Could not receive uXRCE-DDS messages through TELEM2 with serial port on companion computer
Hello all,
I am now developing with ROS2 - PX4 offboard controlling with VTOL and I am having problems with receiving ROS2 topics on companion computer.
Hardware/Software:
Drone: YangDa Sky Fury (link)
Configuration: Standard VTOL
Controller: CubePilot Cube Orange+ (link)
Firmware Version: 1.15.1
Companion Computer: AmovLab Allspark2-Orin NX (a customized version of Jetson Orin NX) (link)
CPU Architecture: ARM
Computer OS: Ubuntu 20.04
ROS Version: ROS2 Foxy
Wire Connection
TELEM2 on Orange+ <—> UART1 on Amov NX
  • According to official document, TELEM2 refers to /dev/ttyS1 on CubePilot Cube Orange+
  • According to official document, UART1 refers to /dev/ttyTHS0 on AmovLab Allspark2-Orin NX.
Autopilot Setup
  • Set MAV_1_CONFIG to 0.
  • Set UXRCE_DDS_CFG to 102(TELEM2).
  • Set SER_TEL2_BAUD to 921600.
  • In MAVLink Console run uxrce_dds_client stop then uxrce_dds_client start -t serial -d /dev/ttyS1 -b 921600.
  • Reboot Vehicle in QGroundControl.
Environment Setup on Companion Computer
Problem
On companion computer run sudo MicroXRCEAgent serial --dev /dev/ttyTHS0 -b 921600 and I only got this:
amov@amov-desktop:~$ sudo MicroXRCEAgent serial --dev /dev/ttyTHS0 -b 921600
[1741267380.825678] info | TermiosAgentLinux.cpp | init | running... | fd: 3
[1741267380.826487] info | Root.cpp | set_verbose_level | logger setup | verbose_level: 4
and running ros2 topic list I got nothing more than /rosout and /parameter_events.
Some Other Things
Check with serial connection
I ran cutecom to see the incoming data of /dev/ttyTHS0, then I got:
It seems like there are incoming data frames (starts with 7e 01 and ends cf 12) coming in with ~1hz. So I guess the wire connection was right.
Trials with Other Baud Rates
I read this and tried to set Baud rates with TELEM2 to either 57600, 115200 and 1000000. All of them cause same result. The change of baud rate including these steps(115200 for example):
  • Change SER_TEL2_BAUD to 115200.
  • In MAVLink Console run uxrce_dds_client stop then uxrce_dds_client start -t serial -d /dev/ttyS1 -b 115200.
  • Reboot vehicle in QGroundControl.
  • On companion computer run sudo MicroXRCEAgent serial --dev /dev/ttyTHS0 -b 115200.
  • Try with cutecom to see the data coming to /dev/ttyTHS0.
Basic Configuration
Parameters
In case other parameters need to be examined, I saved a .params file here.
The Most Weird Thing
I have used the SAME companion computer to receive the ROS2 topic data with another vehicle. Here is the brief information about it:
  • Model: AmovLab P450 Quadrotor.
  • Controller: Pixhawk6C
  • Firmware Version: 1.15.4
  • Link: here
  • PX4 Params: here
  • Wire Connections: TELEM2 on Pixhawk6C <—> UART1 on Amov NX
So I guess my companion computer was set right.
Summary
Basically, I’ve encounter problems with receiving uXRCE messages from a VTOL with CubePilot Cube Orange+ using a companion computer that has already succeeded with another quadrotor with Pixhawk6C. I have ruled out (in my mind) problems with wire connections and companion computer. I guess it has something to do with settings with CubePilot Cube Orange+.
I hope someone can help. I am pretty desperate about this. If someone is reading documents with AmovLab devices, they are in Mandarin and I recommend to translate it by web browser.
Wish all the best
