Porting tbs lucid h7
Hi everyone,
I am currently working on porting the TBS Lucid H7 board to PX4 (v1.16.0, NuttX 11.0.0). I am running into issues with the motor outputs and the DShot driver.
The Problem: The dshot module fails to start during the boot sequence. When I check the status in NSH, I see: ERROR [dshot] module not running WARN [MulticopterTurtleMode] failed send dshot command to the dshot hardware
Additionally, I noticed a timeout error during initialization: ERROR [commander] Timed out while waiting for thread to start
System Details:
  • Board: TBS Lucid H7 (STM32H745/755)
  • PX4 Version: 1.16.0 (Branch: formic)
  • OS: NuttX 11.0.0
  • Toolchain: GNU GCC 10.3.1
Current Status & Observations:
  1. The IMU (ICM42688P) and Baro (DPS310) are detected correctly.
  2. The Commander fails to start initially but attempts to restart later.
  3. I suspect a conflict in my timer/DMA configuration for the motor outputs.
Shell (NSH) NuttX-11.0.0
nsh>
nsh>
nsh> dmesg
HW arch: TBS_LUCID_H7
PX4 git-hash: 28ebff779fc7629482d78556036e119a059202fd
PX4 version: 1.16.0 c0 (17825984)
PX4 git-branch: formic
OS: NuttX
OS version: Release 11.0.0 (184549631)
OS git-hash: b0b49a210696dd0074dff9531fd1603afb0cc2e4
Build datetime: Feb 13 2026 08:26:24
Build uri: localhost
Build variant: default
Toolchain: GNU GCC, 10.3.1 20210621 (release)
PX4GUID: 000600000000343739383031511000380025
MCU: STM32H7[4|5]xxx, rev. V
INFO [init] formatting /dev/mmcsd0
ERROR [init] format failed
New /fs/mtd_caldata size is:
Board architecture defaults: /etc/init.d/rc.board_arch_defaults
Board defaults: /etc/init.d/rc.board_defaults
INFO [dataman] data manager RAM size is 68528 bytes
Board sensors: /etc/init.d/rc.board_sensors
INFO [icm42688] Found ICM42688P WHO_AM_I: 0x47
icm42688 #0 on SPI bus 1 rotation 6
dps310 #0 on I2C bus 2 address 0x76
ekf2 [313:237]
ERROR [commander] Task start failed (-1)
WARN [health_and_arming_checks] Preflight Fail: Accel 0 uncalibrated
WARN [health_and_arming_checks] Preflight Fail: ekf2 missing data
No autostart ID found
INFO [mavlink] mode: Normal, data rate: 1200 B/s on /dev/ttyS4 @ 57600B
ERROR [parameters] get: param 65535 invalid
INFO [cdcacm_autostart] Starting CDC/ACM autostart
Board extras: /etc/init.d/rc.board_extras
INFO [commander] not running
Commander not running, attempting to start…
sercon: Registering CDC/ACM serial driver
sercon: Successfully registered the CDC/ACM serial driver
INFO [cdcacm_autostart] Starting mavlink on /dev/ttyACM0 (SYS_USB_AUTO=2)
INFO [mavlink] mode: Onboard, data rate: 100000 B/s on /dev/ttyACM0 @ 2000000B
INFO [logger] log root dir created: /fs/microsd/log
NuttShell (NSH) NuttX-11.0.0
also the motor check libale at the qgc not lock the same
Isn’t Lucid H7 STM32H743VI ?
I also got the IMU and Baro working, but got stuck with MMCSD, can’t even mount the device. Any recommendation ? Thanks
yes you are right i change this
also the mmcsd at the bootloader config
# This file is autogenerated: PLEASE DO NOT EDIT IT.
# You can use “make menuconfig” to make any modifications to the installed .config file.
# You can then do “make savedefconfig” to generate a new defconfig file that includes your
# modifications.
# CONFIG_DEV_CONSOLE is not set
# CONFIG_DISABLE_PSEUDOFS_OPERATIONS is not set
# CONFIG_SPI_EXCHANGE is not set
# CONFIG_STM32H7_SYSCFG is not set
CONFIG_ARCH=“arm”
CONFIG_ARCH_BOARD_CUSTOM=y
CONFIG_ARCH_BOARD_CUSTOM_DIR=“../../../../boards/tbs/lucid_h7/nuttx-config”
CONFIG_ARCH_BOARD_CUSTOM_DIR_RELPATH=y
CONFIG_ARCH_BOARD_CUSTOM_NAME=“px4”
CONFIG_ARCH_CHIP=“stm32h7”
CONFIG_ARCH_CHIP_STM32H743VI=y
CONFIG_ARCH_CHIP_STM32H7=y
CONFIG_ARCH_INTERRUPTSTACK=768
CONFIG_ARMV7M_BASEPRI_WAR=y
CONFIG_ARMV7M_ICACHE=y
CONFIG_ARMV7M_MEMCPY=y
CONFIG_ARMV7M_USEBASEPRI=y
CONFIG_BOARDCTL=y
CONFIG_BOARDCTL_RESET=y
CONFIG_BOARD_ASSERT_RESET_VALUE=0
CONFIG_BOARD_INITTHREAD_PRIORITY=254
CONFIG_BOARD_LATE_INITIALIZE=y
CONFIG_BOARD_LOOPSPERMSEC=22114
CONFIG_BOARD_RESET_ON_ASSERT=2
CONFIG_CDCACM=y
CONFIG_CDCACM_PRODUCTID=0x0036
CONFIG_CDCACM_PRODUCTSTR=“PX4 BL TBS Lucid H7”
CONFIG_CDCACM_RXBUFSIZE=600
CONFIG_CDCACM_TXBUFSIZE=12000
CONFIG_CDCACM_VENDORID=0x1b8c
CONFIG_CDCACM_VENDORSTR=“TBS”
CONFIG_DEBUG_FULLOPT=y
CONFIG_DEBUG_SYMBOLS=y
CONFIG_DEBUG_TCBINFO=y
CONFIG_DEFAULT_SMALL=y
CONFIG_EXPERIMENTAL=y
CONFIG_FDCLONE_DISABLE=y
CONFIG_FDCLONE_STDIO=y
CONFIG_HAVE_CXX=y
CONFIG_HAVE_CXXINITIALIZE=y
CONFIG_IDLETHREAD_STACKSIZE=750
CONFIG_INIT_ENTRYPOINT=“bootloader_main”
CONFIG_INIT_STACKSIZE=2944
CONFIG_LIBC_FLOATINGPOINT=y
CONFIG_LIBC_LONG_LONG=y
CONFIG_LIBC_STRERROR=y
CONFIG_MEMSET_64BIT=y
CONFIG_MEMSET_OPTSPEED=y
CONFIG_PREALLOC_TIMERS=50
CONFIG_PTHREAD_STACK_MIN=512
CONFIG_RAM_SIZE=245760
CONFIG_RAM_START=0x20010000
CONFIG_RAW_BINARY=y
CONFIG_SERIAL_TERMIOS=y
CONFIG_SIG_DEFAULT=y
CONFIG_SIG_SIGALRM_ACTION=y
CONFIG_SIG_SIGUSR1_ACTION=y
CONFIG_SIG_SIGUSR2_ACTION=y
CONFIG_SPI=y
CONFIG_STACK_COLORATION=y
CONFIG_START_DAY=30
CONFIG_START_MONTH=11
CONFIG_STDIO_BUFFER_SIZE=32
CONFIG_STM32H7_BKPSRAM=y
CONFIG_STM32H7_DMA1=y
CONFIG_STM32H7_OTGFS=y
CONFIG_STM32H7_PROGMEM=y
CONFIG_STM32H7_SERIAL_DISABLE_REORDERING=y
CONFIG_STM32H7_TIM1=y
CONFIG_STM32H7_USART1=n
CONFIG_SYSTEMTICK_HOOK=y
CONFIG_SYSTEM_CDCACM=y
CONFIG_TASK_NAME_SIZE=24
CONFIG_TTY_SIGINT=y
CONFIG_TTY_SIGINT_CHAR=0x03
CONFIG_TTY_SIGTSTP=y
CONFIG_USART1_RXBUFSIZE=600
CONFIG_USART1_TXBUFSIZE=300
CONFIG_USBDEV=y
CONFIG_USBDEV_BUSPOWERED=y
CONFIG_USBDEV_MAXPOWER=500
CONFIG_USEC_PER_TICK=1000
CONFIG_MMCSD=y
CONFIG_MMCSD_SDIO=y
CONFIG_MMCSD_SDIO_MAXFREQ=400000
CONFIG_MMCSD_SDIO_MAXBLOCKLEN=512
CONFIG_MMCSD_SDIO_MAXBLOCKS=4096
CONFIG_MMCSD_SDIO_MAXSECTORS=8192
CONFIG_BAROMETER=dps310
I got the Lucid H7 Wing mistakenly thinking it was supported by PX4. When I have more spare time, I can try to take a crack at it.
