PX4 Dev Call: October 9, 2019
October 9th, 2019
Participating attendees
  • Ramón Roche
  • Jinger Zeng
  • Alex Klimaj
  • Alexandre Borowczyk
  • Andries Bosma
  • Beat Kung
  • David Cabecinhas
  • Dino Mani
  • Hyon Lim
  • Jaeyoung Lim
  • Jimmy Johnson
  • Julian Oes
  • Kamil Ritz
  • Mark Sauder
  • Matina R
  • Mathieu Bresciani
  • Matthias Grob
  • Michael Schaeuble
  • Roman Bapst
  • Silvan Fuhrer
  • Tanja B
  • Tony Daniel
Agenda
  • Overall status update high level
  • Status update by component
  • What got merged last week
  • What’s still in the queue for this week
    • Blockers
  • Release v1.10
  • Community members who want to help
  • Open section for the community
High Level update
We continue working towards the 1.10 release, we are trying to lock things down to cut the release. This release introduces a lot of architecture changes and some hardware integrations.
Component update
Comms - Beat /Julian
Pixhawk used to send RC override mavlink messages, this was added about a year ago, to enable using a SITL / Pixhawk as RC input, somehow RC traveled from one drone to another (a wild guess) disabled for now. Disabled in master.
VTOL - Silvan
We’ve been fixing some issues on VTOL lately, currently working again on the rally point issue, needs time to improve and to merge. Airspeed sensor/selector follow-up PR where we enable RC selector device, to be used on control loop. Cannot be used now. Needs testing.
Fixed Wing - Silvan
No direct update, some items from above apply.
Multicopter - Mathieu / Matthias
Final changes, too risky for release.
Only 1 pr that was a bug fix
OS / NuttX
No update
Commander - Julian
  1. Different settings for RC failsafe, setting for disabled (2).
    https://github.com/PX4/Firmware/issues/12307
    -> Stay at same spot if possible, if not descend because it’s the safest we can do. Follow up with the technical stuff offline.
  2. RC failsafe NAV_RCL_ACT parameter set to land (3), we land but we don’t realize we have landed, no disarm.
    https://github.com/PX4/Firmware/issues/11468
Driver - Mark Sauder
Multiple instances Lidar Lite driver waiting for hardware,
Distance sensor driver TF Mini driver doesn’t work right now.
Agar working on 20602 IMU drivers, speedup polling rates for gyro, better downsampling, better data rate. Too risky for release.
System Architecture
No Update
Avoidance - Martina / Tanja
No major updates, two weeks ago big update went in, collision prevention improved, by improving safety you couldn’t fly towards no sensor data directions. Added PR to explicitly add allow to fly to directions where no sensor data.
MAVROS / RTPS / ROS2
No update
Testing - Anthony
Testing report
Julian: RC failsafes, do we test this? Yes, there is a test card: https://dev.px4.io/master/en/test_cards/mc_04_failsafe_testing.html
Documentation
No update
Top Posts on forums last week
This is the section where we discuss open PRs / Issues
Mark Sauder, https://github.com/PX4/Firmware/pull/13074
Reduce number of airframes and maybe remove existing ones
(https://github.com/PX4/Firmware/pull/9849)
Release v1.10
  • What’s missing for release?
  • Can we do a feature freeze now?
  • Release branch, that needs to be continuously tested until release
  • Master now becomes 1.11
  • Can we tag the RC?
  • Release team
  • Release blockers: https://github.com/PX4/Firmware/projects/17
Questions
Matthieu, Major improvements between 1.9 and 1.10, is there any difference?
DShot is ready, do we want this to be part of the release?
Martina, Avoidance is broken on current master due to update on gazebo. We are tracking what happened. Avoidance master is broken
No update
No update
Results from the quick poll on the call
Do you like the dev call in general? (yes/no)
35%20AM
Do you think the dev call adds anything useful to your day-to-day? (please rate 1 - 5)
Do you like this new format? (please rate 1-10)
40%20AM
