Sudden Loss of Stability in Hover (Front-Left Drop)
Hello everyone,
We’re currently working on a lift-cruise drone and testing in hover-only (MC mode) for now while tuning the multicopter behavior.
We encountered an issue during testing: after takeoff to a safe altitude and stable hover, the drone suddenly lost stability and dropped towards the front-left side. You can find the log here:
We’ve already checked and verified the following:
  • Power and signal wiring for all motors
  • Replaced the motor at the affected corner
  • Issue still persists after hardware checks
  • hover throttle is around 40 %
For context — we have a small motor tilt angle configured for yaw authority.
We would appreciate any insights or advice on what might be causing this, or suggestions on what else to check.
Thanks in advance!
