Kopis 2 (Kakute F7 v1.5) PNP (R-XSR rx) Detected 0 radio
Continuing the discussion from Omnibus F4 SD:
I finally bought PNF version of Kopis 2 with Kakute f7 1.5 and as receiver frsky r-xsr.
I flash PX4 as there https://docs.px4.io/master/en/flight_controller/kakutef7.html
But “detected 0 radio channels to operate px4 you need at least 5 channels” issue is continuing.
On PNF version receiver connector cables are pre soldered.
when i connect r-xsr:
r-xsr connection- - - -kakute connection
----- gnd - - - - - - - - - - - -Gnd
------5v - - - - - - - - - - - - -5v
------s-port - - - - - - - - - - T6
------sbus-out - - - - - - - - R4
------sbus-in - - - - - - - - Not Soldered
Am i need make any corrections on Parameter list via QGround?
Or anything else?
@bkueng
Hi
SBUS out should go to R6.
Actually did you select the Kopis airframe? Then it should work as well.
https://docs.px4.io/master/en/complete_vehicles/holybro_kopis2.html
Hi @bkueng,
Sorry for late response.
I change Sbus-out and S-port solders to
Sbus-out -> R6
S-port -> T4
And,
SYS_AUTOSTART = 4053
For now everything is fine.
Maybe some info about soldering can be added to https://docs.px4.io/master/en/flight_controller/kakutef7.html
Thanks for supports…
Now I’m working on corrections esc etc. parameters and will try to add PX4Flow sensor.
