Finally everything is okey about flash but there is an odd issue.
I flashed Kopis2 and select SYS_AUTOSTART = 4053(Holybro Kopis2)
All calibrations and transmitter switch assignments are done.
Then changed parameters to;
SYS_MC_EST_GROUP = EKF2
MC_AIRMODE = Disabled
EKF2_AID_MASK = 2(optical flow)
When armed motors are spinning but not response to transmitter’s yaw, thrust, roll, pitch sticks.
I armed and disarmed with transmitter switch.
First i think it’s because of esc calibration but dshot is not need for calibration and when i try esc calibration with Qground an error occured about safety switch.
When changed Multicopter Altitude Control, Multicopter Position Control and Multicopter Rate control parameter to default, only thrust stick responsed but the motors spinned with vibration, like out of whack. Frame made some disturbing noise.
I need help.
@bkueng
