I’m having trouble with the camera trigger function by pixhawk (PX4 and cube orange).
The parameters related to the trigger camera in the mission planner are set as follows.
CAM_SERVO_OFF 1100 PWM
CAM_SERVO_ON 1900 PWM
CAM_TRIGG_TYPE 0: Servo
SERVO14_FUNCTION 10: Camera trigger
And, the wiring situation is as shown in the picture. The power of servo rail is supplied from the FUTABA radio receiver (4.6V).
Nothing happens when I do a camera trigger on the mission planner screen.
When I checked the condition of the servo rail, the signal pin of servo 14 showed 0.17V in normal condition. If I press the camera trigger button on the mission planner screen, the signal pin responds, but the voltage only rises to 0.31V. I remember that the signal pin voltage rose to about 3.3V when the camera trigger was successful in the past. I don’t understand why the camera trigger is no longer working. Can anyone give me some advice where is the problem?
Best regards,
Tatsuya
