Release candidate before next week. We will continue to compile the high level release notes.
Remaining 2 release blockers will be resolved with small fixes. Regarding 100% thrust issue, it is likely not happening with 1.14, we should keep that in mind.
D.5: Multi EKF sensor priority
Multi EKF is currently enabled for most targets. The improvement PR would add logic in EKF selection to prioritize external magnetometers.
Hi!
Wnated to follow up and see if there is an update on the support for swarm flight and simulation with PX4. Looking tor a way to have offboard control functioning with PX4 for multi vehicle flight. This would allow the implementation of swarm logic. I believe this would be of interested to many researchers as well. I couldnāt find any guide online that worked for me.
Would love to learn if:
This is currently supported on the main branch
How that can be configured and if there is documentation in place.
If this is not in place, what would it take? If someone can take the lead, I am happy to help with the implantation.
If any of the community members have working examples of using swarm algorithms with PX4.
Hi @princealy , Iāll not be able to attend tomorrow, so here is the answer for your questions.
You can simulate multiple drones with PX4 and apply offboard control on them. Everything is in the docs and it refers to the current main branch:
Multiple drone simulations: I am most familiar with Gazebo Classic (default gazebo version up to Ubuntu 20.04) and Gazebo Garden (default Gazebo version from Ubuntu 22.04). In both cases you can spawn multiple drone in different location and have them connected to a PX4 instance.
Offboard control: Once you have the simulation running you can either use offboard through mavlink (mavsdk, mavros, the one that you prefer) or you can use the new PX4 - ROS 2 bridge and its support for multi-vehicle simulations and have all the UORB topics that you want available as ROS 2 topics. Then you can implement any swarm logic on your companion computer / offboard computer.
To be clear, PX4 does not implement any swarm control algorithm. However you can send offboard commands and implements your controllers offboard.
Does this suit your needs? Feel free to open a specific topic if you have other specific needs.
