[mavros_posix_sitl.launch] is neither a launch file in package [px4] nor is [px4] a launch file name
When running
roslaunch px4 mavros_posix_sitl.launch
It cannot find the px4
However, the tutorial told us to add the .bashrc file
I notice the newest PX4-Autopilot change the setup_gazebo.bash into the folder gazebo-classic/
Thus, you have to manually change the path to gazebo/ to gazebo-classic/ like the below picture
you can just use bash, instead of zsh. The reason why I use zsh is just for recording commands
Although changed the source and export, it can find px4 but still cannot find other source
Then, I try to add the below line into .zshrc file
export ROS_PACKAGE_PATH=$ROS_PACKAGE_PATH:~/Firmware/Tools/sitl_gazebo
Then, it can run roslaunch px4 mavros_posix_sitl.launch but shows an error
Some people have the similar issue and cannot find the source
https://answers.gazebosim.org//question/24761/ros1gazebo-2-segfault-for-exit-code-139/
Last, I find an solution by source file , according to this ROS with Gazebo Simulation | PX4 User Guide
but I need to do some modification to run it , like below screenshot
The reason is the latest PX4-autopilot change its gazebo folder name into gazebo-classic
source Tools/simulation/gazebo-classic/setup_gazebo.bash $(pwd) $(pwd)/build/px4_sitl_default
export ROS_PACKAGE_PATH=$ROS_PACKAGE_PATH:$(pwd)
export ROS_PACKAGE_PATH=$ROS_PACKAGE_PATH:$(pwd)/Tools/simulation/gazebo-classic/sitl_gazebo-classic
My platform is ubuntu 18.04 and python version is 3.6.9
Then, I can successfully run
and
rostopic echo /mavros/imu/data
follows 2 small error.
One is Error [Converter.cc:151] Unable to convert from SDF version 1.7 to 1.6
https://answers.gazebosim.org//question/7691/unable-to-convert-from-sdf-version-15-to-14/
I solved it by editing sdf file version from 1.7 to 1.6
The other error is
[ERROR] [1674526819.464722103, 51.024000000]: TM : Time jump detected. Resetting time synchroniser.
There is warning about too many subscription
WARN  [logger] Too many subscriptions, failed to add: estimator_aid_src_ev_vel 5
