Dear PX4’ler
basically I am working on a VTOL / Tailsitter, which is a bit more like a bicopter and tilting motors, with a elevon like setup. I got pretty much everything under control, except, yes now the but, for whatever reason the left motor is with increasing speed running faster (and generating more thrust) and hence, I have constantly a roll. At low thrust settings, it is possible to compensate by RC input, but only up to a certain degree.
- I checked the FC installation and configuration. The horizon turns correctly, the heading is good.
- I checked the configuration allocation matrix. This seems to be okay too.
- While in STABILIZED mode, I tilted and turned the bird, and the correct response is given. (If I roll left, the left motor speed increases, the right loweres, trying to compensate my movement).
- PITCH, YAW, ROLL from RC is correct.
- Reduced the MC_rollrate to 0.01 to remove the option of a constant failure, but this does not change anything.
- ESC, the ESCs don’t require calibration;
While testing this, it is fixed to ground. Due to the constant roll, it is unflyable.
This is the RC input:
Here are the motor outputs, the with increasing thrust clearly visible:
I asked chat gpt, got not a solution
Looked if the control surface CA are somewhat reasonable, and it is at least not bad (whatever I change it does not cause a different motor behaviour).
Here is one logfile:
I guess somewhere is a strange offset parameter I do not know ![]()
Thanks for help, highly appreciated.
