2 of 6 Motors doesn't move / custom hexacopter
Hi, currently I’m working in a Hexacopter X geometry and I have troubles with 2 or even 3 motors when the vehicle is armed.
All 6 motors spin at different velocities, sometimes 4 motors stay at the same speed, and the other 2 remain stationary or spinning at lower speeds, the problem occurs randomly at every motor, sometimes Motor 2,3,4 and 6 work good or 1,2,3 and 5… etc.
I already check each motor and every ESC individually and works perfectly good.
In QGC all sensors and Air frame configurations are correctly uploaded, also firmware and software are up to date.
I’m using a pixhawk 4 FC and a Holybro Px4 PDB
What else can In try? Am I missing something?
Hi @Rodolfo_Garavito ,
Do they start when you tilt the drone or increase throttle? If yes, it is because you didn’t calibrate the ESCs. If they don’t support calibration, you need to increase the min PWM.
They Start when I tilt the drone, I´ll try to recalibrate the ESCs, Thanks for your help!
Hi, i did the calibration as you said, but wich one the drone “takes”… if you do the calibration (ESCs) by the pixhawk on the batteries panel, or if you do it manually by the controller. It takes the last you make? is supposed to spin all motors (low) at 0 throttle?
Thanks for your time!.
@Carlos_Vazquez The ESC will take the last calibration. You should calibrate them using the autopilot and QGC, yes.
