May 26, 2020
Call Moderators
Agenda Items
- UAVCAN
- Message Spec Updates
- BMS, ESC
Dail In
One tap mobile
+14086380968,567710856# US (San Jose)
+16468769923,567710856# US (New York)
Dial by your location
+1 408 638 0968 US (San Jose)
+1 646 876 9923 US (New York)
+1 669 900 6833 US (San Jose)
Meeting ID: 567 710 856
Find your local number: https://zoom.us/u/aetSYKbiMF
Meeting Minutes
Attendance
- Lorenz Meier
- Daniel Agar
- Nuno Marques
- Andrew S.
- Cis Mierlo van
- David Sidrane
- Dugan Yoon
- Jacob Crabill
- Jinger Zeng
- mac
- Peter vd Perk
- Raul Ramos
- Ray Stits
- Nuno Marques
UAVCAN
About the goal of this meeting.
Working with stakeholders from the UAVCAN community, organizations, and maintainers. The standard should drive end-adopter compatibility.
Protocol level coordination
- The fastest way to drive v1 adoption is to reserve a message space for drones
- Our group specializes in drones
- Put a proposal together to reserve message space
- Work with UAVCAN maintainers to get this approved
- Work to deliver a full implementation of the message set on PX4
New Proposals
BMSStatus
- Goal: no more than 2-4 CAN2 frames (~14 - 21 bytes tops)
- Feedback: Things to look for in messages, minimum, maximum, desired value increments in reporting
- Feedback: Add suggestions/comments directly on the document
- Notes: Timestamp removed in favor of the guaranteed maximum delivery time for a packet set in UAVCAN
ESCPowerCmd (ESCCommand*)
- Note: Command name changed to ESCPowerCmd from ESCCommand
- Goal: 3 bytes, default 400hz, max 1.2 Khz
- Goal: this message is only for power
ESCStatus
- Note: We need to further trim down this message
- FOC* Messages were moved to draft status on the bottom of the document
Meeting Documents
Next Steps
- Review spec in the current state, make sure it’s consistent
- Sync offline with team
- TODO: add quick catchup on UAVCAN for next meeting’s agenda
Errata and Feedback
