Pixhawk 6C not connecting via UART to companion computer through MAVLink nor ROS2
Current Issue:
  • Pixhawk 6C Flight controller board cannot make serial connection to companion computer over MAVLink nor UXRCE_DDS
My Setup:
  • Setup 1 (Proved to be able to connect):
FC Board: Pixhawk 1, also known as pixhawk 2.4.8
Companion Computer: Orangepi 5 max dev board
Connection: Telem2 on FC board, UART pins on Orangepi dev board
Performed actions:
  • MAVLink connection proved to be up, on serial port /dev/ttyS1 of Orangepi dev board;
  • UXRCE connection proved to be up, MicroXRCEAgent have output showing topics were created;
  • Can echo and post topic using ROS2
  • Setup 2 (Proved to have issue):
FC Board: Pixhawk 6C or Pixhawk V6C
Performed actions:
  • MAVLink connection down, double checked parameters MAV_1_CONFIG=102, UXRCE_DDS_CFG=0, SER_TEL2_BAUD=57600;
  • UXRCE connection down, double checked parameters MAV_1_CONFIG=0, UXRCE_DDS_CFG=102, SER_TEL2_BAUD=921600.
Observation:
In MAVLink console I can see uxrce_dds_client is running but in default is on UDP mode.
When I manually start uxrce_dds_client on it’s telem2 port(/dev/ttyS3) it’s waiting for connection, but when I wire it up with Orangepi dev board and start mavproxy.py or MicroXRCEAgent both methods of connection have no reply.
Conclusion:
  • I’m trying to use ROS2 on orangepi dev board, uxrce as middle ware, Pixhawk 6C as flight controller.
  • Pixhawk 1 is able to establish ROS and MAVLink connections with Orangepi dev board, so the method should work, the problem should not be with the dev board.
  • Assuming that I’ll need aome sort of logs to clear things up, or some tinkering on the 6c board if it’s a known issue, but have no clue.
Please advise
Case solved
Solution:
  • Turned out that I messed up the Pixhawk 6C FC board’s Telem2 UART pinouts, I miss read the docs and got the pin connected in the wrong way.
  • After I reversed my wire connections everything works just fine.
