On Going problem for over 6 months…! QGC, and Holybro Pixhawk 4 Flight Controller installed on S500mm Quad Copter, installed latest Pixhawk Firmware 1.11.1, Setup and configuration all fine, Motor Test Does not work…! Craft will not ARM…! Error Messages, says
“SEE CONSOLE” listed are “D”, “I”, “E” with some significant problems, have NO freaking IDEA what any of these Messages means or the causes, and from what I gathered, neither does anyone else…! At Discuss PX4.io, Drone code, Git hub, Holybro, Painless360, 3DXR…and others…! So WTF…? Here’s the GD listing from QGC Console…
[D] at C:\projects\qgroundcontrol\src\QGCApplication.cc:267 - “Settings location “C:/Users/James/AppData/Roaming/QGroundControl.org/QGroundControl.ini” Is writable?: true”
[D] at C:\projects\qgroundcontrol\src\QGCLoggingCategory.cc:99 - “Filter rules “*Log.debug=false\n””
- [E] at :0 - “serialnmea: No serial ports found”
[D] at C:\projects\qgroundcontrol\src\Vehicle\MAVLinkLogManager.cc:360 - “MAVLink logs directory: “C:/Users/James/Documents/QGroundControl/Logs””
[D] at C:\projects\qgroundcontrol\src\QGCApplication.cc:367 - “System reported locale: QLocale(English, Default, United States) “en_US””
[D] at C:\projects\qgroundcontrol\src\QGCApplication.cc:441 - “Loading localization for “en_US””
[D] at C:\projects\qgroundcontrol\src\QtLocationPlugin\QGCMapEngine.cpp:164 - “Map Cache in: “C:/Users/James/AppData/Local/cache/QGCMapCache300” / “qgcMapCache.db”” - [E] at qrc:/qml/QGroundControl/Controls/ToolStrip.qml:100 - “qrc:/qml/QGroundControl/Controls/ToolStrip.qml:100:21: Unable to assign [undefined] to bool”
[D] at C:\projects\qgroundcontrol\src\QGCApplication.cc:819 - "“v4.0.10"”
[D] at C:\projects\qgroundcontrol\src\QtLocationPlugin\QGCTileCacheWorker.cpp:1139 - “No Internet Access”
IF ANYONE IN THIS PLACE HAS ANY IDEA WHAT THIS B.S. MEANS AND WHY ITS KEEPING MY QUAD COPTER FROM ARMING…SEND ME A REPLY AND A SOLUTION ASAP…! DON’T MEAN TO BE A HARDA$$ BUT THIS IS TOTALLY RIDICULOUS…6 FREAKING MONTHS OF THIS CRAP AND NO ONE CAN/KNOWS WHY…???
