Test TX RX with servo and motor
hi all, i am new to pixhawk, i am using pixhawk 248 for fixed wing aircraft, i have set up everything about RC, on Qgroundcontrol software has received the control signal of TX. when i connect servo and motor to try to control by TX, nothing happens although the control signal has been received. i need your advice, thank you very much!
First try to check servos movements from actuator tab from “actuator testing” bars. If you configured actuator tab correctly servos should move. If there is no problem probably you didn’t arm the vehicle. Arm and try again. While trying on bench absolutely remove propellers if you are not sure they will spin or not.
Yes, i forgot to arm. I solved the problem. Thanks very much!
  • Check Servos in Actuator Tab: I’ll verify if the servos are moving correctly by using the actuator tab in the “actuator testing” bars.
  • Arm the Vehicle: If the servos are not responding, I’ll ensure that the vehicle is armed before attempting to control them.
  • Remove Propellers: While testing on the bench, I’ll make sure to remove the propellers to prevent accidental spinning.
