Trying to connect a new H520E via USB to QGC but it isn’t recognized. Does it work with the 520E?
Link Manager Verbose Log looks like this
[D] at C:\projects\qgroundcontrol\src\QGCApplication.cc:287 - “Settings location “C:/Users/beggers/AppData/Roaming/QGroundControl.org/QGroundControl.ini” Is writable?: true”
[D] at C:\projects\qgroundcontrol\src\QGCLoggingCategory.cc:118 - “Filter rules “*Log.debug=false\nGStreamerAPILog.debug=true\n””
[D] at C:\projects\qgroundcontrol\src\QGCApplication.cc:390 - “System reported locale: QLocale(English, Default, United States) ; Name “en_US” ; Preffered (used in maps): “en-US””
[E] at C:\projects\qgroundcontrol\src\PositionManager\PositionManager.cpp:150 - “QGCPositionManager error 0”
[E] at :0 - “Location access failed.”
[D] at C:\projects\qgroundcontrol\src\Vehicle\MAVLinkLogManager.cc:360 - “MAVLink logs directory: “//Evans-FS01/Users/beggers/Documents/QGroundControl/Logs””
[D] at C:\projects\qgroundcontrol\src\QtLocationPlugin\QGCMapEngine.cpp:164 - “Map Cache in: “C:/Users/beggers/AppData/Local/cache/QGCMapCache300” / “qgcMapCache.db””
[D] at qrc:/qml/MainRootWindow.qml:51 - “QGCCorePlugin(0x1f51d69c720) []”
[E] at :-1 - “: Invalid empty URL”
[E] at C:\projects\qgroundcontrol\src\VideoReceiver\GstVideoReceiver.cc:284 - “Stop called on empty URI”
[D] at C:\projects\qgroundcontrol\src\QGCApplication.cc:899 - "“v4.1.2"”
[D] at C:\projects\qgroundcontrol\src\QGCLoggingCategory.cc:118 - “Filter rules “*Log.debug=false\nLinkManagerLog.debug=true\nGStreamerAPILog.debug=true\n””
[D] at C:\projects\qgroundcontrol\src\QGCLoggingCategory.cc:118 - “Filter rules “*Log.debug=false\nLinkManagerLog.debug=true\nLinkManagerVerboseLog.debug=true\nGStreamerAPILog.debug=true\n””
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:474 - “-----------------------------------------------------”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:475 - "portName: “COM4"”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:476 - "systemLocation: “\\.\COM4"”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:477 - “description: “Intel® Active Management Technology - SOL””
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:478 - “manufacturer: “Intel””
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:479 - “serialNumber: “””
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:480 - “vendorIdentifier: 32902”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:481 - “productIdentifier: 1763”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:475 - "portName: “COM1"”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:476 - "systemLocation: “\\.\COM1"”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:477 - “description: “Communications Port””
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:478 - “manufacturer: “(Standard port types)””
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:480 - “vendorIdentifier: 0”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:481 - “productIdentifier: 0”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:475 - "portName: “COM6"”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:476 - "systemLocation: “\\.\COM6"”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:477 - “description: “MindPX””
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:478 - “manufacturer: “3D Robotics””
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:479 - "serialNumber: “0"”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:480 - “vendorIdentifier: 9900”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:481 - “productIdentifier: 50”
[D] at C:\projects\qgroundcontrol\src\comm\LinkManager.cc:567 - "New auto-connect port added: “PX4 FMU V5 on COM6 (AutoConnect)” “\\.\COM6"”
[D] at C:\projects\qgroundcontrol\src\comm\SerialLink.cc:205 - “open failed “A device which does not exist was specified.” QSerialPort::UnknownError “PX4 FMU V5 on COM6 (AutoConnect)” autconnect: true”
[D] at C:\projects\qgroundcontrol\src\comm\SerialLink.cc:281 - ““Error connecting: Could not create port. A device which does not exist was specified.””
