Problems with PixHawk 4 mini as Hexacopter
i’m an engeneering student from Brazil and i’m building an autonomous hexacopter drone. I have an pixhawk 4 mini, but in any configuration, one of the propellers has a different speed than the others. I’ve tried to configure several parameters but all without success. The controller also does not access the ESC’s calibration mode.
Here is a short video to exemplificate what i saying: https://youtube.com/shorts/g2e-vHQifQU
I would say try to spin that single motor using motor control in QGroundcontrol to make sure it spins correctly alone(Make sure to remove propellers first). Afterward, I would try and recalibrate everything if that motor spins as it should. If it doesn’t spin then it sounds like either an ESC problem or a wiring problem to the motor, which might be fixed by calibrating the ESC.
