Hi ,
I Have a question . does VTOL in this mode control throttle during climb and desent ?
https://docs.px4.io/en/config_vtol/vtol_without_airspeed_sensor.html
Hi ,
I believe so as long as you have tuned and configured it and depends on what flight mode you’re in.
Good luck.
I mean in AUTO mode . i can’t find parameter that setup this bebaviour . if it dosen’t control throttle may cause stall in climb and overspeed in descent. does it do full throttle in climb or control vertical speed?
I think you need to look at TECS Tuning (Altitude).
Good luck.
This parametrs can not be used , do you see ?
Right. Only use the relevant ones. Go through this process as well.
Good luck.
I find parameters for throttle control from this page . Tuning method of this parameters must be added to document.
FW_T_HRATE_P
FW_T_HRATE_FF
