I have a Pixhawk 6X, and it’s stopped detecting my RC RX (a FrSky X8R fwiw). I verified using a Durandal that it’s the 6X with the issue. Since I’m doing some development, I even loaded my latest dev build on the Durandal to make sure I hadn’t accidentally broken something. Nada.
Any suggestions for what I should try before giving up on this particular 6X?
Known issue. Sort of. Set your RC input type from auto to specific type (sbus) and do a soft reboot. For this issue with rssi I had to have the RC on for it to work and several times reboot.
Also, I’m not seeing the RC_INPUT_PROTO show up on QGC. Poking around the code says it should be part of the rc_input driver, but that’s enabled and I don’t see it. Thoughts?
