	0	6
UAVCAN_SUB_MAG	1	6
UAVCAN_SUB_RNG	0	6
UAVCAN_SV_DIS1	500	6
UAVCAN_SV_DIS2	500	6
UAVCAN_SV_DIS3	500	6
UAVCAN_SV_DIS4	500	6
UAVCAN_SV_DIS5	500	6
UAVCAN_SV_DIS6	500	6
UAVCAN_SV_DIS7	500	6
UAVCAN_SV_DIS8	500	6
UAVCAN_SV_FAIL1	-1	6
UAVCAN_SV_FAIL2	-1	6
UAVCAN_SV_FAIL3	-1	6
UAVCAN_SV_FAIL4	-1	6
UAVCAN_SV_FAIL5	-1	6
UAVCAN_SV_FAIL6	-1	6
UAVCAN_SV_FAIL7	-1	6
UAVCAN_SV_FAIL8	-1	6
UAVCAN_SV_FUNC1	0	6
UAVCAN_SV_FUNC2	0	6
UAVCAN_SV_FUNC3	0	6
UAVCAN_SV_FUNC4	0	6
UAVCAN_SV_FUNC5	0	6
UAVCAN_SV_FUNC6	0	6
UAVCAN_SV_FUNC7	0	6
UAVCAN_SV_FUNC8	0	6
UAVCAN_SV_MAX1	1000	6
UAVCAN_SV_MAX2	1000	6
UAVCAN_SV_MAX3	1000	6
UAVCAN_SV_MAX4	1000	6
UAVCAN_SV_MAX5	1000	6
UAVCAN_SV_MAX6	1000	6
UAVCAN_SV_MAX7	1000	6
UAVCAN_SV_MAX8	1000	6
UAVCAN_SV_MIN1	0	6
UAVCAN_SV_MIN2	0	6
UAVCAN_SV_MIN3	0	6
UAVCAN_SV_MIN4	0	6
UAVCAN_SV_MIN5	0	6
UAVCAN_SV_MIN6	0	6
UAVCAN_SV_MIN7	0	6
UAVCAN_SV_MIN8	0	6
UAVCAN_SV_REV	0	6
USB_MAV_MODE	2	6
UXRCE_DDS_CFG	0	6
VT_B_DEC_MSS	2.000000000000000000	9
WV_EN
EKF2_EV_CTRL is the relevant parameter. Check this out: Using Vision or Motion Capture Systems for Position Estimation | PX4 Guide (main)
Additionally, EKF2_AID_MASK is no longer available in 1.15.2. It’s used until version 1.13.3. So from version 1.14.0, EKF2_EV_CTRL will be the supported one
