Dear All,
First of all thank you for all the information and support that helped immensely my research.
I bought two months ago a Pixhawk 4 Mini. It worked fantastically until a few days ago without problems nor crashes.
It all happened at home, suddenly apm checks fail due the barometer failure:
Tried all hints I found in this and other websites.
Reviewing parameters (that I did not change earlier) / try changing setting, reset , reload saved configuration, etc.
re-Install latest pix4 with QGroundControl
install plane to erase all and reinstall ardupilot latest (4.07)
power first the quad before connection to QGC or Mission Planner
I noticed that while in ardupilot the S/B led was solid red, it looks ok (no red light on) with pix4 I have a promising PWR as solid green and ACT blinking blue.
It’s hard to believe it is an hardware failure because it was all good when I plugged the usb an hour earlier.
Of course this happened a few week away from my college project presentation.
APM: Preflight Fail: Baro Sensor #0 missing
pixhawk 4 mini APM: Preflight Fail: Baro Sensor #0 missing
Should I give up and consider the Pixhawk 4 mini suddenly damaged ?
Thank you in advance,
Mario
