Recently I have tried to look into my log files to increase flight performance, but a thing that is not working correctly is the logged flight time. I know that through SDLOG_UTC_OFFSET it is possible to add / substract minutes and hours from the UTC time to your local time. What bothers me though is that it is not exactly one or two hours off, but approx 14 minutes (and some seconds). Is it possible I am missing some parameter? Does anyone know how px4 determines the times that it puts in the logfiles?
I am using a holybro pixhawk v4, running the latest version of px4 master, and qgroundcontrol.
No I wasn’t using the OFFSET parameter yet, which is why it seemed strange to me that the time was off. Is it common that the time is off, and do you know how time is kept/synchronized in PX4?
An easy fix would off course be to set the OFFSET parameter to 14 min, but I am afraid this 14 min was a random number and could change on later reboots?
Ok, that’s odd. Is this problem repeatable? If yes, can you try to debug where the wrong time is coming from? E.g. you can add printfs in the gps driver to see if it’s being parsed correctly.
I just did another flight, before it it changed the OFFSET parameter to 74 minutes (60 because of time zone + 14 min because of emperical findings). Now it did log the times correctly. This time I also had a stable GPS and RTK connection. What exactly do you mean with:
I meant that if you are compiling the firmware yourself you could add some printfs in the code and debug it to see at which point the error of 14 minutes is introduced.
