Hi all,
I’m using a Pixhawk 6X flight controller mounted on the Pixhawk Jetson Baseboard Bundle Holybro Pixhawk Jetson Baseboard | PX4 Guide (main)
I’ve connected an mRo u-blox GPS to the GPS1 port (10-pin GH connector), but I’m not getting 5V on the VCC pin (measured between pin 1 and GND = 0V). The GPS is not powering up. From the signals pins i am able to read 3.3v.
Things I’ve checked:
- GPS is connected correctly to GPS1 (wiring verified)
- I’m powering the Pixhawk via PM02D power module from a 6S battery
- Signal line shows 3.3V, but VCC is 0V
Do I need to set a specific ArduPilot parameter to enable 5V power to GPS1 on this baseboard? Or is this something controlled in hardware?
Thanks in advance for any advice!
