VTOL - How to test FW surfaces on the field AND FC control
Hi, I’ve test all the actuators on my workshop removing the propellers ans simulating a transition to FW in stabilized mode. So I was able to verify that FC is outputting right commands to level the plane.
Now I would like to double check that on the field, as a pre-flight check.
Following that post I can check RC commands to the FC and actuators. But what about FC controllers to actuators? Is there a way to double check that FC will try to stabilize the planes once in FW mode?
Thanks
Hi @Leonardo_Garberoglio, set COM_PREARM_MODE value to 2 (Always ON) and once your FC boots flick the transition switch to FW. Now your fixed wing control surfaces will be active. You can verify the direction movement through your transmitter and manually change the aircraft attitude to check whether corrections by the FC is correct or not.
