My tiltroter Quad x VTOL is hovering just fine, but it’s constantly yawing clockwise. Somehow steering / yawing left or right doesn’t seem to have an effect. Do you have any idea or tip, why it’s rotating? I double checked the level/compass calibration and should be fine.
Parameter VT_MOT_COUNT is set to 4.
I’ve uploaded the log file to LogMuncher and waiting for the link, will attach it as soon as I receive it.
Is there an issue with LogMuncher? I always receive an error 500 and still haven’t received a link since yesterday to my mailbox.
here would be the link with the 500 error : http://logs.uaventure.com/view/PvxmX66NHsUcwd7B3zpCRg
The file format is px4log. logs.x4.io throws me this one: “HTTP Error 400: Invalid File. This seems to be a px4log file. Upload it to logs.uaventure.com.”
I can do tomorrow a longer “turning” session for logging, if this isn’t sufficient.
Maybe to my airframe type, mainly I’ve just copy and pasted the claire’s VTOL frame and added a rudder. but it’s also the same issue without - the main mixer is standard “R: 4x 10000 10000 10000 0”, so I guess this can’t cause the problem.
hopefully somebody has an idea, I’d really like to get the tilt rotor VTOL in the air
So just to continue my monologue, i was able to do another test. I unplugged the external gps / compass and configured the vehicle as standard x-Quad. Still same behavior. I also saw after it “landed” and reduced throttle to idle, that the compass still was turning, but CCW. Then I gave more throttle and could observe that the compass again was turning slowly CW. Is this an indicate for ESC/ Power module being to close to Pixhawk?
Here is another log: http://logs.uaventure.com/view/hxpbQzvqGPSZVpu6fxYFyF
It was hovering on a tether about 20cm from the ground. But yes, I can do another hover test and upload the log and also post a picture from my prototype setup, when I’m back on Sunday.
How far away should be the power line from the external compass? And will the internal compass be ignored? At the moment the power lines are about 8 cm away from the Pixhawk, approximately as long as the standard power module connector wire is to the Pixhawk.
I’m sure I can extend the external compas wire and place it somewhere farther away, but the Pixhawk self would be still close to the battery and power lines. Because it should be near to CG, right?
I can’t give you a correct distance because it also depends on how much power you put through your system. But it’s easy to find out in the log, best do a few tests with different GPS locations. When the external compass is connected it will not use the internal one (unless the external dies).
I finally got it to work! I extended the wires to the external compass, then the power line interference was gone, but it still yawed in the CW direction. I nearly went nuts, when I realized, that I didn’t pay attention to the angle of the motors, I’ve just put them on the four arms very quickly. Two of them were slightly tilted in CW’s direction and therefore the Pixhawk wasn’t able to correct such movement without losing its level position in the air.
Here is a photo of my “quick” prototype:
