As almost all quadcopters do in manual mode my quadcopter drifts in manual mode when trims are set to 0.
I have discovered Trim_Roll, Trim_Pitch etc. parameters. These work fine in manual modes when i copy rc trims to these parameters and set trims on remote controller to 0.
However I want to use these trims without using a RC so the copter can stay in the same position when rc is not connected or in offboard mode when I send the last local position as a set point (when i do this now the copter does the same drift movement as when all trims are set to 0).
I don’t know if this is clear enough but I would appreciate any software fix ideas for my problem.
Thanks,
