Pixhawk 4 FMU PWM OUT Channel Malfunction, PX4 VERSION 1.8.2 STANDARD AIRPLANE
Here is some background information.
Software: PX4: VERSION 1.8.2, Airframe: STANDARD AIRPLANE, and Q Ground Control.
Hardware: X9D RC, X8R TX/RX, Holybro Pix Hawk 4
Wiring: I followed the instructions here to wire the PMB to the the pixhawk https://www.rcgroups.com/forums/showthread.php?3143157-Pixhawk4-Power-board-does-not-transmit-PWM-signal-to-ESC
X8R is connected using S BUS to Pixhawk 4’s DSM/SBUS RC pin. A 5V BEC is connected to FMU-PWM-out 7 in the PMB. The pix hawk 4’s I/0 PWM OUT pin is connected to the Power Management Board’s FMU-PWM-in pin.
I have verified that all the channels work using X8R TX/RX (without pix hawk connected) and inside Q ground control I see each Channel moving when I send signal using my RC.
My problem is that only 3 out of the 8 channels in FMU PWM OUT are working.
Question 1: Is this because I am using a standard airplane air frame?
Question 2: Can someone please help me change the parameters in Q Ground control so that every FMU-PWM-out channel actuates when I send signal from my remote control?
Question 3: I noticed channel 1 signal (from my RC controller) actuates FMU PWM OUT 3, channel 2 signal actuates FMU PWM OUT 1, and channel 4 signal actuates FMU PWM OUT 4. How do I rearrange each channel in Q Ground control?
Hello !
I am using a quad X configuration. Pixhawk 4 and X8R are used. However I see only 4 channels in QGC. Did you figure out your problem ?
