X500 with X7+ rotor problem
Hi, I tried to build a quadcopter with x500 v2 frame and x7+ pro flight controller.
After set up all the parameters and calibrate all sensors, I tried to test the behavior of the rotors via RC with manual flight mode.
With roll control, I expect that right two rotors should be slow down. But in fact two rotors in backward slow down, so that, right front rotor is faster than left back rotor.
Did I miss something? or is it a problem of the hardware?
Thanks
Sounds to me like you have the motors connected to the motor outputs in the wrong order. You can confirm this with the actuator test function in GQC.
Thanks for your advice. However I already tested the order of motors in QGC. Assigned all the motors and all the motors are tested. I found no weird behaviors on the motors.
But, when I check the PWM signal while controlling the roll on RC, I found the problem. PWM with 0 Roll, 0 Pitch signal converges to the signal with non-zero Roll command. Finally, there are no changes in PWM signal with Roll command.
I sent my H/W to the supplier and they tested the PWM on ArduPilot, and they told me there is no problem. I wonder why PX4 firmware only makes this problem.
Again, thanks for your advice.
