@rolandash How is the companion link set up on MindPX?
In Pixhawk, for example, I can set the companion parameter to run @ 921600 on TELEM2. Does it work the same on MindPX?
Thanks.
Thanks.
MindPX has a USB-TO-UART Bridge IC on the board.
You can set up with one USB line, micro USB connected to MindPX and standard USB to companion computer as below:
Max BAUD rate is same with px4 family up to 921600.
