Karl
January 15, 2025, 4:07am
1
I am working with the MAVLink UTM_GLOBAL_POSITION message and have encountered an issue where the time field is always reported as zero. All other fields in the message appear correct, including the latitude, longitude, and altitude data.
Interestingly, when I use the sensor_gps command in a shell connected to the vehicle system, I can obtain the correct GPS time without issues.
I would appreciate any insights on why the time field in the UTM_GLOBAL_POSITION message remains zero despite the GPS providing a correct time.
Which PX4 version is this, and what GPS?
Karl
January 15, 2025, 4:25am
3
PX4 version : 1.14.3
GPS : here4
Thanks for that.
So this is where the time is sent out:
// Compute Unix epoch and set time field
timespec tv;
px4_clock_gettime(CLOCK_REALTIME, &tv);
uint64_t unix_epoch = (uint64_t)tv.tv_sec * 1000000 + tv.tv_nsec / 1000;
// If the time is before 2001-01-01, it's probably the default 2000
if (unix_epoch > 978307200000000) {
msg.time = unix_epoch;
msg.flags |= UTM_DATA_AVAIL_FLAGS_TIME_VALID;
You can see that it takes the time/date from the OS.
One thing to check would be to type date in the MAVLink shell (QGC â Analyze tools).
Now, I assume your Here 4 is connected with DroneCAN, so then the question is why the time is not set in there. Looking at the code it should be:
// If we haven't already done so, set the system clock using GPS data
if (valid_pos_cov && !_system_clock_set) {
timespec ts{};
// get the whole microseconds
ts.tv_sec = report.time_utc_usec / 1000000ULL;
// get the remainder microseconds and convert to nanoseconds
ts.tv_nsec = (report.time_utc_usec % 1000000ULL) * 1000;
px4_clock_settime(CLOCK_REALTIME, &ts);
_system_clock_set = true;
Can you give me the output of listener sensor_gps? That way we can check whether valid_pos_cov is true or not.
Karl
January 24, 2025, 5:48am
5
Sure, this is the output of listener sensor_gps, everything include the time seems correct.
Indeed that all looks correct.
Whatâs the output of date? Does it show the time and date?
Karl
January 24, 2025, 7:41am
7
From the output of date, time field seems to start from the beginning of the UNIX epoch time.
Thatâs confusing, because the time should be set using px4_clock_settime.
What board are you using? Could it be that the RTC clock isnât correctly set up?
Karl
February 5, 2025, 2:00am
9
Weâre using a Cube Orange+ board. Could you guide me on how to ensure the RTC clock is correctly set up?
I will try to reproduce this to check whatâs going on.
Ok, so Iâm testing this on CubeOrange+ with Here4, and I think I can reproduce the problem.
It switches from initially:
nsh> date
Sat, Jan 01 00:00:09 2000
to:
nsh> date
Thu, Jan 01 00:00:00 1970
nsh> listener sensor_gps
TOPIC: sensor_gps
sensor_gps
timestamp: 12535981 (0.149041 seconds ago)
timestamp_sample: 0
time_utc_usec: 1742262003600000
device_id: 8748291 (Type: 0x85, UAVCAN:0 (0x7D))
It turns out the timestamp in
report.vel_e_m_s = msg.ned_velocity[1];
report.vel_d_m_s = msg.ned_velocity[2];
report.vel_m_s = sqrtf(report.vel_n_m_s * report.vel_n_m_s +
report.vel_e_m_s * report.vel_e_m_s +
report.vel_d_m_s * report.vel_d_m_s);
report.cog_rad = atan2f(report.vel_e_m_s, report.vel_n_m_s);
report.vel_ned_valid = true;
report.timestamp_time_relative = 0;
const uint64_t gnss_ts_usec = uavcan::UtcTime(msg.gnss_timestamp).toUSec();
switch (msg.gnss_time_standard) {
case FixType::GNSS_TIME_STANDARD_UTC:
report.time_utc_usec = gnss_ts_usec;
break;
case FixType::GNSS_TIME_STANDARD_GPS:
if (msg.num_leap_seconds > 0) {
report.time_utc_usec = gnss_ts_usec - msg.num_leap_seconds + 9;
is initially 0 before it switches to something valid.
Therefore, we need to ignore 0.
Iâve created a fix here:
main â pr-uavcan-fix-zero-utc
opened 01:53AM - 18 Mar 25 UTC
We need to wait for a valid UTC timestamp, otherwise we end up in 1970 with Here⌠4 which sends 0 for a bit even if there is already a fix.
Note that you will have to backport this yourself to v1.14.x. I might backport it to v1.15.x but it might take some time to be released.
