Hi everyone,
I’m building a custom eVTOL quadplane and running into issues with the VTOL motors not spinning at all. I’m using PX4 on a Cube Orange flight controller, and I’ve been troubleshooting for days without luck. Hoping the community can point me in the right direction! Here’s the full setup and what I’ve tried.
Hardware Setup:
- Flight Controller: Cube Orange (standard, no carrier board mods)
- ESCs: 4x Flame 180A 12S HV ESCs
- Motors: 4x V807 KV170
- Battery: 12S LiPo (fully charged for testing)
- Outputs: Motors 1/2/3/4 connected to AUX OUT 1-4 on the Cube (signal wires only, power from battery to ESCs)
- Other: Using QGroundControl for config, connected via USB. No RC transmitter yet—testing via QGC sliders
Firmware/Software:
- Last PX4 version
- Airframe: Selected Generic Standard VTOL in QGC
Problem Symptoms:
- The VTOL motors (1-4) don’t spin at all, even when armed and testing via QGC Actuators sliders.
- beeps from the ESCs on power-up and after that they are quiet.
- ESCs have been calibrated multiple times via QGC (battery disconnected at start, followed instructions).
-Propulsion motor is working
What I’ve Tried So Far:
- Re-calibrated ESCs via QGC multiple times— no change.
- Checked PWM parameters: PWM_MIN=1000, PWM_MAX=2000, PWM_RATE=400
- Tested individual motors in Actuators tab— sliders move, but no motor response.
- Verified wiring: Signal wires from Cube AUX 1-4 to ESC signal inputs.
- Reset to factory settings in QGC and reconfigured airframe from scratch.
- Updated firmware to latest stable via QGC.
- Tried a simple servo on outputs 1-4— it responds to PWM, so the Cube is outputting signal.
I’m lost, it feels like the ESCs aren’t getting a valid PWM signal, or maybe a VTOL-specific config issue? Could it be a hardware fault with the Cube’s outputs, or something with the high-voltage ESCs? Any advice on next steps, common pitfalls with this setup, or params to tweak would be awesome.
thanks in advance guys
