I’m thinking about getting a 433Mhz telemetry link for my machine and after a bit of searching I have found this.
The idea is that instead of using a 2.4Ghz to control the system and then 433Mhz for telemetry and ground station we use an OpenLrs TX and RX for both…
Note that the instructions refer to APM / MissionPlanner, which are the wrong references if you want to fly with PX4. You need to use QGroundControl and PX4 in all of the places where the tutorial refers to them.
did anyone use openLRS together with px4? I tried to get it to work, but with no success so far. Here a screenshot of qGroundControl with an attached openLRS receiver via ppm on a pixRacer. The receiver is bind to a transmitter.
I also tried sbus und sumd. And i tried the latest APM on the PIXRacer. qGroundControl showed some more options while connected to APM but at the end i was not able to get the openLRS receiver to work.
would be nice to get some hints
Best,
Alex.
btw:I tried it also with the latest master version of px4
PPM Input is well tested and stable. You should check your wiring and your receiver. Do you have a scope or logic analyzer to check the signal integrity?
I will check the ppm-signal with an logic analyzer later today. Is there a way to check if the rc-in port on the cpu is still working? maybe something is burned?
@LorenzMeier
I did some measurements. The first thing i realize: there is a signal coming out of the RC-IN Port. 330ms 3,3V and 100ms off. again 330ms on and 100ms of. and so on. Nothing else connected to the pixRacer, Just USB with running qGroundControl.
Is this Normal?
//update:i did some tests with this simple ppm simulator, which works fine with px4. so the problem seems to be on the openLRS side. I’m investigating the differences at the moment.
//update2: the main difference: openLRS produces a inverted ppm-signal in comparison to the simulator.
I think that, that frequency falls into the 70cm band and may require an armature radio license. Check the rules in your area.other than those concerns it should work fine.
I’m just getting started but when you talk about telemetry why is the ground controller transmitting? Isn’t it the information produced on the plane/drone that needs to get to the operator?
I was looking at a 433mhz transmitter to extend my control range to 100km, not cheap.
