The pixracer has a 6 pin GPS input connector. When I plug in the GPS 6 pin connector into the Pixracer and connect the battery, I measure only 3.3 VDC across pins 1 & 6. The image below indicates that there should be 5VDV across pins 1 & 6.
What is the correct wiring?
