Unable to use TELEM2 on CUAV V6X
V6X has several serial port Serial Port Mapping
So far, I tried TELEM3, UART4, they all worked for mavlink or ros2 communication.
But TELEM2 not works.
By param show -a
x   SER_TEL1_BAUD [853,1424] : 57600
    SER_TEL2_BAUD [-1,1425] : 921600
    SER_TEL3_BAUD [-1,1426] : 57600
the default SER_TEL2_BAUD is 921600. So start mavlink at default baud rate
mavlink start -d  /dev/ttyS4
it not works.
Change baud rate to 57600, then start mavlink on
param set-default SER_TEL2_BAUD 57600
reboot
param set  SER_TEL2_BAUD 57600
still not works.
Just can not figure out what’s the different between TELEM2 and other UART like TELEM1 or TELEM3
Hi @TianmingLi
Did you solve your issue?
TELEM2 is by default used as MAVLINK instance, did you disabled it before starting it manually?
