Estamos creando un drone tripulado de 6 motores queremos hacer sin el mando inalambrico , que funcione con dos joystick hay algun camino o forma de hacer con pixhawk
And here is an English translation:
We are creating a 6-motor manned drone and want to make it without wireless control, to operate it with two joysticks. Is there any way or method to do this with Pixhawk?
You can use MANUAL_CONTROL via MAVLink.
Here is an example with MAVSDK that sends manual control. You could run it on a companion computer like a Raspberry Pi or Jetson and then connect to the Pixhawk via serial.
This means it’s technically feasible. However, when it comes to manned drones, I do not recommend any of this, as neither the software or hardware is developed or tested towards manned flight.
