Hi everyone,
I come from the Ardupilot world but I use the same Cube Orange FCU.
My quadcopter works beautifully and I am very happy, except that it has a small flaw: although the compass is perfectly calibrated (zero problems in flight, even in rotation on the point, and has no Toilet Bowl Effect phenomena), on take-off it tends to rotate to the right but then if I correct it, it holds the bow perfectly and no longer tends to rotate so I can fly easily… I repeat… it only rotates on take-off. Probably the FCU adopts a sort of Autolearning which constantly corrects the yaw during the flight forcing the UAV to keep the correct course (in fact motors 3 and 4 work at a higher PWM despite everything being symmetrical and the payload in the centre)
I think I need to manually adjust the Rate Yaw parameter but since I want to be careful and I’m new to the PX4 world, can you tell me the appropriate command to change?
Could it be the YAWRATE_P / I /D set??
Thanks for your help
