Hello all, I am a newbie on this px4 platform. There are some errors appear when I run SITL for the iris quadrotor as you can see below
INFO [px4] startup script: /bin/sh etc/init.d-posix/rcS 0
INFO [init] found model autostart file as SYS_AUTOSTART=10015
INFO [param] selected parameter default file parameters.bson
INFO [param] importing from 'parameters.bson'
INFO [parameters] BSON document size 684 bytes, decoded 684 bytes (INT32:25, FLOAT:9)
INFO [param] selected parameter backup file parameters_backup.bson
INFO [dataman] data manager file './dataman' size is 7872608 bytes
INFO [init] PX4_SIM_HOSTNAME: localhost
INFO [simulator_mavlink] Waiting for simulator to accept connection on TCP port 4560
INFO [simulator_mavlink] Simulator connected on TCP port 4560.
INFO [lockstep_scheduler] setting initial absolute time to 3228000 us
WARN [vehicle_angular_velocity] no gyro selected, using sensor_gyro_fifo:0 1310988
INFO [commander] LED: open /dev/led0 failed (22)
WARN [health_and_arming_checks] Preflight Fail: ekf2 missing data
Gazebo multi-robot simulator, version 11.10.2
Copyright (C) 2012 Open Source Robotics Foundation.
http://gazebosim.org
As can be seen in the code above, 2 WARN messages occur. I already checked through QGC that the gyro_sensor is available. It will be great help if someone tells me how to fix this error. Thank you in advance!
Here is the full output when I run “make px4_sitl gazebo-classic”
[0/4] Performing build step for 'sitl_gazebo-classic'
ninja: no work to do.
[3/4] cd /home/fortinov/PX4-Autopilot/build/px4_sitl_defau...opilot /home/fortinov/PX4-Autopilot/build/px4_sitl_default
SITL ARGS
sitl_bin: /home/fortinov/PX4-Autopilot/build/px4_sitl_default/bin/px4
debugger: none
model: iris
world: none
src_path: /home/fortinov/PX4-Autopilot
build_path: /home/fortinov/PX4-Autopilot/build/px4_sitl_default
GAZEBO_PLUGIN_PATH :/home/fortinov/PX4-Autopilot/build/px4_sitl_default/build_gazebo-classic
GAZEBO_MODEL_PATH :/home/fortinov/PX4-Autopilot/Tools/simulation/gazebo-classic/sitl_gazebo-classic/models
LD_LIBRARY_PATH /opt/ros/humble/opt/rviz_ogre_vendor/lib:/opt/ros/humble/lib/x86_64-linux-gnu:/opt/ros/humble/lib:/home/fortinov/PX4-Autopilot/build/px4_sitl_default/build_gazebo-classic
empty world, setting empty.world as default
Using: /home/fortinov/PX4-Autopilot/Tools/simulation/gazebo-classic/sitl_gazebo-classic/models/iris/iris.sdf
SITL COMMAND: "/home/fortinov/PX4-Autopilot/build/px4_sitl_default/bin/px4" "/home/fortinov/PX4-Autopilot/build/px4_sitl_default"/etc
______ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
INFO [parameters] BSON document size 338 bytes, decoded 338 bytes (INT32:14, FLOAT:3)
INFO [lockstep_scheduler] setting initial absolute time to 3328000 us
[Msg] Waiting for master.
[Msg] Publicized address: 172.29.68.132
+ UXRCE_DDS_DOM_ID: curr: 25 -> new: 0
INFO [mavlink] mode: Normal, data rate: 4000000 B/s on udp port 18570 remote port 14550
INFO [mavlink] mode: Onboard, data rate: 4000 B/s on udp port 14280 remote port 14030
INFO [mavlink] mode: Gimbal, data rate: 400000 B/s on udp port 13030 remote port 13280
INFO [logger] [logger] ./log/2024-04-17/09_57_25.ulg
INFO [logger] Opened full log file: ./log/2024-04-17/09_57_25.ulg
INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
pxh> INFO [tone_alarm] home set
INFO [commander] Ready for takeoff!
[Wrn] [GuiIface.cc:120] QStandardPaths: wrong permissions on runtime directory /run/user/1000/, 0755 instead of 0700
INFO [uxrce_dds_client] synchronized with time offset 1713347842805999us
INFO [uxrce_dds_client] successfully created rt/fmu/out/battery_status data writer, topic id: 19
INFO [uxrce_dds_client] successfully created rt/fmu/out/estimator_status_flags data writer, topic id: 87
INFO [uxrce_dds_client] successfully created rt/fmu/out/failsafe_flags data writer, topic id: 93
INFO [uxrce_dds_client] successfully created rt/fmu/out/manual_control_setpoint data writer, topic id: 140
INFO [uxrce_dds_client] successfully created rt/fmu/out/position_setpoint_triplet data writer, topic id: 171INFO [uxrce_dds_client] successfully created rt/fmu/out/sensor_combined data writer, topic id: 194
INFO [uxrce_dds_client] successfully created rt/fmu/out/timesync_status data writer, topic id: 217
INFO [uxrce_dds_client] successfully created rt/fmu/out/vehicle_attitude data writer, topic id: 233
INFO [uxrce_dds_client] successfully created rt/fmu/out/vehicle_control_mode data writer, topic id: 240
INFO [uxrce_dds_client] successfully created rt/fmu/out/vehicle_global_position data writer, topic id: 241
INFO [uxrce_dds_client] successfully created rt/fmu/out/vehicle_gps_position data writer, topic id: 243
INFO [uxrce_dds_client] successfully created rt/fmu/out/vehicle_local_position data writer, topic id: 247
INFO [uxrce_dds_client] successfully created rt/fmu/out/vehicle_odometry data writer, topic id: 252
INFO [uxrce_dds_client] successfully created rt/fmu/out/vehicle_status data writer, topic id: 257
INFO [uxrce_dds_client] successfully created rt/fmu/out/actuator_motors data writer, topic id: 4
INFO [uxrce_dds_client] successfully created rt/fmu/out/vehicle_rates_setpoint data writer, topic id: 255
WARN [timesync] time jump detected. Resetting time synchroniser.
I noticed also there is warning related to time jump detected. Can you tell me also why the warning occurred? Thank you in advance!
Sorry, how to do a clean build? To be honest, I am not really familiar with all these things. I have learned all related to Ubuntu and PX4 for only these past 2 months. Hence, I will appreciate if I could be guided comprehensively to understand all of the setups. Thank you for your consideration!
