Pixhawk short circuit for IO pins
Hi friends. I’m kadir from turkey. last saturday ı used pixhawk for my drone but ı did short circuit main out and not work ıo pins. I’m sad because pixhawk is very expensive in turkey and i can’t buy a new one. so I searched error and found where the error was.
This micro controller is defective. Vcc pins (1-2-3-4) are not work. I want to replace this microcontroller and and I want to install software. Will it work when I upload firmware from Qgroundcontrol?
Sorry my english is not very good
How did you short the main out !!
i was careless and plugged the esc cable as gnd-5v-s instead of s-vcc-gnd
I don’t think these can fail easily. Did you measure using multimeter the resistance value across gnd and 5v and S & gnd
First I’d confirm that it’s bad. Often these chips will handle a short circuit for a time.
If it is really bad, then you can replace the chip. I would expect it would reprogram normally, but I have not tried that. It may need a bootloader that has to be preprogrammed.
Good luck!
thanks for the awesome information.
ı was find broken pixhawk. Tomorrow ı change old micro controller.i hope it will be ok
Hey any updates?? I am having similar problem I/O not detected.
thanks my issue has been fixed.
