Servo set up Pixhawk 4
I am trying to set up my servos but I get no response from them.
I have a pixhawk 4 plugged into the computer via USB. The Receiver is a Futaba 2008SB which should be an SBUS capable Rx.
The PMB is plugged into power 1 and I have a servo plugged into the FMU output ch1 on the PMB.
The FMU and I/O out on the pixhawk are plugged into the PMB in their respective in slots.
I also have an external BEC powering the servo on that FMU output bus.
I have a PPM Encoder and it’s plugged into the PPM slot on the pixhawk, and connected to my RX. The RX seems to be receiving power just fine. When I open Qgroundcontrol it recognizes the inputs from my Transmitter (futaba 14SG), but I’m getting no response from the servo.
I’ve tried different combos of plugging this or that, I tried using the sbus channel on the RX and Pixhawk (doesn’t even recognize the radio at that point). No matter what I try, I can’t get this thing to move the servos at all. Can anyone help me get this set up properly?
Hi, I used this radio setting:
Additional Radio Setup
Aux2 PasstroughRC Channel --> choice to listbox your relative channel radio
by
Actually I found my issue, I believe.
I needed to plug IO out to FMU In, then I had to set up Pre-arming. I didn’t know that in an unarmed state it would lock the servos in place.
Now with pre-arming in place, I can wiggle the roll, yaw, and pitch servos, which was what I was wanting to accomplish for now!
Now I have to build the aircraft.
Thank you @Wildorado. The pre-arming point was useful. I armed the drone, and then I was able to control the servos. Why is this not mentioned in the documentation?
