Help Setting Up DJI O3 Air Unit with OSD on PX4 1.15 (MSP_OSD)
Hi everyone,
I’m trying to set up the DJI O3 Air Unit with OSD on PX4. I’ve flashed version 1.15 with MSP_OSD enabled and connected the DJI O3 Air Unit to TELEM1. However, I’m only seeing the main battery voltage displayed on the OSD—no other telemetry data appears.
Interestingly, when I tested the same setup with a Caddx Vista, the OSD works as expected, showing all relevant telemetry data.
Does anyone have experience with the DJI O3 Air Unit and PX4 MSP_OSD? Is there a specific configuration or workaround needed to get the OSD working fully with the O3 Air Unit?
Any insights or advice would be greatly appreciated.
Thanks in advance!
Hey,
I’m also trying to set it up.
I found a bit of documentation and several links in the original PR.
Since this code likely comes from Betaflight, I bet we’ll need to Root our goggles. Follow this tutorial.
Yes the goggles must be rooted in order to use the MSP_OSD, but the root is only for the Vista air unit, as I mentioned above with the vista everything is working properly.
The o3 air unit is not root able with WTFOS
And that’s why I having a problem getting a OSD on it.
It think it has something to do with canvas mode, but it is just a guess.
Having the same problem here trying to configure OSD for my O3 air unit on DJI integra. I tried all possible configurations found online but still nothing.
Does anybody have a solution?
I have a problem too, with connecting/reading the OSD of the O3 while it is connected to my Holybro 6C Mini, even after having enabled the OSD
When I am arming the DJI Air Unit is leaving Low Power mode but I can not get any OSD… What be be the issue?
Did anyone ever figure out how to display any telemetry data on the DJI systems?
