October 23rd, 2019
Agenda
- Overall status update high level
- Status update by component
- What got merged last week
- What’s still in the queue for this week
- Blockers
- Release v1.10
- Community members who want to help
- Open section for the community
Join Meeting
Meeting ID: 946 175 205
Call in using your phone, find your local number: https://zoom.us/u/aetSYKbiMF
Participating attendees
- No list (please help populate)
High-Level update
- Working on v1.10 release and release blockers
- New beta v1.10.0-beta4
Component update
Comms
No update
Action: make sure we get a brief from mavlink call weekly
VTOL
Roman: Discussion of architecture changes started on the #control channel on Slack. The goal is to remove technical debt in the controls, and to support tilt rotors better. Please join us on Slack.
Action: Ramón: make sure conversation is archived
Fixed Wing
Roman: Working on airspeed selector and fault detection, the module was already merged, but wasn’t hooked up to the controller, new PR from Silvan that hooks the module to the controller, we pinged test team for proper testing.
Action: follow up with the test team and Roman.
Multicopter
Matthias Grob is working on bringing in lots of architecture changes, the first one is PR 13224 “Goal: The user knows in advance if he’ll be able to arm.”. PR seems to be ready, review from other devs would be greatly appreciated
Blocked: this isn’t part of the v1.10 release, how to merge?
Action: Needs flight testing.
OS / NuttX
David Sidrane
- Nothing affecting the release
- Got 10% CPU in H7 gain by bug fixing
- Going to check SD card removal issue. Need to push the fix to NuttX upstream first, might need some time.
Action: Can potentially make it into the release, needs coordination.
Commander
Julian Oes
- PR 13130 Fix for RC failsafe disabled which lead to descend instead of hover in position
- PR 13143 Fixes for Descend mode for no GPS and not RC
Note: PRs merged, part of the new beta
Matthias Grob
PR 13224 is a revamp of the user experience for end-users / pilots, the arming and pre-flight check logic is being refactor, into one folder, and exposed by one class
Action: Devs, please help review
Driver
Mark Sauder
Not a lot of changes attended to a couple of issues, nothing major, no release blockers.
Question: Mark I have this PR on my minutes but I failed to capture any discussion, can you please help us? https://github.com/PX4/Firmware/pull/13103
System Architecture
Action: No update
Avoidance
Julian Kent, the avoidance team needs predictable release cycles, and a stable release.
Action: Avoidance team needs a stable release, to avoid synchronization issues
Action: Performance testing by the Avoidance team.
Action: ping Julian Kent on #avoidance channel once we get a better understanding of the release state.
MAVROS / RTPS / ROS2
Action: Locate someone who can give an update
Testing
Anthony Daniel
- Strong winds in the area, team hasn’t been able to fly Fixed Wing and VTOL
- Once wind conditions are nominal the team will start testing the beta
- Issue 13148 CUAV Nano has altitude issue shown on QGC
Action: Coordinate with Matthias Grob for help testing on similar hardware.
Action: Test team, figure out if this is happening in HITL
Julian Oes
Action: Need help from test team reproducing land detection edge cases
Blocker: this is a potential release blocker, if safety becomes a concern
Documentation
No updated.
Release v1.10.0
- What’s missing for release?
- Can we do a feature freeze now?
- Release branch, that needs to be continuously tested until the release
- Master now becomes 1.11
- Can we tag the RC?
- Release team
- Release blockers: https://github.com/PX4/Firmware/projects/17
- Tracked here: https://github.com/PX4/Firmware/projects/17
Project Board
Action: Issue 13147 Follow up with testing with similar hardware.
If any active community member would like to form part of the maintenance team please sign-up on the following form
Top Posts on forums last week
No update.
Errata and Feedback
