Holybro H-RTK UM982 v1.15.4
Hey guys, I am using for a while now the Holybro UM982 H-RTK Unicore UM982 (Dual Antenna Heading) – Holybro Store
most time I used with with 1.14.3 custom build firmware and 1.15.1 custom build firmware.
I want to upgrade to 1.15.4 and I uploaded the stable fimware from qgroundcontrol, although I have set the right parameter (as before) the GPS does not seem to be recognized with the flightcontroller… Did anyone ran into this issue as well? I also saw in the release notes that there where some changes made with 1.15.4, are there parameters that have to be changed? Or is it an other issue?
Thanks for your help
