March 25, 2020
Agenda
- Status update by component/project
- Roadmap, and Release discussion
- Community Q&A
- In-Depth discussions
Join Meeting
Meeting ID: 946 175 205
Call in using your phone, find your local number: https://zoom.us/u/aetSYKbiMF
Component update
Hardware / Pixhawk
Flight Testing
System Architecture
https://github.com/PX4/Firmware/pull/14438
OS / NuttX
- SPI DMA H7 PX4 NuttX support
- S32K PX4 NuttX support
Drivers
@dagar wants to switch all the Invensense drivers over to the new driver structure and filtering architecture. It applies to every Invensese powered board (all except NXP) and needs heavy testing such that we can be confident for the release.
By default not using the MPU9250 internal mag anymore but a different internal one if available because it screws up the measurement rate of also accel and gyro of the same chip. Capture in release notes to remind people to recalibrate their mag because it will not be available anymore.
https://github.com/PX4/Firmware/pull/14473
Commander
@dagar Is testing arming state machine transition issue where it was in SHUTDOWN state and he could not calibrate anymore. The error is quite confusing. It’s a common problem.
Estimation
- No complaints about EKF heading estimator.
- No complaints about the hover thrust estimator being enabled by default.
VTOL
@Roman
Waypoints are tracked in transition mode.
Tries to keep deceleration in back transition.
https://github.com/PX4/Firmware/pull/14405
Fixed Wing
@sfuhrer still has the pr open to local position setpoints in the fixed wing position controller. It passed already quite some testing and needs review.
https://github.com/PX4/Firmware/pull/14298
It would be nice to have terrain aware landing tested in simulation because we don’t know anymore if it works or if it breaks with this pr. @Jaeyoung-Lim
Multicopter
Auto kill upon attitude divergence detection in the first 3 seconds after takeoff.
https://github.com/PX4/Firmware/pull/14428
Passing through waypoints in a straight line is now done with more speed. There was a bug.
https://github.com/PX4/Firmware/pull/14476
Integrator wind-up fixed for the acceleration setpoint execution.
VTOL transition needs additional testing because it had to be adjusted.
https://github.com/PX4/Firmware/pull/14212
Independent yaw weight and yaw gain.
https://github.com/PX4/Firmware/pull/12175
MAVSDK
- Multiple contributions for the MissionRaw plugin by Katawann (Quentin Collet) · GitHub (thanks!)
https://github.com/mavlink/MAVSDK/pull/1021
- Contributions Implement source system and component ID handling via Configuration class by coderkalyan · Pull Request #1001 · mavlink/MAVSDK · GitHub from coderkalyan
- @JonasVautherin working on C++ being unified with the other language bindings which will make the bindings scale and support all the features. This will be one of the main features necessary for release 0.1.
MAVROS / RTPS / ROS2
- MicroRTPS bridge template improvements:
- Continues working in porting Avoidance to ROS2.
Avoidance
No update
Simulation
- Changed how the model is spawned in the world. Which allows spawning the same model in different worlds that are aligned also with the correct map coordinates.
https://github.com/PX4/Firmware/pull/14166
https://github.com/PX4/sitl_gazebo/pull/441
We had the goal to release by the end of March but it currently looks like we slip by week(s).
@dagar wants to have the drivers in a decent and consistent shape for the release which is mostly finished and just needs a lot of testing to settle. Please make sure the necessary issues and bug fixes are in the release blocker project https://github.com/PX4/Firmware/projects/17
Everyone try to push for that board to get emptied and all the remaining things being up to date with master and tested.
- @david_s5 CI seems to use Astyle 2.x instead of 3.1 which presumably is the stable default version on Ubuntu 18.04. Along with the release we need to get documentation to reference the setup scripts and not mention different packages and or versions. Also we need to use the setup scripts for the CI containers.
Community Q&A
- ? is asking about gimbal driver, the new gimbal protocol and how to get invloved. @JulianOes summarizes that he’s constantly working on the new gimbal protocol which will replace for the current
MOUNT_CONTROLandMOUNT_ORIENTATIONMAVLink messages. Timeline for first implementations next few weeks. To get involved from the beginning there will be offline discussions on slack. Pull request for documentation:
https://github.com/mavlink/mavlink-devguide/pull/219
Errata and Feedback
