Sep 01, 2020
Call Moderators
Agenda Items
- DS-015 Update
Dail In
Direct link to the meeting: https://bit.ly/3gNLZ4F
Learn more about Teams | Meeting options
Meeting Minutes
Physical Layer
DS-015 now has the Physical Layer recommendations on it, which will be extended with a more clear description of the current topologies being considered (Han from NXP) and with the recommended electromechanical design of the ESC’s (maybe we can leverage the FETTech one);
Node-ID allocation
DS-015 now has a description of what is required for a node to P&P, more specifically, the description of the automatic Node-ID allocation (will be improved with the addition of a sequence diagram that replaces that enormous text);
ESC Message Set
Torsten Zunker, from FETTech, already dropped some comments on the document regarding the ESC data types - can be a good opportunity to close these and move forward for the others.
Errata and Feedback
