Currently trying to setup my Pixhawk (latest firmware). The pixhawk is configured with rover configuración; I have calibrated the sensors and battery.
I have an Oscilloscope hooked up but I dont see any pwm signal on the output pins. I used Qgroundcontrol and Mission planner for the configuration, but none worked.
Is there some arming procedure that needs to happen?
I have the same experience, its making me crazy. Is ROVER still supported? I see nothing with my logic analyzer on all signal outputs, even in ARMED state.
I have found that ROVER using PX4 1.6.5 does have signals coming out. 1.7 and above all produce nothing. Seems like something has been broken for a very long time, or I am not understanding something. I will continue to develop using 1.6.5 but it is quite old…
Hi Strongbad71, same problem with 1.8.0. Following your suggestion I uploaded the 1.6.5 version but issue still present. What type of airframe did you select? I tried with Generic Rover and Traxxas but the behavior is the same, no PWM output.
Some additional notes:
I’m using a companion computer in offboard mode, no radio connected
I’ve disabled several CBRK_xxx params to disable checks (RC, IO_SAFETY, SUPPLY)
Thanks, cheers
EDIT: using Mavlink Console and passing the command “pwm test -c 2 -p 1200” steering works, same with “pwm test -c 4 -p 1800” throttle works fine.
Hi, sorry for late reply. I didn’t do anything special, I selected ROVER in QGroundcontrol as you would expect. I might have used Traxxas. I hooked up a logic analyzer to the Pixhawk outputs and I could see signals on some of the pins, not all of them. Did you look at all signal pins using 1.6.5?
Anyway, regardless, I am switching to Ardupilot for the Rover project I am working on. I can’t be using something that is unsupported at the moment.
