Uso una radio Herelink, despues de realizar un update tanto del emisor como del nuevo receptor, todo parece funcionar correctamente en los modos automaticos, RTL etc, Pero el modo MANUAL no funciona, al intentar hacer una calibracion de la radio dentro de QGC no tengo posibilidad de mapeo de canales RC, incluso el canal 3 no aparece. Tal vez no recibe la conexion SBUS y tampoco ningun canal RC. He visto en otros foros que hay mas gente con este problema, pero no he encontrado la solucion todavia. Podrian ayudarme ? Gracias
I use a Herelink radio, after updating both the transmitter and the new receiver, everything seems to work correctly in automatic modes, RTL etc, but the MANUAL mode does not work, when trying to calibrate the radio within QGC I do not have possibility of RC channel mapping, even channel 3 does not appear. Maybe it does not receive the SBUS connection and also no RC channel. I have seen in other forums that there are more people with this problem, but I have not found the solution yet. Could you help me ? Thank you
Which PX4 version are you using? Latest stable v1.13?
Hola JulianOes, estoy usando Ardupilot, no PX4. Creo que estoy en el foro equivocado
Ok, then I’d ask over in discuss.ardupilot.org.
